Supercharging with unforged internals
Old Jan 23, 2011 | 11:26 PM
viper23's Avatar
Car: 92 Camaro rs
Engine: Edelbrock 350
Transmission: TH 350
Axle/Gears: 373
Hello i have a 92 camaro with a carbuerated 350bored 30 over engine and was wondering if i could use a weiand supercharger without having to change to forged internals. Thanks for any help.
Old Jan 23, 2011 | 11:31 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Supercharging with unforged internals
you can, but if your tune is not PERFECT your going to hurt your motor. It's all in the tune, and with cast internals there is very little room for error
Old Jan 23, 2011 | 11:43 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Low boost or a good tune on 6-7 PSI is possible with a stock bottom end. I'd suggest at least moly rings and if it was me I'd do rings and pistons.
The rings are usually the first things to go when you fight a mild case of detonation.
Old Jan 24, 2011 | 12:59 AM
tjl IROC's Avatar
Car: too many
Engine: SBC
Transmission: AUTOs and a 5 speed :D
Axle/Gears: you name it
I've been running a 142 supercharger with low boost for years on a stock motor.
I don't know how much boost I'm running running the pulley that came with the kit from summit.
Old Jan 24, 2011 | 08:25 AM
jhiggins9625's Avatar
Car: 1992 RS
Engine: 98 vortec 350 edelbrock proflo efi
Transmission: 700r4 B&M kit
Axle/Gears: 3:73 lim/slip
Good rule of thumb is not to go over 500hp on a stock small block bottom end.
Old Jan 24, 2011 | 03:18 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
thats crank horsepower not wheel horsepower right ?
Old Jan 24, 2011 | 03:42 PM
da.slyboy's Avatar
Car: 84 frankenstein Z28
Correct. Lots of members on this board run everything from turbo's to nitrous on stock bottom end with good, reliable results.
Old Jan 24, 2011 | 04:01 PM
red/white04's Avatar
Car: 88 IROC
Engine: 305TPI
depends.. if the engine has been worked on, whats the new comp ratio? if it was a stock build you probably could get away with a little boost on cast internals. if you have alittle higher compression, i personally wouldn't.
Old Jan 24, 2011 | 08:33 PM
bduffey723's Avatar
Car: not a camaro anymore
some inspiration
https://www.thirdgen.org/forums/powe...m-up-15-a.html
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
sreZ28
Oct 22, 2015 08:21 AM
mfp189
Sep 27, 2015 09:25 AM
84redta
Sep 19, 2015 09:58 AM
scottmoyer
Sep 7, 2015 07:06 PM
