1989 Iroc with 350 tpi and Paxton issues
Old 02-16-2009, 12:11 PM
614Streets's Avatar
I just purchased a 1989 Iroc from the Family of the now deceased owner. I know little about the history of the engine or the tuning.
The engine appears to be a reman block from aarons automotive in MO , there is a tag on the side of the block with a serial number.
The heads are edelbrocks , the intake has non oem runners , car has headers and exhaust , car has a cam , holley throttle body , paxton sn 2000 blower , red injectors and a billet rail with adj regulator.
The problem is the car runs extremely rich once warm and the idle rises from the blower pushing the throttle blades open? Car came with a new grantelli adj mass air and a shop bill of sale saying it needs installed along with two vacuum canisters for the brakes?
Something is not right because the engine does not pull vacuum at idle , its right at 0 hg or even pos pressure?
I am going to take pics and come back with more information.
Whats the deal with this supercharger system doing this?
Old 02-16-2009, 08:52 PM
614Streets's Avatar
Re: 1989 Iroc with 350 tpi and Paxton issues
N/m I think I got most of the issues solved today.
Old 02-16-2009, 10:11 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
How did you fix it? I am in the proses of installing a sn2k.
Old 02-20-2009, 01:25 PM
614Streets's Avatar
Well for now as a crutch I installed the adjustable mass air that came with the car , was in the backseat new in a box, and that helped it from running so rich and picked up power but it still needs tuned. I am guessing PROM and wideband.
What is the normal thing to do , is it worth sticking with mass air?
Old 02-20-2009, 03:23 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
What most ppl do is switch to MAP, and learn to tune. Steep learning curve there. I think I will be doing the same as you. Ajustable maf, and a fmu. Did you run a second pump and the meth injection?
Old 02-20-2009, 03:24 PM
scribbles's Avatar
Car: 88 gta
Engine: 350 tpi
Also get a af reader, even if it is a cheap one that will conect to your NB-O2.
bellez77
09-05-2015 08:39 PM
kyleb24
08-15-2015 08:24 AM
BewleyBizzIROC
08-14-2015 02:52 AM
wruiz
08-13-2015 09:07 PM
gta power
08-13-2015 06:15 AM
Quick Reply: 1989 Iroc with 350 tpi and Paxton issues
