ntirous works TPI plate with NOS Powershot solenoids?
Old Jan 18, 2010 | 09:51 AM
ChevelleFan's Avatar
Car: '70 Chevelle, '63 Corvette
Engine: 383, 327
Transmission: B&M 700r4, Muncie M-21
All,
I have an older NOS Powershot 125hp plate kit for a Holley 4 barrel. The solenoids are in good condition and seem to work fine on the bench. I have since upgraded to an HSR, so obviously my nitrous kit won't work.
Can I buy this plate, http://cgi.ebay.com/ebaymotors/Nitro...item53daf3e25e
and plumb it up with the solenoids/bottle from my old Powershot?
Is there any reason why this shouldn't work?
-Dave
Old Jan 18, 2010 | 10:02 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: ntirous works TPI plate with NOS Powershot solenoids?
As long as the an fittings are the same i see no reason why not.
Old Jan 29, 2010 | 09:28 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
it will work.
if your checking your solenoids put NOS to them, and let it sit for 5 min.
see if you get frost anyplase, frost = leak.. from dirt/dust/sitting.
the Nos leaking anyplace that it can get into your intake is the backfire King...
this is only a prob when you let the bottle sit open, set to run, and you leav it there,.. always shut the bottles down, when your not using them.
and if you have a purge. use it, to take the presher off..when done..
Old Jan 29, 2010 | 05:42 PM
Engine: 383, 327
Thanks for the tips, I'll check for leaks when I get it all together. Not really planning on running a purge right now.
As for taking the pressure off without a purge, I could close the bottle valve first, and then with the engine running, I could tap the button once or twice (giving me a rich stumble, I'm sure) and that should sufficiently remove the pressure? I'm talking about once I'm gonna leave the track and head home.
-Dave
Old Jan 29, 2010 | 06:07 PM
ya, turn bottle off, and hit it on freeway.. is fine
Old Jan 30, 2010 | 03:50 AM
2002chad's Avatar
Car: 1989 GTA
Axle/Gears: 9 bolt
Horrible idea. Running rich can be just as bad if not worse than running lean. If you want to dump the pressure just loosen the line from the bottle.
Old Jan 30, 2010 | 03:55 AM
it takes less then a tap on the Button to let the presher out..
sky will not fall..
starting your car up to drive it to work, is harder on it then tapping the Button.
this is why i use a purge Kit... takes all the work out of it.
all you need to Buy is 1 SMALL solenoid. dont need to buy a kit.
just a solenoid and a T fitting.. switch & wire it up to a button..
Old Jan 30, 2010 | 04:20 AM
2002chad's Avatar
Car: 1989 GTA
Axle/Gears: 9 bolt
sky will not fall..
Just keep in mind. With the pissant little shot you are running combine that with 1000+ psi bottle pressure and the length of line you are have. It is going to take more than "just a tap" to empty the line. I do agree with him with the purge kit tho. If you are going to do it, why not do it right?
But do what you want, it's your car.
Old Jan 30, 2010 | 04:39 AM
in any case.. you dont want it leaking into your intake when it's not running.. IF IT LEAKS AT ALL!
the only time iv seen them leak.
is when guys mess with them. or the parts are used up/dirty from sitting.
if it's dirty.. its a easy fix.. they also sell Kits to redo them..
you would not think Guys would just let the things set with 900+ psi in the lines for Hrs.(but they do). that could be a roll of the Dice... on start up you would fined out right away.. if it was leaking
i run a guage so i know whats in my line.
(i run a full on sports men Fogger)and have for years.. in this new redo i will have to go in and out of every part.. to make sure it works 110% right
no Leakes.. mine are easy to see.. it frost Right Up... pull coil wire and turn over for a 10 to 15 sec.. your fine..
Old Jan 30, 2010 | 12:39 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I run Nitrous express solenoids with a NOS tpi plate.
Old Feb 15, 2010 | 11:07 PM
5.0 Eater's Avatar
Car: 1989 IROC-Z
Engine: 383 waiting on afr 195 comps
Axle/Gears: 3.42 Posi
Quick question for you guys than run those plates. Will they work with a 58mm tb.
Old Feb 24, 2010 | 07:52 PM
2002chad's Avatar
Car: 1989 GTA
Axle/Gears: 9 bolt
i hope you slapped the guy that installed the nitrous and fuel gauges. the line routing looks like shlt.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
mhatfield 14
Oct 24, 2015 07:48 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
