vortech oil leak
Old Jul 6, 2018 | 12:28 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
vortech oil leak
I can't figure out where this oil is coming from. It's NOT the feed and NOT the drain. I don't think it's leaking out of the seal behind the pulley..
Getting pissed.
-- Joe
Old Jul 6, 2018 | 12:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: vortech oil leak
Oil dye and a black light might help.
Old Jul 6, 2018 | 01:08 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah might be the next step. So even when oil has dried, it leaves a stain behind with the dye right?
-- Joe
Old Jul 6, 2018 | 01:12 PM
Engine: Lb9
Transmission: M20
Correct, you might want to clean the area and run the engine. You can get the oil blowing back and it makes it harder to trace.
https://m.ebay.com/itm/ACDelco-GAS-E...8AAOSwrOtZuZVO
https://m.ebay.com/itm/Black-Light-B...wAAOSw1PJbIXAX
Some examples on what to buy.
Old Jul 6, 2018 | 01:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Almost looks like the front and middle of case is leaking. I can't remember, O ring on those 2 halves or paper gasket?
Old Jul 6, 2018 | 01:49 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It's a rubber oring.. what's weird is i don't see it leaking out of the case split.
But it collects at the lowest point and drips to the ground.
-- Joe
Old Jul 6, 2018 | 11:15 PM
TTOP350's Avatar
All of them I've ever delt with did.
Old Jul 9, 2018 | 09:49 AM
86CamaroDan's Avatar
Car: 86' IROC
Engine: Supercharged 350
Axle/Gears: 3.45
I would definately try resealing that drain just for giggles, and as stated a bit of oil dye. Clean it down with a can of brake cleaner, blow it off and then run it.
After seeing the case seal on my V3, i dont have much faith in it longevity wise. Very thin, and barely protrudes from the machined grove.
Old Jul 9, 2018 | 10:21 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I did. Three times. Changed fittings, thread sealant, etc. Its not leaking from the fitting. Absolutely not. It's leaking from the case somewhere, and running down.
I think I've had this out several times and gone through a case of brake cleaner lol.
I *think* maybe my first -6 drain into the fp blockoff was causing back pressure and maybe it blew a seal.. ? I dunno. Annoying.
My rear main seal leaks too.. F'n old style 2pc engines. I should have build a dope LTx.
I guess I still can, technically. I've thought about yanking this motor out for my t-bucket project and doing up an LT1 for the thirdgen.
-- Joe
Old Jul 9, 2018 | 12:55 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I never remembered it leaking, and i never took it apart. Might want to put another case rubber rope seal on it and run it?
Old Jul 9, 2018 | 02:27 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Yeah, I may end up doing that. I'll have to see where I can order a new seal online.
I've never had it apart either.
-- Joe
hydrolic144
Nov 11, 2010 05:20 PM
ATCharming
Jun 29, 2009 03:33 PM
305 black ghost
Jun 1, 2007 09:25 AM
firebird305
Dec 11, 2002 02:12 PM
Stroked 86 Bird
Sep 19, 2002 05:58 PM
