10 Second, Streetable, Emission Legal Thirdgen, Possible??
Old Sep 16, 2001 | 04:54 PM
Superblue87Formula's Avatar
Here in ohio we have only a dyno test, no underhood. I am leaning toward a well built, moderate boost motor, think it's possible?
BTW, I want an efi car, pref small block.
Old Sep 16, 2001 | 05:07 PM
as a second thought, I just noticed the ramjet 502 is only 9.6:1 comp. Could a 9 psi ATI be adapted to this motor? (or would I need a 12psi b/c of all the extra cubes??) and put me where I'd want to be?
Old Sep 16, 2001 | 05:09 PM
This plan also needs to incorporate some type of long block crate engine, I can do any metal fabbing and wiring that may be required, but I'd prefer to have a professionally built engine screaming underneath it..
-=1987 Formula 350=-
Member Greater Cincinnati F-Body Association
Old Sep 17, 2001 | 01:14 AM
PROCHARGED89Z's Avatar
You know,Whipple sells a complete motor/blower combo.A gm zz4 mtor and whipple blower.Lots of torque on pump gas,only its Carb sorry.
http://www.whipplesuperchargers.com/ak_zz4.html
A ramjet could be the ticket,probably NOS would be the way to go with that motor.
Check out my Hompage,or the beginnings of one.355 dynoed at 400HP at 5800RPM & 410LBFT of TQ,on Motorhttp://www.procharged89z.cz28.com/index.html
Old Sep 17, 2001 | 06:57 AM
I would def use a blower instead of NOS, I wouldn't be driving the car that much but I want to have the power on tap when I need it.
I think a blown ramjet 502 might work very nicely..
Old Sep 17, 2001 | 09:26 AM
Kevin G's Avatar
10 second, emmisions legal, daily driven car?? You can build one no problem.. But you will need most likely around 25k to do it dependign on how much work you do yourself.
I helped build a 580RWHP dyno emmisions legal 383 LT1 car, that ran 11.29@129 on junk street tires..Easy 10s with slicks. But we used a state of the art Motec computer management system to get it to pass emmisions. Also you will need to upgrade the trans and rear to accomidate the extra power, and set up the susp to be able to hook all of the power. Also an entire new fuel system to suport the power also.. Cha Ching. It can be done, butit wil cost SERIOUS amounts of money.
Old Sep 19, 2001 | 01:27 PM
ATOMonkey's Avatar
That is some serious money. You have to use a centrifigual blower or turbo. Something that only comes on at high speed and load. If you use a roots or whipple you'll blow high numbers. Especially with a big block when they're measuring for a small block. After you get done with the suspension/chassis and solid motor/trans mounts you won't want to drive the car everyday. Having a sophisticated electronic spark/fuel management system is a must. Sounds like a fun idea though.
Old Sep 21, 2001 | 08:55 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Just a thought,A TTA could easily do this.
Stock is 13.68(mine)
Tweaked stock stuff is around 11.70
PT-54 Turbo and MSD50# injectors is around 11.2
Add a front mount intercooler and some tuning and it should go high 10's.
Cost,
PT54 $700
MSD50's $500
CAS V2 front mount $1100
Tuning $FREE
Total $2300
Figure in a few hundred more for small parts like a fuel pump and there you have a high 10 second,25 mile per gallon,emmisions legal,true daily driver with out even removing the throttle body.
I know,I know,it's not a V8 but I don't care scince I'm faster than most of the V8's around here.Just figured I'd give you another option.
Steve
1989 Turbo Trans Am's #124 and #850
1989 Turbo GTA,600hp 3.8L SFI TURBO
2001 Kawasaki ZX-6R
Old Sep 21, 2001 | 11:39 PM
Twin Turbo 358's Avatar
my '88 GTA twin turbo made 465 rwhp & 521 ft-lbs rwtq before i started the rebuild. it had a mild .440 lift cam and had dual cats & mufflers, and passed VA emissions in this configuration. although i never ran a 10 sec 1/4 in it, it definitely had the capability. i had some tuning issues and a cheap converter that would not let me get any boost on the line.
Jeff
99 T/A WS6 A4, 12.97 @ 105, lid, cutout, free EGR mod, Yank Stealth
88 GTA twin turbo 358, forged crank, forged H-beam rods, Wiseco reverse dome pistons, Dart Sportsman II 72cc heads, Comp Cams custom grind blower cam (.560/.586 lift, 232/236 duration), 1.6 roller rockers, TPIS mini ram intake manifold w/ Accel 58mm TB, 83 lb injectors, Accel DFI computer with variable injector controller, 2 Garrett T04B "hair dryers" with dual Garrett wastegates, TH400 tranny with BTE transbrake and Art Carr custom converter, F*rd 9 inch rear w/ 3.50 gears, and more...
Old Sep 23, 2001 | 11:00 AM
TTA's Avatar
TTA
<font face="Verdana, Arial" size="2">Originally posted by TTA850:
</font>
Steve Steve Steve... You know you dont need a PT54 to run 11.20s... A small PT51 will do it no problem
-Mike
89 TTA
PT51, V4, 50s, 3DP, Stock Long Block and Convertor.....
11.25@121 w/1.56 24psi Through the Exhaust on a 16psi launch
1998 LS1 T/A 6-Speed
13.10@106 Factory Stock down to the air in the tires. 296HP/319TQ
Old Sep 23, 2001 | 01:56 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
damn you TTA guys beat me to it!!
