Fixed one problem now have a new problem.
Old Aug 26, 2023 | 10:11 AM
dana0330's Avatar
I had a bucking problem on my boosted 2,8l that I fixed with larger flow injectors. Now I am getting a code 45 rich mixture. I replaced the one wire o2 sensor with a heated sensor to try to correct it, but it is still happening. It sets when cruising, I can put the 17lb injector back in but I will get the bucking back. I am running a FMU to boost fuel pressure under boost it is a 10:1. Any help would be appreciated.
Old Aug 27, 2023 | 02:01 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: Fixed one problem now have a new problem.
You really need a wideband o2 sensor on there and a way to datalog things. The one wire and heated sensors are no good for your application. Are you running a boost referenced fuel pressure regulator??
Old Aug 27, 2023 | 07:12 PM
dana0330's Avatar
I am running a 10:1 fuel management unit. What kind of wideband o2 sensor will work with the stock computer? I could not find any computers that will work with it,
Old Aug 29, 2023 | 12:27 PM
dana0330's Avatar
I am looking into the Fi Tech system it is for a v8 but would it work for the v6 If I don't plug in the other 2 injectors? I called them and they just said they never tested it on the V6.
Old Aug 29, 2023 | 12:37 PM
thatsupnow's Avatar
Try it out. I think you'd most likely have to rearrange the firing order in the software
Old Aug 31, 2023 | 07:49 AM
dana0330's Avatar
I put the 17 lbs injectors back in, and the rich code 45 is gone but of course the buck is back. I was thinking of putting a inline fuel pressure regulator in to boost the fuel pressure a bit. If I do that should i just pull the spring out of the stock regulator to bypass it. and hook the vacuum line from it to the inline one?
Old Sep 5, 2023 | 12:11 AM
drive it's Avatar
If you have an FMU you should adjust that to increase fuel pressure and get more flow thru the injectors.
Old Sep 5, 2023 | 01:58 PM
dana0330's Avatar
My FMU is not adjustable. I talked to the guy at Soutbay injectors and he said base fuel pressure is to high for the larger injectors and it probably flowing too much fuel. I would like to bypass the stock fuel pressure regulator and put in a inline one taht I can adjust the pressure down, and then the FMU would boost it back up under boost. I just don't know how to bypass the stock regulator. I was thinking of removing the spring and put a regulator in line on the return hose.
lazey8
Dec 20, 2013 11:15 PM
1986iroc350
Jun 6, 2011 09:48 PM
bowtieboy42
Dec 8, 2009 03:28 PM
1989 5.0 tpi
Nov 14, 2001 02:57 PM
vadrad
Mar 5, 2001 06:55 PM
