Chronicles of a 9 Second 305 Trans Am...
Subscribe
Mar 21, 2014 | 01:18 AM
  #451
Re: Chronicles of a 9 Second 305 Trans Am...
Quote: Any track times yet ? Or guestimates ?
Edit; I'll prolly get that intake off u in a couple weeks .. got laid off back Wrekin now ! .. if u get a chance measure the runners for me ... thanks .... how do u think this intake would compare yo the summit stage 1 I got now?
Right now the GTA is fully tuned up to 20 pounds of boost pressure. Must have read Rauscher's Accleration Enrichment article so many times until it finally sunk in lol. If I put the MT 315's from the vette on the GTA there is no question in my mind that the rearend will be destroyed, no question whatsoever, she pulls very hard, insomuch that even the Grand National fella's I hang with are saying damn. Been patiently waiting for some of the other members in this forum with their own builds to throw up some numbers before I embarrass them with the anemic 305's results so far. The Holley intake, its here if you want it, if not no biggie. I ported that awhile back with the only concern being volume. Any substantial increase above the cylinder head ports will essentially "shorten" (not literally) the distance from the chamber to the throttle body orifice, and I opened them up as much as they would go. Will try to throw up a pic of the ports and measurement tomorrow...
Mar 21, 2014 | 08:28 AM
  #452
Quote: Right now the GTA is fully tuned up to 20 pounds of boost pressure. Must have read Rauscher's Accleration Enrichment article so many times until it finally sunk in lol. If I put the MT 315's from the vette on the GTA there is no question in my mind that the rearend will be destroyed, no question whatsoever, she pulls very hard, insomuch that even the Grand National fella's I hang with are saying damn. Been patiently waiting for some of the other members in this forum with their own builds to throw up some numbers before I embarrass them with the anemic 305's results so far.
Mar 21, 2014 | 08:53 AM
  #453
In for updates!
I'm upping boost on my TPI here soon
Mar 27, 2014 | 06:10 PM
  #454
I think I am going to pull the 4" intake tube from the throttle body and run a 3" tube in its' place, mainly because I want to retain the stock appearance, and not have to run a 2 1/2" cowl hood. Also, I think the 3" downpipe is hurting me, and I need to somehow figure out a way to fit a 4" downpipe in there. I don't want to notch the frame though...
Nuff, you need to get that thing out there and take down some GTR's on the highway, getting so tired of those damn guys hogging up all the limelight on youtube. Was thinking about 2.73's myself, as the 3.42's really limit my MPH...
Mar 27, 2014 | 11:23 PM
  #455
I'm thinking about getting a pro charger type setup and running a waste gate on the recent 305 build and running g around 10lbs at the track on race gas then put the the lowest lbs spring in waste gate I can find for street cruising ? I believe I'm around 10-10.5 cr right now ... idk might b fun might go boom ! Lol
91' bird 305 TBI T-5, trick flow heads, 4.10 gears, full UMI setup, track times coming soon!
Apr 4, 2014 | 02:15 PM
  #456
Quick update for the thread, the duty cycle (heh, I said "duty" - insert Peter Griffin's voice lol), the duty cycle is getting up there at 20-psi, so I had to install the larger injectors. While the runners were off I hit them with some Black paint too. Paint scheme will all come together when I install the STB (which fits perfectly btw). Also pulled the 4" oval intake tube we made off of the throttle body in favor for a 3" tube so the stock hood will be able to close, just waiting on the tube to get here so I can cut it, bead it, and get back to the track...
Apr 4, 2014 | 02:30 PM
  #457
I TRIED TUNING MY SRT WITH A HIGH AN LOW BOOST BUT I NEVER USED THE LOW BOOST EXCEPT IN SNOW .LOL
Apr 4, 2014 | 09:52 PM
  #458
How are you beading the aluminum tubing?
Apr 5, 2014 | 12:37 AM
  #459
Quote: How are you beading the aluminum tubing?
We use a bead roll set, and it's a real pain in the @ss because my buddy doesn't have his mounted anywhere, so it's constantly moving. We have to crank it with one hand, then hold it in position with the other as you clock it, while another person holds the machine in place. Works like a charm though, as I'm a pretty big guy, and the couplers don't budge once the tubing is beaded and in...
