anyone running a procharger with carb setup?
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Axle/Gears: 3.73 posi
i was looking at s/c my 383 stroke once i start to get to working on the motor, i searched and i was looking what everyone is using to run this setup on their cars.I plan to run 8-10 psi with my car so i know some things will need to be beefed up. some help getting started would be great thanks.
Car: 1982 z28
Engine: 383
Transmission: 4l60e
Re: anyone running a procharger with carb setup?
ill be running alt and ps and maybe water pump unless i which it out for an electric pump also i was looking at the march performance serp belt system.
Don't waste your money on the March pulley system. It won't work with the ProCharger system. Your best bet would be to go with ProCharger's Carb Chevy system and use ProCharger's repositioner bracket. (To lower the blower bracket a bit.) Give Larry @ ASSC a call and get you set up pretty nicely. (847) 838-0393 He may have some other suggestions for you as well.
Car: 1982 z28
Engine: 383
Transmission: 4l60e
ok kool thanks ill look in to that. it dosent realy say much on there site what to run or what not
As far as blower size? Larry, myself, or some of the people here on this site can help you with that, but we'll need some more info about your engine and your goals. Right now, I'd suggest a D1SC.
Car: 1982 z28
Engine: 383
Transmission: 4l60e
i have a 383 stroker 4 bolt main, as fas as i know it has flat top pistons and factory heads that are ported the cast number is #3998920, right now it has a holley intake which im planning to change out and i have a holley 650 dbl pumper with manul choke. i dont know what it has for a cam until i pull it out and check the specs all i know its a hydr flat tappet cam which i plan to change out for a roller cam, i would like to make about 500 hp at the motor and maybe alil less to the rear wheels i was looking at the procharger p-1sc intercooled kit they had. what other things should i do with my enigne.
A P1SC should be able to get you to that HP number, but a D1SC would do it easier. As far as the engine goes, that's a pretty broad question with no 1 right answer. My only suggestion would be to put a set of forged pistons in it.
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Well i just had our local performance shop order my D1SC kit for blow-thru carb application on my 92RS. I shold have it in less than 2 weeks.
I know i'm gonna need a different carb but right now im using a 750 on my 383. How well does your 383 do with a 650 on it?
I switched to an elec W/P and have manual steering, so i'm only spinning an Alt off of my crank.
If i were you i would definitely go with the D1SC.
Car: 1982 z28
Engine: 383
Transmission: 4l60e
my 383 with the 650 seems to run ok from the lil time i got to drive it around it was just a pain on start up cause its manual choke and im not use to it, i think i may go with the D1SC for my car, i plan to run elec water pump but i wanna keep my power steering since ill be driving the car alot and using it for auto-x too, whats all done to ur 383.
Car: 92RS
Transmission: TH350
My 383 has all forged internals, AFR 210 heads, NX288HR Comp Cam, All MSD ignition system, Super Victor Intake, Demon 750 (for now, will upgrade for D1SC), Hooker 1 3/4 full length headers.
It ran an 11.85 once i put in the new blower cam. Everybody says i will get into the 10's easily with a D1SC, maybe even high 9's if i really put some boost in it and "good" gas. I plan on running 91 from the pump since i will street drive this car quite a bit.
Car: 92RS
Transmission: TH350
Well here's what mine looks like as of today. My best friend took on the task of polishing my brackets so i've been waiting a few weeks (well worth it).
theshackle
Mar 5, 2017 06:37 PM
86IROC112
Aug 17, 2015 02:00 PM