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Old Sep 23, 2001 | 05:35 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Sorry Mike,I was thinkin of your car but all these numbers get me mixed up
Steve
2001 Kawasaki ZX-6R
Old Nov 28, 2005 | 09:27 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Well I dug this up ... trying to really get ahold of the whole emmisions thing . I have the BBS 650hp kit . They are refabbing me a set of headers so I can retain the smogg pump ( suxx I need it but ohhh well ) , they are swapping it to the passenger side header. I have to figure out how where I want the bungs put in for the A.I.R .
But what I am curious about is ...once all the hardware is all visually legal ( smog ****'s up here pull ya over ...and pop the hood ...and stick a probe up your tail pipe sometimes) So the setup HAS to be tight ( legal) . You guys think I can make a 165 ECM with an FMU and a Prominator pro .... pass the smog test if need be ? It will be around 6 psi for start . I JUST rebuilt this motor before I knew I was getting a turbo so the CR is wrong ( 9.74:1) so I am going to just be nice with boost for now .
Thanx all
D
Old Nov 28, 2005 | 11:46 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I think my engine has the capacity to get in the 10's...... and it pass emission.......
/N.
Old Nov 29, 2005 | 07:20 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
/N.
Could you pass a visual as well ? Do you have all the smogg crap , etc ? I need to have all that . I am sure i could make a tune to make it pass a sniffer , etc . But it's the fact I need all the emmissions crap intact.
Old Nov 29, 2005 | 07:33 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
I'd be willing to bet my car will pass emissions if i installed a cat on it. And it cost under $12,000 all together to build(including the cost of the car, mint 92 formula)
Old Dec 1, 2005 | 05:12 PM
1bdbrd's Avatar
Car: 1991 Trans Am
Thanx all
D
i dont know how Canada is but if its as strict as say california, not even having all the air lines connected will pass a visual. the parts installed MUST have a CARB number to be emissions legal even. it doesnt matter if they help emissions to make it better than stock, if theres no CARB number its not legal. thats cali though so you may want to check with your local government first.
also, if you are gonna burn your own prom you dont need an FMU. the FMU is only a bandaid IMO because it adds fuel based on vacuum. whereas a properly tuned computer will add fuel based on load. if you are already planning on burning a prom then i would just skip the FMU.
and finally, your compression ratio is fine. theres this big myth on the internet that you are REQUIRED to run low compression with boost. that is untrue to an extent. yes it makes it more pump gas friendly, but you can run even a 10.5:1 or high compression ratio with maybe a higher octane pump gas (say 93 or so) and run some sort of alcohol injection setup to help combat detonation. but at around 9.5:1 you should be ok as long as you dont run a higher boost level. im not sure whose tuning it but if you are gonna run say a low boost and high boost setup where you have the ability up the boost whenever you want, i would start out kinda low with boost pressure and add more slowly and check for detonation. then tune accordingly.
as to the original poster, the short answer to this is no. it is IMPOSSIBLE. i say impossible because it cant truely be 100% emissions legal per Federal standards to make our cars run that fast. now i say this because NO turbo kit available for our cars (no the STS kit is not legal for our cars, only 4th gens thus far)is CARB legal. i think the only CARB legal supercharger is the Procharger P1SC and that will NOT push a full weight daily driver into the 10s. nitrous is not CARB legal (as far as i know, im not a big nitrous guy). and the CARB legal heads and cam setups arent good enough to make the power needed.
so the technical answer is no. you can probably pass emissions in most places with like a D1SC and a big inch engine or maybe a hidden nitrous setup. but other than that it wont run that fast CARB legal to my knowledge.
Old Dec 2, 2005 | 12:34 PM
Project's Avatar
Car: 85 Camaro Z28
Transmission: 700-R4
I know a couple of guys in CA that are emissions legal that runs low 11's but use nitrous
Old Dec 5, 2005 | 12:42 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
We don't need the carb numbers up here . Just anything that was origonal. As far as the FMU thing . I am running a MAF setup and havent really found anything definitive on a good tune ....for a Forced induction setup AND a MAF .... so I figured the FMU was a necessity for a starting point.
Old Dec 13, 2005 | 09:17 PM
92zcamaroperson's Avatar
Car: 92 z28 25th
Engine: 5.7 liter
just a question. Thankfully my area has no emissions testings. But how would emissions laws apply to putting an ls7 into a thirdgen? Would you have to have the emissions equipment that were originally on the third gen or that which is supposed to go with an ls7?
Old Dec 15, 2005 | 03:52 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
depends where you are .... can;t say for sure. But up here it would put you in a "hotrod"class and make you pass 1980 standsards if the engine was not an option for the car.
Think I got it right . ( PS ...maybe make a topic about it )
Old Dec 17, 2005 | 07:41 AM
1BADDAM's Avatar
Car: 89 TA
Engine: 3.8 V6
Transmission: 2004R
TTA out of Florida
http://trmirror.rage-board.com/files...iteTurboTA.wmv
Can't read the board but this was a 10.85 @ 127 pass
93 octane, drag radials, street legal
Old Dec 17, 2005 | 09:04 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
I've got the car you need, you just have to get the engine and trans!
http://www.turbobuick.com/forums/sho...76#post1212676
onefreakz
May 14, 2018 12:15 PM
MoJoe
Sep 15, 2015 12:50 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
