its finished.
Old Jun 17, 2008 | 06:59 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
its finished.
Old Jun 17, 2008 | 07:14 PM
Tony_B972's Avatar
Car: 86 IROC
Engine: 383 (in progress)
Transmission: tko 600
Re: its finished.
A work of art, any numbers?
Old Jun 17, 2008 | 08:42 PM
fallenleader's Avatar
Car: 1984 firebird
Engine: 2.8 v6
Axle/Gears: soon: A working car.
Re: its finished.
whats the thing on your intake?
Its a turbo? but the red thing.
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
Re: its finished.
Its a super charger and the red thing is a blow off valve.
Sure is purty! nice job
Old Jun 17, 2008 | 08:46 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Re: its finished.
Looks bad man i also want to see wat numbers that beast is putting down!
kevin
Old Jun 17, 2008 | 08:51 PM
Car: 1984 firebird
Engine: 2.8 v6
Re: its finished.
stupid me, used to the super sitting directly ontop. didn't know they had blow offs either. "yay for my V6 and lack of knowledge"....
Thank you.
Old Jun 17, 2008 | 09:09 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: its finished.
I like it
Time to change the sig from "I WANNA GO FAST!" to "I'AM TO G0D DAMN FAST"
Old Jun 17, 2008 | 09:13 PM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
Re: its finished.
Wow how much horsepower are we talking here? Damn that looks good!
Old Jun 18, 2008 | 02:24 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: its finished.
No dyno yet, need to do some fuel upgrades to take full use of the engine, I estimate anywhere from 600-800 rwhp
if you have the correct player, you can see an idling video here
www.camaroalley.net/traviz/iroc.3gp
Old Jun 18, 2008 | 10:04 AM
Re: its finished.
lol thats awsome! So what is this car to you do you race it, show car, weekend driver? I wish my car sounded like that!
kevin
Old Jun 19, 2008 | 11:08 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: its finished.
One question from the peanut gallery here - how do you mate the carb hat to the carb? I'm just seeing the stud coming out of the carb, and the wingnut - but how do you get a good airtight seal there? Snug fit around the stud, and an o-ring or something?
Wow, you're really hoping for a lot of HP! Best of luck to you!
Old Jun 19, 2008 | 12:17 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: its finished.
my car has an o-ring around the carb hat and the carb
Old Jun 20, 2008 | 08:52 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Re: its finished.
Might want to consider water injection to keep detonation down...
Old Jun 20, 2008 | 09:50 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: its finished.
Sounds freaking awesome! Can only imagine the first victim's expression after running into that out on the street....
Old Jun 20, 2008 | 10:23 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: its finished.
Been waiting a long time to see this thing. There wasnt any hype about it, didnt seem like many people knew, but the word got out here and there.
Congrats!
It doesnt look like it should fit in there, do you have any pix from further back?
Old Jun 20, 2008 | 12:30 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: its finished.
i plan on it
online170, I will put up more pics tomorrow if you desire, but I warn you, the car is not painted yet.
Old Jun 20, 2008 | 01:29 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: its finished.
How's your turbo setup coming?
Old Jun 20, 2008 | 02:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: its finished.
ah, ok. Customized the carb for the o-ring? Same with the hat?
What about the hole for the stud? o-ringed as well?
Old Jun 20, 2008 | 02:24 PM
tpi user's Avatar
Re: its finished.
with methanol inj an some good gas an tunin 600 rwhp shouldnt be much of a problem at all.intercooler an boost now ur talkin 700 plus
Old Jun 20, 2008 | 06:35 PM
xpndbl3's Avatar
Car: 1984 Z28
Re: its finished.
slowly....been working lots of hours and building cars for other people who pay me, so mine is sitting for a bit.
the hat has the o-ring provision, remember a proform carb has a smooth mating surface already for the o-ring to seal. The hole for the stud has a washer and is cut out slightly, that requires no gasket, etc.
Old Jun 20, 2008 | 07:08 PM
Outlaw28's Avatar
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
Re: its finished.
where did you get that setup?? what brand of supercharger is that??? curious...cuz in the future i want to do something similar to my z28
Old Jun 20, 2008 | 11:44 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: its finished.
i plan on it
No worries, neither is mine.
Im just curious to see it from afar. By the looks of it, it was a tight fit, and you did a flawless job.
Old Jun 21, 2008 | 12:21 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Re: its finished.
the hardest part was running an intake elbow to the blower for my air filter, and my brake lines being in the way, im still working that out, as you can see from the pic, no master cylinder to be seen.
Old Jun 21, 2008 | 01:06 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Re: its finished.
They make mini-master cylinders that will bolt up, but you'll most likely have to re-make / bend new hard lines.
Old Jun 21, 2008 | 01:40 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: its finished.
i plan on it
Ha, I'm in the same boat, half my car is faded. The back looks like someone painted it in the rain. People come over to check it out, and like eh? Then I pop the hood. Duuuuuuuuuuuuuuuuddee.
snowflake
Oct 19, 2015 10:24 PM
sandman92084
Sep 12, 2015 10:27 PM
spartyon
Carburetors
77
Aug 21, 2004 01:06 PM
Timz2882
Apr 13, 2004 10:00 PM
90tararebird
Apr 4, 2004 07:27 PM
