Ran the GTA for the first time,....
Old Jul 20, 2001 | 01:15 AM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
I ran the GTA w/ the Vortech for the first time pretty hard. Altough I didn't "floor it, I probably had 3/4 throttle. I think my tranny is slipping pretty bad. It felt like I had one foot on the clutch half way down. so I guess this thing isn't gonna run strong untill I get a new tranny. Also, It was so funny. Now that I'm getting more air, I guess I have to get it out. When I jumped on it, I blew the cat clean off the y-pipe. and the cat is highflow along w/ the rest of the exhaust. I guess I'm making a lot of flywheel hp, but getting no more to the ground then I did w/out the sc. On top of it all, I only hit like 5lbs boost at 3/4 throttle.
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best ET (Nat. Asp.): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 -*100% NYS emissions legal*
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM, Install completed 7/9/01: 10 & 15 LB. PULLEYS, HKS race bypass, Custom cold air, Swapped to serpentine. Best ET: High 11'S I Hope.
Old Jul 21, 2001 | 01:05 AM
Car: 1987 GTA
Well, tonight I finished the Walbro 340 and the FMU. I took it out fot a run. I ran my buddies 96 12.9 sec SS camaro. He used to beat me by a couple of lengths. I got him pretty good, was pulling on him well, w/ all 10lbs. boost. He Said his car was running better than ever, and I still got him by atleast a few lenghts. Don't forget, that's w/ the 48mm tb, no PROM, all the timng pulled out, restictive exhaust and a tranny that's slipping really bad ( i could really feel it slip). any way, I guess that translates to a mid 12 if I hook up. AND when I put timing back into it, put on the 58mm tb, uncap the exhaust, fix the tranny and whatnot, I can't see how i won't get into the high 11's or low 12's atleast. So all in all I'm pretty happy!
Old Jul 22, 2001 | 09:59 AM
firebird305's Avatar
Cool!
82 firebird with 305H.O.,Block bored .30 over,Keith black hyperutectic flat top pistons for 10 to 1 compression,Turned crank,Magnafluxed connecting rods,Melling H.V. oil pump,and double roller timeing chain,Ported and shaved heads w/3angle valve job,Z-28springs,Summit push rods and comp cams magnum roller rockers,Ported Edelbrock performer r.p.m.intake,Carter 625 afbcarb,Accell spark plugs,wires,and H.E.I.super coil,Heavy duty cap and rotor,Clevite performance cam with 450-460 inches of lift,Comp cams lifters,700r-4 tranny rebuilt with trans-go rebuild kit,corvette servo,New torQue converter,Flowtech headers,Flowmaster muffler,3.73limited slip rear end,Energy suspension bushings from front to rear,Energy suspension tranny mount,New center link,ball joints,trans-am steering box,ASP power pully.
Old Jul 30, 2001 | 03:36 AM
mtx28's Avatar
impressive !! i really like your car also, just finished looking at your page. good luck with the transmission. its good some L98 guys can bring the LS1 owners back down to earth every once in a while
83 Z28--not a pretty site, sold thank goodness
74 Z28-- 383/400, green on black. pretty clean. FOR SALE!!!
Old Jul 30, 2001 | 09:52 AM
Car: 1987 GTA
Thanks. I used to tie LS1's when I ran them N/A.
Old Jul 30, 2001 | 01:55 PM
rudys119's Avatar
Nice!! how much of a pain in the rear was it to put it in????? I am thinkin of puttin a s/c in my 87 GTA once i get the money, overall bout how much money did u put into installing the SC?
87 GTA 350 TPI
Mods: K&N Air Filter, New rocker arms, Stage III chip.
Next Mods in line: Exhaust, headers
http://www.geocities.com/rudys120/transam.html
Kills:
87 Mustang 5.0,
89 Mustang 5.0 (modded)
?? Iroc
00-01? Jaguar driven buy 85 yr old guy
Too many ricers to count......
Old Jul 30, 2001 | 03:20 PM
Car: 1987 GTA
Honestly, it was not thatbad, becausei took my sweet *** time. Te biggest problem was getting the oil pan welded to acceptthe oil return, but you don't have to weld it if you don't want. I put in a intank fuel pump, thatwas aPITA too, butthey give you an inline. The sepentine conversion is SIMPLE, if you have all the parts. It takes time to find odd bolts and stuff if not, and you need a different alt, p/s, waterpump, crank pulley etc. I got most of the stuff for free, or for cheap. I had to relocate a few wires, from one side of the motor to the other, but that was just time consuming. Overall, if you are mechanical, you can do it. If you don't work on cars at all, i wouldn't try it. I had to make a lot of custom stuff fit on top of it all. But I thin that if you ffind a used kit for $2000, like i did, you will spend another $500 on extras. For me, it might have been a little more, because I opted for a new aluminum water pump and some other new stuff. Also, I had a shop dothe fuel pump for $275, but tatwas the intank. i didn't want to do it. I would think that if you bought a new kit, you should pay about $3000, and $500 in extras, at the most. So, about $3500 or $2,500 for a used kit. If you have any other specific quetions, post here or email me. good luck. it's defeinatly worth. it. But, don't forget, you could blow your tranny, rear, or need exhaust upgrades and whatnot, so you could be spendind more eventually. latr
Old Jul 31, 2001 | 06:59 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Justin,
Sounds like a great set-up. I think 11's are a definite with some tuning.Is it the V-2 "super quiet" Vortech S-trim. How quiet is it really. I would like to up grade to a V-2 S-trim from my V-1 S-trim because I can't stand the noise. How is the durability on these units. I heard the "Super Quiet" units are breaking, but I think those was the systems for the LS1.
'91 Formula
383CI Supercharged
5-speed
3.42
12.34@117.04
on Drag Radials
Old Jul 31, 2001 | 06:44 PM
Car: 1987 GTA
Actually, I don't think it is the super quiet, but then again, it's not all that loud. I'll have to get back to you on that one. But it seems to be very durable so far. I am very impressed w/ the quality. BTW, i like the sound it makes.
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fronzizzle
Aug 17, 2015 02:52 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
