single turbo setup being built, couple of questions
Old Sep 24, 2007 | 08:34 AM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
hi, im currently in the middle of building my first turbo setup....
89 formula, using ebayT70 , have the headers, and have the pipes to the merge collector which are 2.5", one of my questions is should the size after the collector be 3" or stay at 2.5" to keep up velocity?
also what size should the cold side plumbing be? i would guess 3"???
another thing is i was considering a water to air intercooler because of the lack of air flow in my front bumper area.(dont really wanna cut the bumper all up)
could anyone inform me on the necessary items for the W2A intercooler like water lines, resevior, is there a pump involved?
down pipe is 3"for about 16-18" then opens to 3.5",
probably not going to use any muffler...does this sound sufficient for this level of build?
thanks in advance, Keith
Old Sep 24, 2007 | 11:37 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: single turbo setup being built, couple of questions
Hey, good luck with the build. 2.5" is fine for after the collectors, i'd leave it at that. Most people run 2.5" or 3" for the cold side. I made my choice based off the turbo & intercooler inlet/outets, both were 2.5" for me. How much boost are you planning to run and what is you power goal? The downpipe should be ok as long as it's mandrel bent all the way back, but it might become a restriction if you're looking to get big power numbers. What does the rest of your system consist of? engine, fuel, etc...
Old Sep 24, 2007 | 07:31 PM
Car: 91 camaro rs
right now i am mocking it up/fabbing it around a TPI 305, i probably wont even run it on the motor at all.
I am trying to decide on the motor, it will be a 350, probably not stroked, just a 355, but i have a "010" 4-bolt main block w/ a standard bore, but i also have a 1-piece rear main seal, roller cam, 2-bolt main block...that i would like to have splayed 4-bolt main caps put onto..... BUTT the block is already bored .030 over and not crazy about starting an engine build with more overbore than that.
either way it'll be TPI, i have a 58mm holley TB, hyd roller cam, was thinking of one of the XFI cams- 113LSA...
i would like to try Megasquirt i think, but may spend the extra money and get a holley commander or FAST setup.
8.5-8.75:1compression ratio,
would like to make around 500RWHP,
im guessing i'd run anywheres between 12 and 18PSI...
i am definitely willing to swap a more efficient, better suited turbo in place of the 62mm in order to reach this goal.
fuel system is all aeromotive, new in boxes, A1000 pump, aeromotive filter, aeromotive 5 port boost referenced regulator, -10AN feed and return...
my fuel system was originally bought for a blow through carb setup, i was told that the regulator might not work for EFI, i believe the part number is 13202.
I dont have injectors yet. have to look more into sizing, possibly 44, or 50lb/hr...
what are the cheapest injectors available and where to buy them?
my down pipe isnt 100% done yet, i am waiting on a v-band clamp and another 45* bend, but it is mostly there, tacked together, and it is going to dump around the trans. crossmember, with no muffler(unless its wayyy to loud, i'll run a bullet or something)
calebzman, how much HP / FT/LBs do you make with your setup?
any 1/4 mile times?
Old Sep 24, 2007 | 08:46 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
This really isn't on topic for the turbo, but after all the fantastic experiences I've had with RBobs EBL I'm going to recommend it. He has a version of the EBL that is flash capable and will run a port fuel setup for around $400.
Excellent support, excellent tuning advice and he's a nice guy to boot.
ok rant off...
Old Sep 25, 2007 | 05:30 PM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Looks like you have a good idea of what you have to do. I started off with just the open exhaust, but it was too loud for me. I added a magnaflow straight-thru muffler and I'm really happy with the sound now. In a couple weeks I'm taking mine to a dyno to get it tuned, so I'll be able to find out how much power it's putting out pretty soon.
Old Sep 25, 2007 | 10:03 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Is that Ebay T70 the classic 60mm comp. wheel inducer diameter? How long is the pipe after the merge? I would tend to use 3" pipe after the merge....but I always error on the large size when it comes to turbo piping.
For the cold pipes either run the same size out of the compressor or a little larger. I usually go a bit larger. 3" would be fine.
The water to air setup depends on how long you need it to cool for. How big the tank is, etc. It is going to be loud without a muffler.
Old Oct 16, 2007 | 10:31 PM
Car: 91 camaro rs
I am in the process of moving my car to a friends garage for the winter so I can continue the turbo build....
going to try hard to post pics, my camera's broke so i gotta get a new one or borrow one..
Old Oct 16, 2007 | 10:36 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I'm just curious about "turbo'ing" a TPI .... If the stock system runs out of breath naturally aspirated how do they do when you force even more air through them?
Old Oct 16, 2007 | 10:54 PM
Car: 91 camaro rs
I cant really tell you how or why it works so well with forced induction, it just does...
http://www.theturboforums.com/smf/in...19.0;topicseen
low 9's @ 150mph, somethings workin.
theres quite a few other successful Turbo TPI builds out there too.
Old Oct 16, 2007 | 11:32 PM
junkcltr's Avatar
Engine: 3xx ci tubo
What is the comp. wheel diameter at the inlet of that T70?
Old Oct 17, 2007 | 03:26 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
seems like all the questions have been answered accept the IC. SO here ya go:
Parts needed:
A2W IC
water/ice res. ( i recommend 5-7 gallons for street)
water pump (meziere or stock one off lightning or cobra)
lines/fittings
heat exchanger, (afco or a stock one off a lightning or cobra)
also whats the PN on the regulator you have?
Old Oct 29, 2007 | 04:21 PM
Car: 91 camaro rs
Thanks for the W2A IC info,
the wheel is only 60.5mm, and T3 Flange, Better suited for a Syclone or something...
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 13, 2015 08:28 PM
