some partially fabbed hotside pics, and few others
Old Feb 3, 2009 | 03:30 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
Old Feb 3, 2009 | 03:33 PM
Car: 91 camaro rs
Re: some partially fabbed hotside pics, and few others
this is my summertime daily driver, runs 13.1 @105 with a terrible 60' and gets around 21mpg:
Old Feb 3, 2009 | 03:38 PM
Car: 91 camaro rs
im using a Turbonetics TC-78(.96 a/r t4), on a 355.
50mm jgs wg
56mm jgs bov
1 3/4" f-body hooker headers
2 1/2" crossover
3" to turbine
afr195cc heads
vic jr.
csu 750
comp cams hyd roller around .575" 224 duration
aeromtive fuel system w/ A1000
msd 6al btm and msd pro billet dist.
th350
3800ish stall
3.23s w/ mini spool for now
looking to make 650-700 crank hp, seeing 80+% street use, hope to run 10.99@130 on 15-18psi (3500lbs)
Old Feb 3, 2009 | 04:34 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Take it easy man, your going to wake the dead....
Old Feb 4, 2009 | 07:47 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Nice, I like how it's all mandrel bent tubing and the way you used standard facing headers. Do you have your downpipe fabricated yet? Also, have you thought about moving the air dam forward so that it's flush with the front of the intercooler? It looks like it would direct the incoming air better that way.
Old Feb 4, 2009 | 06:15 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
peeped this n the turbo forums....nice build...im startin mine in a few weeks...
Old Feb 4, 2009 | 08:11 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
Hey i really love the build. can you post up some more pics of you cell and fuel system?
Old Feb 5, 2009 | 03:20 PM
Car: 91 camaro rs
i have not had any real issues with overheating yet with the intercooler like that but i think i will move it forward a little bit to allow air up into the radiator also. we'll see ive only got about 20-30miles on the car with the "old" turbo setup...
i dont think i have many pics of the fuel system other then whats on here i can try and get some... its the aeromotive 'blowthru' system...a1000, boost ref. fuel press.reg., etc...
its a 16 gallon plastic cell, sumped with a -10an outlet, i made a "frame" to cradle the cell out of 1/2x1/2" and 1x1" square tube. it was a pain. and took along time..if i had to do it again i probably would have paid for a sumped stock style tank. my cell is held in really solid, and doesnt hang low or anything, but as far as making it legal for track tech inspection is a pain in the neck, ive got to make ahinged sheet metal cover for it or something........
Old Feb 8, 2009 | 12:18 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Looks good! Where are you going to run that downpipe and what size?
Old Feb 10, 2009 | 06:54 AM
Car: 91 camaro rs
im going to make a half circle notch in the firewall behind the passneger side header collector. and its going to be 3 1/2", i'll probably use a single 3 1/2" bullet muffler right about where the factory cat was and then head towards the rear along the driveshaft and most likely dump it at the axle. that the plan anyways..
Old Feb 12, 2009 | 10:02 AM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Looks good. I want your turbo! Want to trade, mines good for 10.7's. haha j/k. Nice work. As far as the airdam goes, mines in the stock location and my intercooler is exactly where yours is and it works fine. When i make a pass, i can feel one side of the intercooler is hot and the other is cold, so air flows thro for sure.
Old Feb 14, 2009 | 09:57 AM
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
looks wicked man! those gears should complment the boost pretty well should need to go much lower. u gonna throw some alchy on it too?
Old Feb 14, 2009 | 05:20 PM
Car: 91 camaro rs
um, maybe some water/meth/alky injection... moneys tight, works slowed down alotttt... i have an old Nitrous Express wet nitrous kit i was thinking of converting/fabbing into a intercooler spray bar kit just for the track, but im not sure...
also dont know what exactly im doing for a shortblock, i really wanted to run a built motor this year but i cant afford it right now and didnt wanna half-*** it, so i may just throw another stock short block in it with some steel head gaskets and my small turbo cam and keep the boost conservative...
Old Feb 14, 2009 | 05:57 PM
hey gotta run what you can, i here ya on shlt being slow. this time last year i was thinking id have my new short block together and running boost by about now. a nitrous cooled intercooler cant be to hard to fab at home.
honestly i think you can get away with some good numbers on a stock mild rebuild with some good pistons and flow. make that turbo do the work.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
83RDRACR
Mar 26, 2016 08:13 PM
!CamaroDave
Convertibles
Sep 17, 2015 12:53 AM
Mongoose462ci
Sep 16, 2015 11:46 PM
Cleotiz
Sep 16, 2015 08:02 AM
