Chronicles of a 9 Second 305 Trans Am...
Re: Chronicles of a 9 Second 305 Trans Am...
Y'all should have seen the gen 5/6 dfi my car had in it. Had a variable injector controller/driver and a plug n play board so it would plug right into the car. I had an IBM 486 laptop to tune it with. Was put in the car in 1990. Has a megasquirt now, but may swap to something else when I get it running again.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Just a small update. The engine felt like it was holding back a little during that video on the page before, and after looking at my spark advance in the datalog, I knew something was up because I was seeing a lot less advance than I should have with the values that I set in the Launch - SA table. So, I went back into the bin to inspect. Well, found the problem. I had my values in the table the way they would be with XFI, they were going the wrong freaking way, as I keep forgetting Tuner Pro is the opposite. Fixed that issue, ran a quick datalog, and now she pulls so hard off the line it has me grinning from ear to ear. Didn't adjust Launch - Sa just yet, as I need to go in there and lower some of those values, as I was seeing upwards of 37* w/out boost at 100-KPa. Oddly enough, no knock despite that. Gotta love SBC's...
Just some part throttle tuning today before the fireworks, I can't floor it anymore because all I get is a smoke show, and I don't want to **** off the neighbors. It's bad enough I am running an open downpipe as it is...
Let off at 8.4-psi of boost pressure, I need brakes up front desperately, damn car didn't want to stop. Something is off with the grams/second, I am telling you that the injectors are static, duty cycle is over 100% at 8-psi, O2's are reading 800's. She is pulling so hard at only 8-psi, 15-psi is going to be a nightmare to handle. I need brakes asap...
Car: check
Engine: check
Transmission: check
Brakes, now this is funny, you know what I worked on today, brakes. Dang things, never been happy with them, but am getting it narrowed down and working much better.
{edit} As for brakes, use a good set of pads, such as StopTech high performance street pads. Makes a world of difference.
The Air Flw is not in gms/sec, it is just a decent estimate used for various non-critical areas of the tune.
RBob.
RBob.
Yeah, I am not gonna play like that on my street anymore, it was pulling very hard, wasn't expecting that at first from only 8-psi, then I had trouble slowing down. Gonna pick up a set of StopTech brakes this weekend. I calculate 410-RWHP at 100% DC, not bad for a stock throttle body and stock runners. I'd like to get a run in against Murphster with these injectors, but I think its time to install the bigger ones, then on to the stall converter which I am not looking forward to installing...
Car: 89 Formula
Thanks Will. Anyone who lives in the Queens area, or New York in general, and heard about the NYSD dept worker who was killed last week, that was him. Knew Steve since I was six years old, he leaves behind a beautiful wife and four adoring kids. It's been a horrible week...
Originally Posted by fozzi58
Oh Fudge - the guy that killed by the street sweeper? That sucks big time. My condolences...
http://www.nydailynews.com/new-york/...icle-1.1840982
http://www.newsday.com/news/new-york...eral-1.8595401
Small update, stall speed converter needs to go in asap, stock stall is killing it from a dig. Was sending RBob datalogs, and even he is like it's time to lose the stock 1600-RPM converter, and I agree, gotta get that in next. The siamesed TPI system revs well over 6000-RPM when I keep the throttle down, but I keep easing off the pedal because of the brake issue. Even with the new brakes installed, she scares the **** out of me trying to slow it down during boost, so I more than likely will be throwing on larger rotors w/brakes. Also, the 60# injectors go on tomorrow. I might be buying a local's HSR, but will know how that turns out later on tonight if he agrees to the offer I made him. Once those two out of three issues are taken care of; the converter, the injectors, I'll take it to Ida Performance to dyno it at 15-psi...
Took it for a quick blast down Route 9, running an 8 pound spring by the way. Was cruising in overdrive, floored it, trans downshifted of course, and it felt very very good, pulled extremely well. Duty cycle is down of course at 8-psi, whereas it gets pegged in first and second gear. IAT's again high because she was idling for awhile before this datalog, not to mention 90+ degree day...
What iat you using and where is it located?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Get the bird cage one running! Its ten times better than the stocker. Stock one gets heat soaked and doesnt react fast.
