turbo????
Old Mar 31, 2009 | 09:17 PM
1983z5speed's Avatar
turbo????
so here is the deal. i have an 83 camaro with a 5 speed and a mild built 305. i have a 81 datsun parts car with a turbo. and yup you guessed it i want to put the turbo off the datsun on the camaro. is this hard? or even possible? if so is it worth all the work? how much work would need done and what parts do i need? i have never messed with a turbo before. people at my school love my car and everyone said i should find away to do it and of course who wouldnt want more power haha. thanks for the help
Old Mar 31, 2009 | 09:58 PM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: turbo????
try the research button lol....im gonna say the turbo from a datsun is WAY to small, doesnt it come with like a 3.0L?
Jay
Old Mar 31, 2009 | 10:12 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
Re: turbo????
too small, two of em might work....
Old Apr 1, 2009 | 10:23 AM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
Re: turbo????
is it hard for you? YES
possible? YES
Worth it? NO
if u have no prior exp with any turbo or even know how they work, dont mess with it.
build u a strong 350ci motor with vortec or better heads.
Old Apr 1, 2009 | 03:30 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: turbo????
You have a turbo from a tiny Datsun engine, yup you guessed it, you need 2 or more of them turbos for your 305ci. Is it worth the work? You have to ask yourself........do you want to go fast? That will determine if it is worth it or not.
Old Apr 1, 2009 | 03:56 PM
Car: 02 SS
Re: turbo????
negative
not even a pair of trim toyota ct26 will be enuff to feed a stock 305
those are some of the best oem turbos. perhaps a pair of trim GN turbos will work.
if u want to work with a good oem turbo, the holsets of cummins work. but not the wg'd vband versions.
look for the t4 remote wg of 94-97 5.9 cummins
Old Apr 1, 2009 | 05:34 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Re: turbo????
Originally Posted by NemeSS-TyranT
negative
Woohoo. It looks like we have an expert giving info. here now. Welcome. Please share about these great Holset/Cummins HX35 turbos you speak of.
Old Apr 2, 2009 | 02:01 PM
Car: 02 SS
Re: turbo????
im no expert, but i have around 11 yrs. of turbo diesel engine repair and assembly. the H1E holset turbos will support around 500bhp on gas engine. a pair of GN turbos will support around 400bhp on v8 engine.
the H1E is t4 non wg with with 22 cm exhaust turbine, its a/r is around 1.00.
with a holset h1e my 95 355 z28 lt1 with stock heads, intake and manifold single turbo made 415rwhp without tune, and fmu. stock opti, with msd wires and coil. thru m6
and that was in like 99'
dam! been a while. i dynoed at some bigtime import place in town at the time the had a new dynojet chassis dyno
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
