spraying 100 or 150 shot Timing???
Old Mar 12, 2010 | 08:06 PM
1b rock's Avatar
Transmission: a4
im spraying my 90 350tpi with a 5151kit...
its a 100 or 150 shot and was wondering if i need to adjust the timing when i do so.....
also what kind of gains should i see in the 1/8th
car is stock with headers and runs 8.80 in 1/8th now
just wondering
Old Mar 12, 2010 | 08:22 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: spraying 100 or 150 shot Timing???
they say 2 deg for every 50hp. the timing will likely retard itself. this is a wet kit correct? i hope the engine is up to the task. 8.8 is pretty good, what mph?
Old Mar 12, 2010 | 09:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
whats your timeslip like now? 60 foot 330, and 1/8 trap speed?
100 shot i'd start with around 4-6 degrees pulled and keep air fuel ratio in the mid 11's if you can. THen add timing back in slowly to see if it can tolerate just 2-3 degrees pulled.
Same with the 150, pull 6-8 and add in timing to see if it handles it. I"d advise on a scanner and a wideband to monitor all this to see whats going on.
Gap the plugs tighter and maybe run a step colder on the heat range.
Should really pick up tho with a 150 shot. My 383 ran 6.76 at 102 in the 1/8 with a 150 shot. Was running in the 7.3's at 93 n/a.
You probably willl pick up more going from an 8.80 to around a 8.0-8.2 or so with a good 7-8mph gain on a 150 kick. Just a guess
Old Mar 13, 2010 | 11:48 AM
83 Crossfire TA's Avatar
2*/50 is the standard deal.
FWIW, you loose _much_ less power retarding timing on spray than you do NA so if in doubt run it on the safe side, because unlike NA, where a little detonation usually doesn't hurt much, with decent sized N2O hits a little detonation could mean carrying the engine home in a bucket.
Old Mar 13, 2010 | 12:21 PM
joe2844's Avatar
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
i have the same kit on my 88 tpi 350. with a stock converter, 3.73 gears, a locker, nitto drag radials, and spraying a 100 hp shot with the timing @ 0* (imo the base timing on these cars doesnt really matter as long as its close to 0* bc the computer is gonna do what it wants with it based on what the knock sensor is telling it) my car ran 8.90's on just motor and traction limited 8.20's with the n20. i spray right off the line and hold it till the end. my 60ft times are high (2.2 on motor, 2.0 on n20) bc my track just opened and they dont treat it for t&t. as for mph 80 mph on motor and 90 on spray. hopefully as the track gets better throughout the summer i will be able to hook better and drop a tenth or 2 off my times.
Old Mar 13, 2010 | 10:54 PM
1b rock's Avatar
Transmission: a4
the best was 8.70s on motor was goin tomorrow but rained the track out so after a week of anticipation i guess its back to drawing board this week there open next saturday so we ll see i just bought a set of 255/50/60 bfg drag radials and put them on my irocs so ill see how well it hooks planning on gettin a 2800-3200 converter and maybe ditching the 3.23s i paint so ill have to do some swaping and come across a few after hour jobs to get some more goodys
Old Mar 14, 2010 | 01:27 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
IF it stalls near 3200 on the spray, it should leave in the 1.6's 60 foot if it hooks. Its gonna come off the line hard! My bolt on L98 ran 1.71s with a 2800 stall so nitrous would easily gain a tenth
Old Mar 14, 2010 | 06:19 PM
1b rock's Avatar
Transmission: a4
that would sure be a nice sleeper in a world of ls1s most people around here dont even pay much attention to these cars since they are old tech that is till it runs down the track against a newer ls1 ive had ls1cars,lt1cars two thirdgens and even a 69 camaro in my life and i have to admit i didnt respect the tpi cars till i bought this one... its been a blast and i sure do like it it has suprised several of my buddys mustangs and i hope to keep that up i would like to later down the road do a 6.0 swap but we will have to see.....
Old Mar 15, 2010 | 02:21 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
I agree with the 2*/50 timing retard. I went 1 step colder on the plugs also, gapped at .030 Pulled 6*, ran a 150 shot more times than I could even attempt to count with no problems.
Old Mar 15, 2010 | 03:40 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If you ever upgrade to a different motor with good heads you can get away with only a few degrees pulled with a 150 shot. My 383 made best power on motor at 34 deg timing and on 150 shot juice I ran 32 deg with a air fuel in the mid high 11's to 1. Best to start out lower and bring it in slowly only if the motor can take it.
Old Mar 15, 2010 | 05:09 PM
running the 150 shot I had mine at 30* total with a/f at 12.0-12.1
Old Mar 19, 2010 | 05:58 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
just from my personal experience on my 305 car, i ran a 100 wet shot through a spray nozzle in the intake all i did was put in some r42ts AC delco plugs and 91 (best i can get out of the pump here) and ran it. plug looked good, timing mark was right to the bend on the strap. personally i would pull 2 degrees and read the plug and see where to go from there
Old Mar 20, 2010 | 08:48 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I would say if the car is stock he could run premium gas and pull no timing. Just throw in some colder plugs. The NOS 150 kits could be ran with no timing pulled. But if the car has a chip or base timing has been advanced then yes you will have to pull timing.
Old Apr 25, 2010 | 04:24 PM
singledad1972's Avatar
adjust timing back 2 degrees every 50 shoot
Old Apr 27, 2010 | 02:15 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
PRIMARY QUESTION, do you have an aftermarket chip? What's your base timing set at right now with the EST unplugged?
92camaroJoe
Jul 29, 2023 07:57 PM
customblackbird
Aug 15, 2021 10:16 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
92camaroJoe
Aug 13, 2015 06:07 AM
