off the shelf TT headers?
Old Jul 10, 2007 | 09:35 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I got a pair of GN turbos and am looking for a set of off the shelf headers that you have welded a turbo flange on the end to run them. I have heard 97 pickup truck headers flipped upside down, but was looking for pics or any other thoughts.
Old Jul 10, 2007 | 10:47 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: off the shelf TT headers?
yeah as far as i know the easiest way is to use the truck shorty's though from what i 've see, making you're own doesnt look too hard..i thought about doing some log style using these...should be easily done in an afternoon....
http://www.jegs.com/webapp/wcs/store...44797_-1_10607
Old Jul 10, 2007 | 10:54 PM
xpndbl3's Avatar
Car: 1984 Z28
Didn't really want to make the log style, guess I'll be leaning towards the truck shorty's just wondering which part number people used and some pics. Plus those header flange kits are the same price as the truck shorty's. Don't think the weight of the turbos will be a problem since I'm building support brackets off each cylinder head bolt holes to alleviate some of the stress of the turbo weight.
Old Jul 10, 2007 | 11:04 PM
Car: 91 z28
these s-10/blazer ones look like they would work good accept they only are 1 1/2 primaries
the 96-99 truck headers will work well, These ones from edelbrock look promising, though im sure you can call them and get them uncoated for cheaper thatn $300.
and these hedman shorties with 1 5/8 will work too they are $250
http://www.jegs.com/webapp/wcs/store...44779_-1_10605
Last edited by WheelsUp84z; Jul 10, 2007 at 11:08 PM. Reason: Automerged Doublepost
Old Jul 11, 2007 | 08:47 AM
firstfirebird's Avatar
I thought the Corvette shorties looked like they would work well...
https://www.thirdgen.org/forums/powe...gle-turbo.html
Old Jul 11, 2007 | 01:00 PM
xpndbl3's Avatar
Car: 1984 Z28
I wonder how the vette shorties would work in a TT setup. Not sure if there's enough space back there to run my downpipes off the turbos with those primaries in the way. I appreciate the ideas though, turbomustang.com didn't have much in the way of suggestions either.
Old Jul 11, 2007 | 02:02 PM
Yeah, I see what you are saying now, the pass side looks good, but the driver's side would be a bit tight. junkcltr modified the stock manifolds to have the turbos at the front of each bank.
If I were you, I would just modify the headers you have to work, you could actually make the flanges in post#2 by cutting them and using the left over primary tubes.
Old Jul 11, 2007 | 02:06 PM
xpndbl3's Avatar
Car: 1984 Z28
Actually the headers I have now are going to buddy in exchange for letting me use his lift during this swap at his shop for a bit this winter. I can't think of anyone on these boards that has a TT setup that could answer this for me, I am keeping my non-A/C box as well, so some space back on the firewall will be used up for that.
Old Jul 11, 2007 | 02:16 PM
ttypecamaro, junkcltr are two that I have had quite a few conversations with and can think of off the top of my head. There are at least three more that i have seen here in the pwoer adder forum. trbo355, and a few others...
https://www.thirdgen.org/forums/sear...archid=1085218
They fixed the search!!
Old Jul 11, 2007 | 07:32 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I posted a few links for ya over on TM.com
That vette meader seup up was mine. posted above.
Old Jul 11, 2007 | 07:46 PM
I used to have a bunch of your pics that you PM'd me. My welds on mild are looking that good now. What SS did you use, 304, 316 etc?
Old Jul 13, 2007 | 11:13 PM
rob_m's Avatar
What size primaries? Has anyone tried to see if they hit the motor mounts if flipped side to side? They look good if they miss the motor mounts.......
Old Jul 13, 2007 | 11:37 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
...Just something to consider ....
I am by means no authority on turbo's , etc . But to me getting off the shelf headers and converting them to twin turbo manifolds sounds like it's doomed to fail.... the thickness of the pipeing isn't enough ...just my $0.02.
Anyone ?
Old Jul 14, 2007 | 12:09 AM
Anyone ?
Yes and no. With N/A headers, you can get away with thinner walls, along with using less expensive 304 SS. True. However, as long as the turbos are supported properly, they are going to be less likely to crack.
Old Jul 2, 2008 | 11:02 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
if you guys are still interested in those 96-97 truck headers on 3rd gen, i have Gibson short headers on my 97 silverado that i can test on my 90 vert and take some pics .
Old Jul 3, 2008 | 12:56 PM
Car: 91 z28
holy old thread, batman! He's already got his setup now.
Rousseau92maro
Feb 1, 2016 05:12 PM
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Pinguiclia
Oct 12, 2015 04:47 PM
Bradsaundry
Oct 7, 2015 04:35 PM
