nitrous on a 305?
Old Apr 10, 2007 | 04:49 PM
scottyb123's Avatar
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
nitrous on a 305?
i was runnig this through my head and thought it was at least worth a try... is nitrous on a 305 even a consideration?.... with the right set up, is it plausable. i have the L69 which people say is a "high revving" engine, does this help the fact that it could handle n20?....if it can handle nitrous, what kind of shot?
Old Apr 10, 2007 | 05:30 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Re: nitrous on a 305?
Have a good fuel pump, WOT switch etc...
Small shot would be fine with the proper peices to make it work.
Check my sig for a 305 tpi with nitrous
Old Apr 10, 2007 | 07:35 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A NOS Powershot will work well (125hp) Install new Champion #RV8C spark plugs gapped at .035". Use the best gas available 92+ octane. CHeck and reduce the ignition timing to 32deg total at high rpm. Make sure the fuel pressure going to the Fuel solenoid is 5.5-6psi "flowing". Best way to achieve this is to install a small 1 to 1.5 gallon fuel cell under hood and using 3/8" fuel line, A Carter #4594 fuel pump and holley #12-803 fuel pressure regulator and a fuel pressure guage. You must set the regulator to 5.5-6psi by flowing the system.
Rig up the nitrous plate with an extended fuel line so you can flow the fuel thru the plate into a bucket and adjust the fuel pressure regulator to the required pressure.
Follow this setup and you're good to go.
For maximum performance try this Nitrous Friendly http://store.summitracing.com/partde...2&autoview=sku
Crane Cam set.
Old Apr 10, 2007 | 08:01 PM
Adrenaline91TA's Avatar
Car: 91' Pontiac Trans Am WS6
Engine: LB9 305ci V-8 TPI
Transmission: 4-Speed Automatic
nice setup LB9GTA... i have an LB9 also on my 305 TPI T/A.. mine has 121k miles on it.. so i was wondering if putting a new mild cam in... or replacing my headers with new ones... or what i should do with it basically..
Old May 8, 2007 | 01:08 PM
smoktire's Avatar
Car: 88 camaro
Engine: L69 305
Transmission: TH350 3000stall
L69 + 75HP shot on 3300Lbs car =
60' 1.73s
1/4 12.79s
mph 105
Old May 8, 2007 | 01:25 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I'd do it. Just run a WOT switch and a good fuel pump, you don't wanna run outta fuel. IMO, a WS is also necessary...
Old May 8, 2007 | 03:53 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
can some one tell me or show me what a window switch does? or what it is?
Old May 8, 2007 | 03:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Only allows nitrous to be used in a "window", of RPM.
Say from 2500RPM ->5500RPM or something. Usually you use a WOT switch, so you have to be at WOT, and then a window switch means it won't come on at idle sorta thing, but only after you have hit 2500RPM say, to help with traction, then kills it off before redline so you don't blow the motor. Ask LB9GTA about that one
Old May 8, 2007 | 08:31 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
When I was on my last run of the year, I was pumpin' n2o and i hit the rev limiter.
The n2o should shut off before it hits the rev limiter
Old May 9, 2007 | 12:56 PM
I got the window switch coming on right before the converter starts moving the truck and it kills the nitrous 100rpms before the shift points...
Old Oct 24, 2007 | 10:15 PM
firebird896's Avatar
Car: '89 GTA/'86 TA/98 TA
Engine: 350/350/LS1
Transmission: R4/T5/4L60E
Axle/Gears: 3.23/2.77/3.73
Of topic but what is a WOT switch????
Also what nitrous system would be the best to get with an automatic 700r4 car with a V8 TPI 305 LB9
Old Oct 26, 2007 | 09:24 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
WOT= wide open throttle, that means that the nitrous will only turn on once you hit wOT
I used a zex dry nitrous system. It was easy to install and cheap $/hp.
Old Oct 26, 2007 | 09:53 PM
Engine: 350/350/LS1
Zex?? What website or what store can I find this product at?
Old Oct 27, 2007 | 02:34 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I've thought about getting the NOS GM EFI (TPI) kit currently offered on Jegs. The one with the throttle body plate... has anyone here had any experience with that one?
(sorry, don't mean to thread jack...)
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