Apr 6, 2014 | 10:09 AM
  #460
Quick update;
I posted over on Project89's thread, and mentioned how the center section has started to leak a little oil after racing everything I can find on the highway last night (I have video ). Maybe it always did trickle a little oil and this is the first time that I even noticed it, for that matter. At night it is impossible to see anything, even with lights, so I waited until this morning to see what the heck was going on. Firstly, the lower bolt that connects the exhaust housing to the center section has a little oil trickling out from behind the bracket plate it holds down, and the upper fitting on the oil return line just below the turbo also has oil trickling out from it. I pulled the downpipe off and seen no sign of oil anywhere, and started the engine and observed it, and no oil shooting out. Intake side is also clean from any oil being prevalent. So, long story short, oil is more than likely backing up from the block off plate fitting that we made and creating it's own pressure build up, either that, or that particular area behind the block off plate doesn't support enough volume needed and is essentially causing the same thing. One of two things to do here. One, is simply move the oil return location from the block off plate to the oil pan directly, or two, put an oil restrictor on the top of the oil feed going into the turbo. Going to try the easier method first, that being the oil restrictor up top...
Apr 6, 2014 | 05:30 PM
  #461
Been doing some reading on boost and found this ...just figured I'd share ... so looks like I can't run much boost with 10-10.5 cr lol ..
I believe I could run 10 psi on 110 leaded no problem
Apr 6, 2014 | 06:53 PM
  #462
All it would really take for your engine is E85, as 11.5:1 is the area most target for running as much boost as they need. Simply doesn't detonate from what I have seen. Get your hands on a DW300 fuel pump like me (compatible with E85), larger injectors, and adjust your target afr with the EBL. Sounds difficult, but it really isn't. The hardest part would be finding a local E85 station near you. Could always just drop the compression where you need it with custom Cometic head gaskets, which you would need to install anyway if you go boosted...
Apr 8, 2014 | 06:59 PM
  #463
Quote: One of two things to do here. One, is simply move the oil return location from the block off plate to the oil pan directly, or two, put an oil restrictor on the top of the oil feed going into the turbo. Going to try the easier method first, that being the oil restrictor up top...
Well, the restrictor didn't help one bit, not to mention the fitting that came with the turbo was essentially a restrictor in itself, but I went with an even smaller diameter restrictor and it still didn't do the trick. Let this be a lesson to you new turbo SBC guys, do not use the mechanical fuel pump block off plate as your return source. The area behind the plate that houses the mechanical fuel pump pushrod simply cannot handle the volume. I now have to pull the damn engine out again and drop the oil pan to install a return fitting, sigh...
Apr 8, 2014 | 07:33 PM
  #464
Quote: Well, the restrictor didn't help one bit, not to mention the fitting that came with the turbo was essentially a restrictor in itself, but I went with an even smaller diameter restrictor and it still didn't do the trick. Let this be a lesson to you new turbo SBC guys, do not use the mechanical fuel pump block off plate as your return source. The area behind the plate that houses the mechanical fuel pump pushrod simply cannot handle the volume. I now have to pull the damn engine out again and drop the oil pan to install a return fitting, sigh...
my returns ( both) are to the fuel pump area and i have no oil issues , ur block may not have the return hole in the pump mounting spot not all do.
if it doesnt have the drian back hole u can drill it , if it does have the hole u can drill it larger
Apr 8, 2014 | 07:46 PM
  #465
Quote: my returns ( both) are to the fuel pump area and i have no oil issues , ur block may not have the return hole in the pump mounting spot not all do.
The engine has both holes, that was actually covered awhile back when I was talking to BBSDesigns about his turbo header setup, it was one of the first things I confirmed before using the blockoff. Even with both holes though it's getting backed up. I'm not going to drill the block any larger though and worry about residue with the engine already being together, it's easier to just drain the oil, drop the pan, and install the fitting while it's on the lift. If it was a bare block, then yeah. Not going to do the fitting in the driveway, as Paul can get it done in five minutes for me once it's by his house...
Apr 8, 2014 | 08:00 PM
  #466
Quote: The engine has both holes, that was actually covered awhile back when I was talking to BBSDesigns about his turbo header setup, it was one of the first things I confirmed before using the blockoff. Even with both holes though it's getting backed up. I'm not going to drill the block any larger though and worry about residue with the engine already being together, it's easier to just drain the oil, drop the pan, and install the fitting while it's on the lift. If it was a bare block, then yeah. Not going to do the fitting in the driveway, as Paul can get it done in five minutes for me once it's by his house...
u should be able to put the fitting in with the pan on the motor in the car, just do not drain the oil pan before welding it
and use a punch to punch a hole in the pan instead of drilling it
while my engine was apart i instaled 2 bungs in my pan just incase i wanted to switch from the fuel pump area
Apr 12, 2014 | 08:55 PM
  #467
Spring is officially here, finally. The weather was incredible, especially considering this is swap meet weekend at raceway park. Gonna bang out the Intercooler box tomorrow, and weld it into the bumper support. Already bolted in the hood latch/nose support and painted it, just need to weld the box in underneath it, and the two will be bolted together using bolt spacers. Will look factory when done, and everything is easily accessible in terms of maintenance (bulb replacement, IC removal, etc)...