I got a thread in the members camaros board here with 2 pics lol
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Car: 89 Iroc-z
Transmission: TH400
Probably. It literally does react like it should. I've run the MAT ones that are same as coolant temp sensors on my car and it may move 2-3 deg after a 1/4 mile pass and it reads surface temp air of hot manifold which is not accurate for whats going into cylinder. It was reading 150 after sitting with ambient in the 80's. The birdcage type plugs right in place and i actually can see temp rise over 1/4 mile like you expect. Same ambient 80's deg my IAT now was 95 at start of run and it 125 after a 12 psi full pull in 10 seconds. Thats the data you neeeed for boosted cars
Engine: LB9 | LS1
Car: 89 Iroc-z
Transmission: TH400
http://www.diyautotune.com/catalog/g...tail-p-62.html
I run all diyautotune stuff. Iat and 3 bar map
I am gonna get another for my 305 car since its gonna be boosted
the v6 f-bodys have the birdcage type sensors
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I am surprised that 700R4 isn't junk yet. I ballooned two stock converters at 10 PSI with a bone stock 150K mile 1986 305ci TPI at 10 PSI (daily driver). One converter lasted 300 miles at 10 PSI.
Since ya are running on the street, what does the 1/4 mile button in the WUD report?
Yes, stock IAT is way too slow. Install it in a place where it makes sense relative to your ECM tuned IAT tables.
Originally Posted by junkcltr
I am surprised that 700R4 isn't junk yet. I ballooned two stock converters at 10 PSI with a bone stock 150K mile 1986 305ci TPI at 10 PSI (daily driver). One converter lasted 300 miles at 10 PSI. Since ya are running on the street, what does the 1/4 mile button in the WUD report?
I am gonna get another for my 305 car since its gonna be boosted...
http://www.napaonline.com/Catalog/Ca...100_0306514996
Car: 89 Iroc-z
Transmission: TH400
Yeah i'm gonna try my stock 129k mile 700r4 but dont think it will last long at all. Also dont want to spring for a expensive converter, hoping to find one used. I dont want any cheap tci, b&m, or similar style one. I just want a mild converter, 2400-2600
Engine: 3xx ci tubo
Car: 89 Iroc-z
Transmission: TH400
Now i know i am gonna need a 700r4 if i turbo this 305, and a converter. Found a few built trans for sale around. Just not in the budget yet
Engine: 3xx ci tubo
I need to learn those too! Already had to rebuild the th400 in the other car. Burnt the hell out of it. Luckily no hard part damage and my trans guy covered it under warranty so no repair costs!
If you buy the paul zank video, and ATSG manuals, and read about upgrades online (or look at pkgs vendors sell) then you are good to go. The worst part is tools. I bought some cheap harbor freight alum bushing driver kits and had someone turn them on a lathe to do all the trans bushings. The kit for the 700R4 is expensive. Besides that all you need is some mig wire to make a lip seal installer, some plastic bottles & zip ties to make teflon seal resizer, snap ring pliers, and clutch compressor (make one or buy), small drill kit.
I wonder how street made out with the bigger injectors and quarter mile run.
Car: 89 Iroc-z
Transmission: TH400
I think Street will be learning soon too. Your trans guy is good to cover that. The question is: How do you keep it from happening again? What do you do when it happens again or something else does?........and it will.
If it happens again? Quit racing lol dismantle and turn down the power
Lol so eagar to see what Streets 305 is gonna do. I just need to beat a 12.5 at 109 in summer air to be happy
I think Street will be learning soon too...
I wonder how street made out with the bigger injectors and quarter mile run...
Injectors are in as of last night. Changes to the bin have been made immediately after, and the VE continues to make changes while in Learn Mode. I know you guys wanna see a 1/4 mile blast in the WUD, but I have to make sure the fueling at 100-kpa is dead on first before I make changes to the BST tables...
Trans seems fine at the moment, not slipping, no burning, fluid looks good...
Patience Junk, patience, guess its been awile since you changed a set of TPI injectors, as it is a royal pain in the @ss to have to remove the plenum and runners each and every time. Main reason why I wanted that HSR, makes injector swaps a breeze, but I am sticking with the TPI for now as the deal for the HSR fell through...
ummm rob i have one if ya want it
That's the Chinese version of the HSR though Dave, yes?
Stock setting in the LB9 bin for IAC - Gain is 12.55% for both Park and Gear. Was getting some hesitation in the idle for about a second or two when switching from Gear back to Park , not Park to Gear, when the larger injectors went in. Went in and raised that 12.55% value 30% more, just under 17.00% for both Park and Gear. The hesitation from Gear to Park is gone, but then the RPM was overshooting (not oscillating, but hanging too long, not settling down fast enough), so I lowered those two values down to 14.00%, and now all is good with the idle transition both to and from Park/Gear. Not sure if I should touch the IAC - Gain Breakpoints, though...
