Cheap nitrous need help
Old Dec 27, 2012 | 02:02 AM
monsterjam5000's Avatar
Is this kit good? Is it easy to install?
It's going on my 1991 firebird with a lt1 swap
I'm looking for a cheap and easy kit. That I can use without having to do computer mods or any major modifications.
http://www.summitracing.com/parts/nex-20420-10
Old Dec 27, 2012 | 08:01 AM
Guest
Guest
Posts: n/a
Re: Cheap nitrous need help
Your gonna need to buy jets for real shots and not those honda sized shots for kids...
Old Dec 27, 2012 | 08:49 AM
ligerzero5621's Avatar
Car: '76 LT, '87 IROC
Yea it should work but depending if your gonna wet or dry, if you go dry which is really the easiest, your gonna need a throttle body spacer that has an inlet thy will allow you to inject the nitrous there. Or if you I wet and inject them at the fuel rail wich is gonna be a more of a pita to install.
Old Dec 27, 2012 | 08:50 AM
Sorry about all the typos I'm on my phone lol
Old Dec 27, 2012 | 03:14 PM
I'm going with a wet kit I hear its safer. My only problem is how do you splice in with the factory fuel system
Old Dec 27, 2012 | 03:38 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
tap into the fuel rail. Off the shrader valve.
Old Dec 27, 2012 | 03:46 PM
How do you do that? Do you have any pictures
Old Dec 27, 2012 | 04:22 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Do you know where the fuel rail is? Do you know where the shrader valve is?? If so all you do is run a line off of that shrader valve, to the fuel sileniod that the Wet Nitrous kits have. Then after the sileniod theres a line that runs into the nitrous nozzle. There a jet in there for the n20 for strictly the fueling. And also another jsut for the n20.
Says factory fuel line here but you can use a adapter off the fuel line or a adapter on the shrader valve.
Old Dec 27, 2012 | 04:33 PM
Shearer valve is where you install a fuel pressure gave right. Right behind the intake on an lt1
Old Dec 27, 2012 | 04:40 PM
mr305's Avatar
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
si
Old Dec 28, 2012 | 01:31 AM
Will the supplies hose fit on the factory shrader valve
Old Dec 28, 2012 | 05:10 AM
fasteddi's Avatar
Car: 1991 Camaro RS
it "should". Im no n20 expert here though.
Old Dec 28, 2012 | 09:51 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Find the cheap "wet" kit with two solenoids and get that. The price will be similar. Also search other makers... NX is good, but you can find good quality kits for cheaper now...
Old Dec 28, 2012 | 11:03 PM
I like this kit because the silanoids are houses in that little box I think that's a clean look. I found that kit but with the 100,125,150 jets for 400 even.
What kit would you recommend. Please find one and post link I'm looking for cheap
Old Dec 29, 2012 | 06:50 AM
fasteddi's Avatar
Car: 1991 Camaro RS
check ebay. Im not sure how cheep you want to go but there are also used kits on there.
http://www.ebay.com/itm/NOS-8-CYLIND...862a04&vxp=mtr
Heres a good kit IMO for the hp that youd like and its a wet kit with every thing you need to get it on the car. I think 360 bucks for a new kit isnt too bad for the hp youll gain when the juice is flowing.
Old Dec 29, 2012 | 03:11 PM
In not really sure I want a used kit. But ya 360s not bad Where else can you get 100 horse for 360 bucks
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wanext
Oct 6, 2015 12:18 AM
Damon
Sep 26, 2015 04:29 PM
