How much boost ? OEM block/crank
Old Apr 12, 2002 | 01:57 PM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
I want to buy an ATI with intercooler. I am running about 9.2 to 1 compression.Heard different things about how much boost the block and crank from an 89 L98 can take.The crank has been micropolished and magged.Block has been decked, magged and bored .030.The rest of my mods are below.Any help greatly appreciated.Stewart
Old Apr 12, 2002 | 04:18 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
I think a couple of guys are running about 9lbs intercooled and some are running up to 12lbs. Not really sure if anybody runs 12 or not.
Old Apr 12, 2002 | 04:58 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I believe Willie is running 14psig now on stock crank and rods.
Old Apr 12, 2002 | 05:00 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Double post
Old Apr 12, 2002 | 07:02 PM
maniacc's Avatar
i am running 10#'s of intercooled boost on my stock L98 iroc-z, Willie engine was built for the blower (i.e. lower comp 8.7:1), i don't recall if he running a forged bottom end or not.
later
larry
Old Apr 12, 2002 | 07:18 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I called ATI and they said that they are can sell me 12 rib pullies to replace the 8 rib ones (9lb) on the '91 so that when I make the switch from the 350 to the 412 it will make 14 to 16 psi (they say) with this P1SC. it is a 2 bolt block (w/ARP's), stock 400 crank, "X" mark 5.7" stock rods (w/ARP's), and dished forged TRW's (9.21 w/72cc TFS 23 degrees) and ARP head bolts. I hope she stays together long enough for some dynos and some passes at bandemere.
Old Apr 13, 2002 | 09:43 PM
tacoboy's Avatar
im a big fan of willie's car, plan on actually copying it next summer ... anyway im almost certain it is 9.2 CR with all forged bottom end, not stock, aluminum headed too, l98's that is
Old Apr 14, 2002 | 09:58 AM
BlownBird's Avatar
Stock block, crank, and rods. 15 psi non-intercooled boost. It worked for me, but I have gone to forged internals this year as a precaution. I am still utalizing the stock block, and plan on testing the limits with it.
Old Apr 14, 2002 | 02:25 PM
maniacc's Avatar
tacoboy,
you maybe right but check out this thread https://www.thirdgen.org/techbb2/sho...threadid=74537
but i do know that Willie did change to AFR aluminum heads, earlier this year, which may have changed his compression ratio.
I'll have to give im a shout, and find out.
later
larry
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
skinny z
Oct 5, 2015 06:23 PM
