IF YOU WHERE TO BUILD A 600HP BLOWER MOTOR.....
Old Nov 13, 2006 | 04:17 PM
hollowcd's Avatar
Well I have been running around in these forums for a few weeks now. I have posted a few times on the things that I have for my build, and the things that I want. In the end, I want to build a 500-600HP motor for my 92 camaro. I originally was going to start with a 1972 GM 400 4-bolt main block, but after many suggestions there are better options out there to start with. So that is my first question, if you where going to build a 500-600HP street car that is going to have a P1SC or D1SC blower, and run off of pump gas, what block would you start with? Lingenfelters book on smallblocks suggests a Bow Tie block over the 400 4-Bolt, but I dont know much about these. Any suggestions? This is my first question in this post, and I am sure their will be many more. Thanks for the help fellas,
Cole
Old Nov 13, 2006 | 05:07 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It depends. How often is it going to be producing 600HP? If you have the cash then just go out and buy the Bow Tie or Dart block. If it is just a regular street /strip engine I would just get a 2 or 4-bolt 350. Yes, opinions on this will vary a lot.
Old Nov 13, 2006 | 05:13 PM
hollowcd's Avatar
As often as possible. Really I am just looking to build a bulletproof engine, something that will last. I would love to give it to my son someday as I wished that my father would have passed down his 69 to me. 500-600HP is my dream, but I am unsure of how easy that will be to build. I would like it to be a smooth idling motor, and run on pump gas. I obviously need to start at the ground up if I am building it to accept a blower, that is why I am starting at the block. Where can I get a Bow-tie block? How much? Thanks Junk,
Cole
Old Nov 13, 2006 | 05:43 PM
WaaX's Avatar
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
Get a Motown block.
Old Nov 13, 2006 | 05:51 PM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
find a 350 "010" block (long time since ive even tought of them and im not 100% if it is a 010) and if the block wasent a 4 bolt already convert it to one useing 4 bolt Splayed Main Caps (block must be line bored after 4 bolt instal), use all arp bolt/studs for the mains if i missed anything please chime in
Sean
Old Nov 13, 2006 | 06:22 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
I got a stock 2 bolt main 350 block. 3 years of extreme abuse and still running fine.
Old Nov 13, 2006 | 07:14 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
A good solid 350 "010" four bolt block with all the proper machine work and ARP everything is going to net you a pretty stout bottom end. If you have the extra money you could go more exotic and get the motown or dart block but I think I would still just go for the 010 block if it were me.
Old Nov 13, 2006 | 07:19 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
id get a 454 block, fordged stroker crank and all the other goodeis cuz being stroked is nice, and i like being blown, why not both? and whats better then a blown big block camaro with slicks and headers?
Old Nov 13, 2006 | 07:45 PM
WaaX's Avatar
Car: 1985 IROC
Axle/Gears: no idea
A blown big block camaro with slicks, headers, and a 200 shot of laughing gas =]
Old Nov 13, 2006 | 09:24 PM
hollowcd's Avatar
Would this work, other than I want forged Pistons????
1978 350 4-bolt main 010 block
.060 over zero decked
clearanced for 383 stroker
hyper 4-valve releif flattop pistons
chromemoly rings
GM crank
GM vortec 5.7 rods
Double row timing chain
HV melling oil pump
clevite rod/main bearings
292h 501/501 flattappet cam/lifters
oil pan
timing cover
balancer
flexplate
Fresh build, never run, ready for your choice of heads!!!!! $850
Old Nov 13, 2006 | 09:40 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
hyper pistons don't like boost.
go with a blower cam for a blower or a turbo cam for a turbo, or an N/A cam for N/A. they don't cost more so why not.
.060 over is a lot for boost too.
Old Nov 13, 2006 | 09:46 PM
hollowcd's Avatar
I agree, just curious as if it was a good price, and if I would be able to sell any of the combo I didnt use. Thanks, keep the advice coming. Dang those Mowtowns are expensive!!!
Old Nov 14, 2006 | 06:35 PM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
how bout a blown, injected, stroked, roller-cammed, aluminum headed, 815 ci hemi?
Old Nov 14, 2006 | 07:13 PM
BBCAM's Avatar
Car: 99 Camaro
Engine: LS
Transmission: TH-400
Axle/Gears: 3.25 9"
Theres nothing wrong with either a "010" block or a two or 4 bolt 400 at the 400-600 HP range we have built a couple of 412ci 400s that were well over 600HP on spray and haven't had much trouble with blocks ... but a good steel crank is a must cola, scat, or others make good steel cranks that aren't too expensive , another way to go would be a BBC I have a 408 ci 2 bolt that sees 6000 + rpm with a steel crank and is over 600 HP (on the motor) and has been hit with a 350HP plate with no issues .
Old Nov 15, 2006 | 05:45 PM
hollowcd's Avatar
How much is a SuperRam going to run me? Or, is there options out there that I can upgrade my TPI unit to have adequate flow?
Old Nov 16, 2006 | 12:18 AM
junkcltr's Avatar
Engine: 3xx ci tubo
You could also go with a Holley Stealth Ram, TPIS Mini-Ram, or a modified LT1 intake. I have a modified LT1 intake and I like it, but it is a fair amount of work to make it fit the older blocks.
You can still make 600HP with the TPI with the right compression and boost.
Old Nov 16, 2006 | 09:27 PM
hollowcd's Avatar
Intake Manifold
Is the intake Manifold that I have for my TPI the same Intake manifold that a SuperRam will bolt up to? Are the flow restrictions in the TPI or the manifold, or both??
Old Nov 16, 2006 | 09:38 PM
Drac0nic's Avatar
My thoughts on how to do your setup reliably; GM 1053 forged crank, a set of Powdered metal rods, some ARP studs in the main with a .030 bored block and TRW/Speed Pro L2441F pistons for 600fwhp. If you want to the wheels I"d get splayed billet caps or a 4 bolt block with studs and some H-beams. The L2441s are heavy slugs but they do work well, another set to look at if you use production type rods are the Probe Factory Replacement series they're as cheap as the TRWs but considerably lighter; however they are also press fit only for the pins where as the TRWs will work with a bushed type rod. With a 'charger, some Vortec heads and this setup 5-600fwhp should darn near be like shooting fish in a barrel.
codeysabatini
Nov 10, 2015 04:07 PM
Jorlain
Oct 8, 2015 01:57 AM
buckeyecelt
Sep 24, 2015 05:50 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
IROCZ1989
Sep 4, 2015 11:54 AM
