Should I gear or spray the 305?
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
I have 2.73 posi (Boo!)
Stock bottom end with 110K miles. Should I spray a 100-150 NX shot or add 3.73s. I'm looking for a better quarter. Or should I say stoplight times?
I don't have the money to replace an engine nor the time. And if being responsible helps, I'd spray maybe once every 2 weeks.
I don't have the money to replace an engine nor the time. And if being responsible helps, I'd spray maybe once every 2 weeks. gears will be there everytime u step on it, u will always feel that gain unlike nitrous which is only there with the flip of a switch or button. With that many miles ur asking for trouble with nitrous also. go with gears, u'll be happier in the long run(no rebuild for a while)
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
what about differences in times with 3.73s compared to spray? my car is a dog out of the hole but puts me in my seat after 3000 and still pulls at 4800.
Your times will definately improve. I know that with the 2.73's the car shifts right before the traps with the 3.73's you'll get a shift a little bit after the eighth so the engine can pull through third too. Here's a little tech to help out too. 3.73's will give you a 37% increase in torque. If the engine make 250 ft-lbs that's like a 92 ft-lb increse. If that torque is being made at 5252 RPM then the HP is equal to the torque(probably not making 250 ft-lbs at 5252 RPM) so we can assume that your HP increase is less than 100 for arguments sake, even though gears do not multiply HP. The lesson here is that your times won't be as good with gears as with juice, but there will be less wear on the system and better reliability.
Doing a gear swap to mine right now and with a 2.73 carrier all you will have to do is order your gears to fit the 2 series carrier...richmond makes a set and through Summit the install kit and gears will run around $303.??..hope I helped
Car: 1992 B4C 1LE
Originally posted by ATOMonkey
Your times will definately improve. I know that with the 2.73's the car shifts right before the traps...
ambainb
Apr 25, 2016 09:21 PM