Apr 13, 2014 | 01:44 PM
  #468
Should have the cold air box wrapped up later tonight, with the welds smoothed down, and everything hit with a few coats of black. Will definitely look factory when done, and it's very stout in terms of strength. Few more pieces to weld in, and I need to shorten the lower area as it will only extend as far as the crush guards. I'm also going to make a removable bracket for the front license plate...
Apr 13, 2014 | 07:26 PM
  #469
It's pretty much done, I made the top already just need to weld it in. Before I do that though I need to smooth down the welds, grind off the flux, smooth the edges down, then top it off with the cover. Once its all welded up, and smoothed down, I'll remove the crush guards and fog lights, sand it down, and hit it with some black paint. Can finally put the nose back on then permanently with the mesh grill installed...
Apr 13, 2014 | 08:07 PM
  #470
Last pic for the night, gonna freaking pass out soon lol. Setup is gonna look awesome when smoothed down and painted, even the crush guards will look brand new when I am done. Too tired to do anymore tonight...
Apr 16, 2014 | 06:04 PM
  #471
Looks great, Nice work man! Keep them pics coming.
Apr 18, 2014 | 09:12 AM
  #472
Awesome fab work Lethal!
Apr 20, 2014 | 04:30 PM
  #473
Thanks guys...
Still have some smoothing and shaping to do, then it's just the matter of painting it then putting it all back together. The cut out on the nose bumper is the exact same length as the air box. The metal used is 16 GA steel, same thickness as the bumper support itself, and it doesn't budge. It's very strong. Will have a picture of the finished product up soon, it's gonna look killer. Happy Easter fella's...
Apr 20, 2014 | 07:56 PM
  #474
i can't wait to hear this things exhaust note
Apr 21, 2014 | 05:30 PM
  #475
want to buy a 9 inch housing and axles located in ny?
Apr 22, 2014 | 04:47 PM
  #476
Quote: i can't wait to hear this things exhaust note
It sounds very unique with the exhaust hooked up. Next on the list though after the cold air box is done (painted) is the hood. Gonna blow your minds when you see how it comes out, it's going to look awesome. Not sure about paint just yet, as I have been fiddling around with different colors with a spare front bumper. Might just keep it black though to tell you the truth...
Quote: want to buy a 9 inch housing and axles located in ny?
Not just yet, wanna see how long the stock rear holds out first...
Apr 22, 2014 | 04:49 PM
  #477
Good luck!
Apr 22, 2014 | 05:01 PM
  #478
awesome, unique is good. black is beautiful, and until the boost comes on
Apr 26, 2014 | 01:11 PM
  #479
Beautiful day outside, way too much sun (not complaining lol). Gonna wrap up the front then get back into the tuning...
Apr 26, 2014 | 02:53 PM
  #480
Looking good, should have mine together soon.
Im running the stock ac box for now, I will let you know if I want the delete box you have in the future if you still have it then. If you have a buyer between now and then feel free to sell it.
Lol, too much sun? Not in Jersey, lol. I dont miss the snow one bit
Apr 26, 2014 | 03:05 PM
  #481
Quote: Beautiful day outside, way too much sun (not complaining lol). Gonna wrap up the front then get back into the tuning...
Hey street ! Ever get the runner dimensions on that intake ? ... I finally got mine.to the track last night ... only got 2 shitty passes in before it rained out .. but I picked up about 10 mph trap speed ... still needs major tuning work tho ...
Apr 27, 2014 | 03:09 PM
  #482
Very big cam I went with for this 305. Got the idle down to 900-RPM, targeting 14.7 stoich in Closed Loop, yes, Closed Loop lol. Any lower than 900-RPM and she surges no matter what I do, but considering the size of the cam, 900-RPM with no surge is pretty damn good. Here's a short clip. Still running an open down pipe. Gonna spend the rest of the day on the nose bumper, gotta glue the mesh grill in and then paint...
