whats the max boost that a stock 350 engine could take?
Old Feb 11, 2007 | 10:52 PM
Superior Styles's Avatar
Car: 1986 CHEVY CAMARO IROC-Z
Engine: Twin Turbo 383 (1190hp 1249Tq)
Transmission: 1000 rated T56 6 speed manual
Axle/Gears: 3.73 Posi & mini spool & 28 spline
Whats the max boost that a stock 350 engine could take with to4e .57 twin turbo?
Old Feb 11, 2007 | 11:30 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
that depends on the 'stock' motor...
Cam, compression, heads, age, ect...
Old Feb 12, 2007 | 12:02 AM
IROC-You's Avatar
Car: 87 IROC-Z28
Engine: 414ci Twin Turbo
Axle/Gears: Ford 9"
https://www.thirdgen.org/forums/search.php?do=process
Old Feb 12, 2007 | 01:04 AM
GM Goodwrench 350ci / 260hp Engine
Specifications: 4 bolt main with 2 piece rear main seal
Cast iron crankshaft
LT1/LT4 powdered metal connecting rods
Cast pistons (dished)
Hydraulic flat tappet cam, (.383''/.401'') and a 112° lobe separation
Cast iron cylinder heads with 76cc chambers
8.5:1 compression ratio
Left hand dipstick
4 quart oil pan
8'' balancer
spark plug- Accel 111-574 with 14mm, .460'' reach, 5/8'' hex, tapered seat, projected tip
Old Feb 12, 2007 | 01:14 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's pretty abysmal. That low CR will tolerate a fair bit of boost, except for the cast pistons and tight ring gaps.
I'd stop at about 9psi or so.
Old Feb 12, 2007 | 07:00 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Everyone I talked to recommended against boosting that engine. That included Summit and engine shops. To do it right with that engine, you'd want to change the pistons/rings and the tiny cam too. But, by the time you change everything, you could've had a better engine built from the start.
Old Feb 12, 2007 | 12:48 PM
i just wanted to find out but i have made my block already forged crank forged pistons nitrous hp cam and blow thru 750 carb, h-beam rods and the whole engine is arp bolted and the to4e twin turbo setup intercooled with 3 inch exhaust all the way back
Old Feb 13, 2007 | 09:46 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
then why do you care what a " stock " 350 will handle?
Old Feb 13, 2007 | 11:05 AM
cause i want to know it does not hurt to ask does it!
Old Feb 13, 2007 | 05:54 PM
rmmstnr's Avatar
Car: 89 TA
Engine: 305 TBI
Axle/Gears: 10 bolt 3.08
perhaps it's for future reference, it doesn't hurt to learn. better to ask than to bomb an engine. beside, 9 psi isn't bad at all if you're just looking to put a little kick in a daily driver, although I'd be a bit more conservative myself for an added durability factor
Old Feb 13, 2007 | 05:56 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
No I suppose it doesn;t . I figured you had a stock setup and wanted to know thats all.
Old Feb 14, 2007 | 01:55 AM
http://www.cardomain.com/ride/2400581
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BBSDesigns
Aug 11, 2015 07:39 PM
