Safe shot for my setup
Old Jul 11, 2011 | 04:44 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Hi,
I'm just finnishing my engine rebuild and was wondering what shot will be safe for me. Engine is:
383 2 bolt block
cast crank Eagle
i-beam Eagle rods
Probe FPS forged pistons
TFS 195 cc heads with 72cc chambers
TFS cam Duration at 050 inch Lift 230 int./234 exh.
HSR intake
Holley 2x58mm TB
MSII controled
what should i go: +100, +150 or more/less mayby ? wet system
best regards
Old Jul 11, 2011 | 06:33 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Safe shot for my setup
Stock 350s have been taking 150 shots many times. Main thing is to run colder plugs, pull out timing, and make sure your mixtures are correct.
Old Jul 11, 2011 | 06:38 AM
WASyL's Avatar
plugs will be around Autolite 24's, are they correct? timing and mixture will be set with dyno runs
best regards
Old Jul 11, 2011 | 06:47 AM
Engine: 383 SBC
No clue about plugs.
Basic tune with the timing is 2* pulled out for every 50 hp used.
Old Jul 11, 2011 | 07:13 AM
joe2844's Avatar
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
should handle a 150 wet shot no problem. Make sure your running a stock chip. pull 4-6 degrees of timing and put a set of colder solid core plugs(no bosch platinum+2 or anything like that. stick with autolite's). i ran over 150 lbs of N20 through an unknown milage L98 with the 150hp n20 jets and 75hp fuel jets. ran like a raped ape. good luck and enjoy!
Old Jul 11, 2011 | 07:24 AM
WASyL's Avatar
well i do not have stock chip as engine is controlled with Megasquirt.
pull timing means add or retract (sorry for this simple question byt my technical english is still not that good)
and back to plugs, Autolites 24 are ok or should i switch to different number ?
stock are NGK UR4 (same as Autolites 24 as i recon) so should i go 1 or 2 level colder
best regards
Old Jul 11, 2011 | 08:15 AM
joe2844's Avatar
Engine: Carb 5.3
Transmission: Th350
yes, pull means retard the timing. not sure on the plug part numbers but yes 1 or 2 steps colder. and i say stock chip because aftermarket ones advance your timing too much but since you have full control of your timing curves i would adjust them accordingly. i have no expierience tuning with a laptop so i cant give you any worthwhile info on fuel/timing maps.
Old Jul 11, 2011 | 08:27 AM
WASyL's Avatar
with timing and fuel i will manage, thanks for help, if anyone have something else to add i will be happy to ready about
best regards
Bubbajones_ya
Jul 6, 2024 08:32 PM
86IROC112
Nov 27, 2015 09:54 AM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
