Need a good piston/head combo for TT set up
Old Mar 6, 2011 | 10:46 AM
WhoCares?'s Avatar
want to be in the 9-9.5:1 range
Old Mar 6, 2011 | 11:10 AM
IROCyou86's Avatar
Car: 1983 Z28
Engine: 305 LG4 soon to be FRANKENSTEIN L69
Transmission: T-5 NWC
Re: Need a good piston/head combo for TT set up
I know very little about forced induction but did some research to make a 305 TT and this is roughtly what I came up with:
Get a LB9 block (flat top pistons) with decent 350 heads idealy 2.02/1.60/62ish cc. This would bump the CR down with the 350's larger combustion chambers. The LB9 has an ok cam but you could get a turbo one off summit. I estimate the CR would sit at about 8-8.5:1 which is from what i've read, about right for the turbo set up I'd want. Twin T25s were the turbos i was planning on using which are obtainable from an eclipse/ gen II 300zx, and some mazdas at the picknpull.
Old Mar 6, 2011 | 11:32 AM
WhoCares?'s Avatar
i already have a block 350 block .030 over
Comp 300B-14 cam
full forged rotating assembly
i currently have 26cc dished pistons but i was just looking for options
Old Mar 7, 2011 | 05:33 PM
WhoCares?'s Avatar
Any ideas?? really i just need a good head for a turbo setup
Old Mar 7, 2011 | 08:26 PM
IROCyou86's Avatar
Car: 1983 Z28
What's your budget?
Old Mar 7, 2011 | 09:55 PM
WhoCares?'s Avatar
dont have a budget... but id like to keep it a mid grade build
Old Mar 7, 2011 | 10:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What say we move this to the Power Adder forum...
Old Mar 8, 2011 | 08:35 AM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
People are afraid to answer this question around here any more. If someone comes in here and says get Brand 'x', someone else will come in and bash their recommendation. Just about anything modern heads out there will perform great with forced induction. I've been through this decision making process several times in the past few months. I always come back to AFR because of:
The availability and variety of the combustion chamber sizes (still debating pistons)
Good quality valve hardware
Long term resale value - hype or not, they are easy to sell later
Proven performance (Orr on this forum runs 9's with 195's and twin turbo)
Proven reliability (I put 70k miles on some AFR 195's)
If you want to save some money you could consider ProcComp 210cc heads at less than half the price. Others have reported good results with them. I have considered taking this route as well. I'm concerned about the long term implications of using heads with cheap hardware. This car is going to be a driver and trip maker.
Since I couldn't make up my mind on the engine build, I went ahead and started a paint project instead
Old Mar 8, 2011 | 09:58 AM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
diamond pistons and afr's or darts
Old Mar 8, 2011 | 04:34 PM
WhoCares?'s Avatar
thanks for the input guys... Doing AFR 195s 65cc combustion chamber 14cc dished JE pistons ... gonna be more in the 8.9:1 range
Old Mar 8, 2011 | 10:19 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
cool deal man... im gonna be at 9.7:1 with a t76 master power.. so we'll see how it all works out
Old Mar 8, 2011 | 11:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
To many variables to honestly answer that question..... you didnt give any information on what motor you are working with, what your goals are for that motor, what fuel you are using, what your budget was, ideas for power and useage, etc
The right compression and head could be anywhere from mid 7's to 1 with an iron head for optimal performance or as high as 10-10.5 to 1 with aluminum heads for a E85 boost build or a race gas only build...
Wayyy to many options with an open question like this.
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
Navy8125
Aug 22, 2015 07:13 PM