Transmission seems fine. Not saying it will last forever, as it will give up the ghost whenever it decides to, but stop saying that its going to for crying out loud already, I know that it will lol...
yes it is and the funny thing is its nicer then the holley , out of the box both are the same , but the procomp one can be ported further, and the fabbed plenum is nicer then the holley cast plenum
Car: 89 Iroc-z
Transmission: TH400
Murphster stopped by yesterday with his 3.8 Turbo Buick powered C10, looking to give me a taste as to what to expect when we run. He just finished installing his alky setup, so he took me for a ride at 20-psi of boost. She pulled nice and strong, but in my opinion, not as strong as the GTA at 8-psi of boost pressure, and I am not kidding when I say that. When we got back to my house, I pulled the GTA out from the garage and said to him get in, took him for a ride up and down the block and laid into it. Gave him a taste of what the SBC felt like at almost just a 1/3 of his boost pressure. He was holding on much tighter than I was in his truck lol. By the way, he is now running a 62-1 turbo with larger injectors. It's gonna happen very soon, throw downs are a comin...
Wow this forum has been dead since I've been gone, nobody has made any progress with their builds? Anywho, had the GTA by my cousin's house to make some needed room in my garage, but I asked him to swing by this morning with it to get some work done to it. Nabbed a fiberglass twin turbo hood by the way, which is fitting because the car will eventually employ another turbo charger sooner than later, but the hood needs to be adjusted, the brackets need to be moved forward about a half an inch. Not sure when we'll be able to get her to the track, haven't had the time to work on her lately, unfortunately, but she pulls like a ****...
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Car: 1984 T/A
Engine: LQ4
What happened to your custom hood?
Originally Posted by willexoIX
I noticed that too lol. Guess its the slow part of the year. I am just waiting on getting my license back and running hardline for my oil feed, other than that no real updates over here.
It's funny it worked out that way, was supposed to pick up up a 2 1/2" Harwood Cowl this weekend over in PA, but at the last minute my cousin sent me Steve's link. Very nice guy, but damn you guys live in seclusion down there lol. Turnpike was at a damn standstill too, took a freaking hour to get to Exit 8 from Exit 7, and I am being honest...
Missing in action?!. Just got alot of **** going on right now and i been staying away from the internets. Glad to see you got the car up and running. If i get some time this weekend ill run thru the rest of the post i missed. I just got back to finishing up my pos.
Originally Posted by TwinTurboROC
Missing in action?!. Just got alot of **** going on right now and i been staying away from the internets. Glad to see you got the car up and running. If i get some time this weekend ill run thru the rest of the post i missed. I just got back to finishing up my pos...
Car: 89 Iroc-z
Transmission: TH400
Any chance it will see a dyno for additional tuning? Only 2 months til tracks just about close... Will it see an et?
Car: 89 Iroc-z
Transmission: TH400
Kinda took a back seat as i had to get the other car running again. Had some
Minor issues lol
So far i have a turbo, a oil pump, zz4 cam and my chip burning working. Plan is remote setup with code $59 for now.
But car needs 4th gen rear first and shocks/springs. Alittle at a time but not gonna finish it before winter. It will be winter project
Minor issues lol
I have a better chance of getting it to the dyno first. There is a track rental over at Atco Raceway next month, but I don't want to take the GTA that far away (about an hour drive), set it for 20+psi, then get stuck there if something breaks. Will stick with E-town because it is ten minutes away, only thing stopping me is they will have a fit because of the no cage issue, and they don't play around anymore because of the heavy fines. They freaking rip into you too, and you have to stand there and just take it without losing your damn cool, otherwise no more racing there ever again, and I kid you not...
Gonna at least push for the dyno w/video very soon, wanna see at least 600-RWHP at 15psi. If it feels good on the dyno, and the data looks good, and Ida has no issues, will up the boost to 20psi and see what she makes...
Car: 89 Iroc-z
Transmission: TH400
Thats a pretty big number for 15 psi but it should make steam
Theres a rental nov 14 at MIR, i am considering. Think its a vette group but others are welcome. From what i hear they dont mind fast cars tht dont have all the safety stuff. I heard they let 2 c6's run 8's with no cage. I only have a roll bar and no chute so this is a good chance to test n tune. My current track is also fairly lenient on tech
That is why I wish I lived closer to Atco Raceway. During a rental Atco Raceway will let everyone fly without saying a word, but e-town limits you to 10.0 with no safety equipment during a rental, but then it is a matter of rental cost which is why we don't see too many rentals at e-town, so we're all subjected to run on a regular day/night at e-town hoping they don't bitch and complain, but they always do. She should make 600-RWHP at 15-psi no problem, now I am actually looking forward to seeing if it does myself...
Exhaust is almost done. I took the Flowmaster that was already on the car, cut off the 3" intermediate pipe connection that goes over the rear axle, and just got rid of the 3" intermediate pipe itself. I opened up the orifice to 4" on the inlet of the Muffler, and plan on running a 4" intermediate pipe from the downpipe to the muffler. The dual 3" exhaust tubes coming from the Flowmaster have also been cut off, as I will be merging the tubes into one 6" oval (stainless) towards the center. Will post pics as soon as its done...
