What do you guys think of this Turbo?
Old May 7, 2015 | 03:09 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
http://www.cxracing.com/mm5/merchant...y_Code=BRTurbo
Stage III Ceramic Ball Bearing on Compressor Side
0.70 A/R Compressor Housing with Anti-Surge Inlet
T3 0.82 A/R Turbine Housing
T3 Flange to Manifold
3" V-Band Downpipe Flange
4" Air Inlet and 2.5" Turbo Outlet
Light Weight Billet Wheel Offers Excellent Performance
High Quality Built product. Each Turbo is individually tested and computer balanced.
BRAND NEW, not used, not remanufactured.
Item(s) Specification :
- 4" Air Inlet
- 2.5" Compressed Air Outlet
- Ceramic Ball Bearing on Compressor Side Compressor
- Standard T3 Turbine Housing Flange
- 3" V-Band Exhaust Outlet
- 400-600 HP
- Oil Cooled
- Working Pressure: 8-30 PSI
- Compressor: 0.70 A/R
- Turbine: 0.82 A/R
- Compressor Wheel (Major/Exducer): 76.6/58mm
- Turbine Wheel (Major/Inducer): 60/55mm
I havent heard anything bad about cxracings turbos, and was thinking of using these in my twin turbo setup!
Old May 7, 2015 | 03:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: What do you guys think of this Turbo?
Could work on a smaller cube motor at moderate power levels. I wanted similar ones for my 305 but thinking going single rear mount now
Old May 7, 2015 | 04:21 PM
What do you mean smaller cube motors? I have seen tc66s on 383's pushing nearly 1300 - 1500 hp?
Old May 7, 2015 | 04:24 PM
I dont have much experience with the single vs twin debate, but from everything I have read and searched for the street twins behaved better and provided a better boost curve and spooled faster.
But I dont know, I was debating a single rear mount, but as I said after research I chose to try smaller rear mounted twins.
Old May 7, 2015 | 06:27 PM
Rough drawing of my current plan
Green Charge Air
Blue Cold Air
White Intercooler
Red Turbos
Purple Turbo Exhaust
Grey Exhaut
Old May 7, 2015 | 07:37 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Sorry to hijaak, that is a cool pic do you have a hi-res version? Thx!
Old May 7, 2015 | 09:43 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Turbine side is small. T3. I wouldnt use them in larger motors that turn some rpm or making bigger power. Wont match up well
Compressor side is big enough to make decent power
Old May 7, 2015 | 09:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If everything is sized right, singles spool well. For rear twins it complicates things more with twice as many pipes but could prove to be good for space and still get good power/response
Old May 8, 2015 | 10:52 AM
project89's Avatar
do not buy a ball bearing ebay unit,
they use skateboard/roller blade bearings in them they blow up
crazynights
Aug 21, 2015 06:53 AM
PestilenceIV
Aug 20, 2015 03:32 PM
PestilenceIV
Aug 20, 2015 02:33 AM
Street Lethal
Aug 14, 2015 08:25 PM
makaveli09
Aug 12, 2015 09:07 PM