Apr 27, 2014 | 06:37 PM
  #483
Quote: Looking good...
Quote: Hey street !
... the two of you must "unlearn what you have learned" (beer is kicking in lol).
Apr 27, 2014 | 07:08 PM
  #484
Lol, yea beer was kicking it hard today. Got the turbo headers and xpipe on, tightening them down i hear crack. Hmmm cold weld broke in 2 places. Fixing it now then back on later. Tight fit too.
Apr 27, 2014 | 07:39 PM
  #485
I think I heard you had some street racing videos somewhere up top?? Link?
Apr 27, 2014 | 08:16 PM
  #486
Quote: Lol, yea beer was kicking it hard today. Got the turbo headers and xpipe on, tightening them down i hear crack. Hmmm cold weld broke in 2 places. Fixing it now then back on later. Tight fit too....
Which welder and rod are you using...?
Quote: I think I heard you had some street racing videos somewhere up top?? Link?
I'll be posting everything once I edit it, including dyno and track. I have been posting the entire build in chronological stages.
Apr 27, 2014 | 08:22 PM
  #487
Quote: I'll be posting everything once I edit it, including dyno and track. I have been posting the entire build in chronological stages.
good.......................good....... muahahahahahah
Apr 27, 2014 | 08:34 PM
  #488
Cool. Now I kinda feel like Im waiting on a PPV fight!
Apr 27, 2014 | 08:36 PM
  #489
Eastwood mig 175 with gas. Bl85c did the original welds on the headers, just didnt get enough penetration in some spots. It aint gonna crack now, just gotta do some grinding to clean it up and the passenger side header can go back on. Drivers side is tightened down, ill have to loosen it a bit to get everything to line up. It really is tight, man it was solid as hell bolted up.
Apr 27, 2014 | 08:40 PM
  #490
I put a brushless on an rc car, kinda feels like Im doing the same to the Camaro, just a much bigger brushless, lol
Apr 27, 2014 | 09:34 PM
  #491
The cold air box was actually six inches bigger than the original cut I made in the nose, so I increased the length of each side by three inches. Couldn't use my cutting tool because of the noise, had to use a box cutter just to make the preliminary cut. I already smoothed down the cut along the bottom, the sides and top will be perfectly even once it is all smoothed out, will look flawless when done. I already purchased the honeycomb style mesh grill, a la Pontiac style. Still debating what color I am going to paint the car, as the grill will be black, and I want it to stand out. Even though I painted the cold air box black, in the daylight the Intercooler's reflection can be seen on it, pretty sweet looking...
Apr 28, 2014 | 09:16 AM
  #492
Yeah man!
Apr 28, 2014 | 09:42 AM
  #493
Grain of salt... That chart says i'm at 20.9:1 comp under boost. How can i be on 93 oct then?
Apr 28, 2014 | 10:22 AM
  #494
Because you're Orr and you just dgaf.
Apr 28, 2014 | 10:29 AM
  #495
Quote: Grain of salt... That chart says i'm at 20.9:1 comp under boost. How can i be on 93 oct then?
u lucky bastid im stuck with 91 oct but i still ran it up as high as u without issues, though being a mile and a half above sealevel did help with that
at sea level id prolly have to drop about 5 psi on 91 oct
Apr 28, 2014 | 11:42 AM
  #496
Once we get summer air i probably wont beable to make full boost. Cooler is taxed. Need meth or better gas lol. My runs were made in 40 deg weather and dropping. Air was thick!! Snowing by time i left. Cold air makes pump gas power possible. Meth is a must at higher temps and or compression
Apr 28, 2014 | 12:06 PM
  #497
So technically I could run 14*15 lbs @ 10.5:1 cr :-o ... and all the shell stations here have 93 and the shell by the track has 110 leaded at the pump.
Oh and I'm only at like 1000ft
Apr 28, 2014 | 12:26 PM
  #498
You will have to experiment but good intercooling and cold plug it may be possible
May 1, 2014 | 12:05 PM
  #499
Okay, the cold air opening/orifice on the nose bumper is done, just need to sand the rough edges a little then prime. Car is very dirty, need to wax her asap. Gonna stick with the TT2 rims, they are 17 by 8 up front, and 17 by 9 1/2 out back, with no spacers. Wait til you see the killer hood I go with, as those of you following this build will be scratching your heads saying to yourself "wtf is he nuts" lol...
May 1, 2014 | 12:13 PM
  #500
Figure I'd kill page ten with one last pic, picked it up for $150.00 over at e-town...
