How much does it really help to grind fins in MAF
Old May 1, 2001 | 11:22 PM
StockBastard's Avatar
You know, those little cooling fins in the MAF thing. Mine is gutted, but those fins are still in there. How much does it really help to grind those down? 1 maybe 2 HP gain, or none at all?
Thanks,
Jason
"Why StockBastard?" you might ask. Well...
84 Berlinetta body w/custom paint.
92 front/rear bumper and ground affects.
89 IROC 350tpi engine w/lots of mods.
87 3.73 possi rear w/disk brakes.
86 interior w/IROC dash.
And finally, stock Vet rims from the early 70s.(same ones used on the 69ss)
ALL IN ONE CAR!!!
Old May 1, 2001 | 11:39 PM
89ProchargedROC's Avatar
handed me about a .13 gain and 1 mph
that is around 12hp
Old May 2, 2001 | 04:52 PM
DANG, time to break out the hand grinder!
Old May 2, 2001 | 11:24 PM
CanadianBeast's Avatar
I think that removing the fins, causes the maf to underreport the airflow due to more air flowing around the wires, which runs the engine leaner, but since the ecm is set up stock to run rich this helps get the AF ratio closer to optimum therefore the engine runs better.
Now considering that this is on the power adder board you probably are supercharged or something and you need that extra CFM to feed your engine.
In either case I think it can only help, and it's free so go for it.
Old May 4, 2001 | 12:17 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Dear Bastard
Just be really careful when removing those fins. I've heard many a horror story about people screwing the whole maf while doing that.
Good luck with it though
Rob
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Old May 4, 2001 | 12:22 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
I was trying to remove the fins off of mine and if you look at the outside there are 4-5 screws, if you take them out you can pull the guts of the MAF out a little, is there something else that is holding this in place? it seems a lot easier and safer if you can pull the center out (which is how they reman these Im sure) and then cut the fins off, if anyone else has tried this with sucess please let us know.
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flowmaster 2 1/2" exhaust true dualls, recently installed a set of alum vette heads 58cc, new cam for a paxton, recently installed paxton, OMG need a posi bad. So if anyone knows where a buick GN 8.5" rear is let me know.
Old May 7, 2001 | 04:12 PM
honestly, i think it is worth the $40 to send it to TPIS to do it. they did a nice job and for a total of $50 or so with shipping, find me another mod that will get you almost .2 for that price.
Old May 9, 2001 | 10:35 PM
Thanks all for the sound advice. Yes, I do need more air flow. It just seems like something is restricting the whole thing. I'm also going to invest in a bigger throttle body, and perhaps some larger runners. If I still don't get the right results I'm going to scrap the whole stock TPI and go with a mini ram. That should get me down into the times I'm looking for. Man, what's with this curse, this need for more power and speed anyway??
Mark_ZZ3
May 24, 2018 01:02 PM
racereese
Oct 3, 2015 03:46 PM
Shane87irocz
Sep 22, 2015 06:21 PM
