Will this supercharger work on my 305 TPI v-belt setup
Old Feb 18, 2014 | 01:06 PM
oddscrounger's Avatar
Car: 1987 IROC Z28
Transmission: TKO 600
Axle/Gears: 3.45 (G92 package)
I typed in all my car info and Jegs says so but I doubt it...
any input please?
http://www.jegs.com/i/Weiand/925/7750-1/10002/-1
Thanks,
Kent
Old Feb 18, 2014 | 01:10 PM
project89's Avatar
Re: Will this supercharger work on my 305 TPI v-belt setup
any input please?
Thanks,
Kent
all the info u need is in the manual on the jegs page
There are some important differences between these kits.
First, all Pro-Street kits listed above can be used on both
long and short water pump engines, depending on the
length of the blower. Short nose blowers will work on short
water pumps with up to 2 ìVî belts. The long nose blowers
will work on both short and long water pumps with up to 3
ìVî belts. To use an OEM of the aftermarket serpentine
drive, you will need to modify the lower drive pulley to get
the correct belt alignment.
Old Feb 18, 2014 | 01:15 PM
Car: 1987 IROC Z28
thank you thank you. previously all my research on this site has led me to believe that the only setup that works is the Paxton SN series, and that supercharger sucks apparently; and is not available....
Old Feb 18, 2014 | 02:36 PM
Car: 1987 IROC Z28
the instructions for installation make it seem like it's for carb engines only? is this so?
Old Feb 18, 2014 | 02:39 PM
project89's Avatar
yes that supercharger mopunts in place of the intake manifold and the carb goes ontop
Old Feb 18, 2014 | 02:58 PM
Car: 1987 IROC Z28
yea I have a TPI so no bueno
Old Feb 18, 2014 | 03:04 PM
project89's Avatar
have u thought about turbos? i happen to have a set of twin turbo log manifolds for sale in the classified there were built to fit around the v belt setup
u can use that blower on ur car , u just remove the stock ecm and wiring , get a non computer control distributor and bolt it all on with a carb, u would need ot purchase an msd btm box or the new digital ignition box eithe rbox is in the 300$ price range
Old Feb 18, 2014 | 03:36 PM
Car: 1987 IROC Z28
I've thought about it but I don't want to get away from the original TPI setup and go carb.
Old Feb 18, 2014 | 03:52 PM
project89's Avatar
with turbo or turbos u can keep the tpi and just have the stock ecm tuned
ur only choice for a supercharger is one of the centrifical types i.e paxton,procharger etc, none of the roots style blowers will allow u to keep the tpi
Old Feb 18, 2014 | 04:11 PM
Car: 1987 IROC Z28
I can't any supercharger that works for my application right now.... unless I switch to serpentine setup
Old Feb 18, 2014 | 04:15 PM
Car: 1987 IROC Z28
I can't "find"...
Old Feb 18, 2014 | 04:57 PM
project89's Avatar
I can't "find"...
search for one of the carbed setups i belive those were vbelt systems , then just plumb it to ur tpi intake
Old Feb 20, 2014 | 03:16 PM
toronto formula's Avatar
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
Paxton made sc for mounting on passenger side for v belt set up
Search adhuntr for used kit unless you are dead set against paxton
Old Feb 21, 2014 | 07:51 PM
T/Aperformance's Avatar
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
There is a few ways to run fuel injection with that supercharger. The first and easiest way is to change over to TBI .
The other way that was talked about on this forum is to weld fuel injector bungs on the manifold And run a 90 degree elbow on top of the blower and a TB.
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
