Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
my sig
Old Oct 21, 2003 | 12:04 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
my sig
it doesnt work why
Old Oct 21, 2003 | 12:11 AM
Dirk's Avatar
TGO Founder/Former Owner
Car: 1992 GTA
What is it supposed to say?
Right now I see:
__________________
Originally posted by level
I hate saying this but when you're asking if you can beat a honda civic you need a better engine
In USER CP > EDIT OPTIONS do you have "Show user's signatures in their posts?" set to YES?
Old Oct 21, 2003 | 10:48 PM
jocww's Avatar
now its working
Old Oct 21, 2003 | 10:49 PM
jocww's Avatar
dont see it and now its not working
Old Oct 21, 2003 | 10:56 PM
JT's Avatar
JT
Community Administrator
It looks set from here, as Dirk mentioned. When you reply to a post, underneath the Your Reply text area, the bottom option is "Show Signature". Make sure you have a check mark in that box whenever you reply, or your signature won't be used for that reply/post. You must not have done so for your last reply, above.
Old Oct 21, 2003 | 11:20 PM
JT's Avatar
JT
This is what i was talking about:
Old Oct 22, 2003 | 08:37 AM
MdFormula350's Avatar
u got the hail smilie in the best position.
Old Oct 22, 2003 | 09:27 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
lol
Old Oct 22, 2003 | 09:17 PM
jocww's Avatar
dont i feel like a right now
Old Oct 22, 2003 | 09:29 PM
jocww's Avatar
do i have to click it every time
Old Oct 22, 2003 | 09:54 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yes, unless you set your User Cp to do it for you everytime.
Old Oct 22, 2003 | 11:08 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
where??
Old Oct 22, 2003 | 11:43 PM
JT's Avatar
JT
i don't think it's an option that can be default to ON, unless the Admins 'adjust' vB.
Old Oct 22, 2003 | 11:45 PM
jocww's Avatar
iroc can u do it for me please
Old Oct 22, 2003 | 11:50 PM
Administrator
Hmmph, I thought we used to have that. Maybe I'm thinking of another site. Oh well, yes you have to click it each time.
Old Oct 23, 2003 | 12:00 AM
JT's Avatar
JT
IROCZTWENTYGR8,
If you want this default to ON (like the Private Message system uses)
1) go into your Admin section
2) go to the Templates section and click on Modify
3) Click on Expand next to the Theme you use
4) Find New Posting Templates selection and click the Expand next to it
5) Find newreply and click the Edit
6) Almost 3/4 down the box find the following:
<input type="checkbox" name="signature" value="yes" $signaturechecked> <b>Show Signature:</b> include your profile signature. Only registered users may have signatures.
Make sure it looks like the above. That will automatically default to signatures ON without the user having to select the box each time they reply.
You will need to do the same for "newthread" as well.
Old Oct 23, 2003 | 12:13 AM
Dirk's Avatar
Car: 1992 GTA
I turned off the auto sig check box a couple days after having VBB installed, due to popular demand.
Old Oct 23, 2003 | 12:17 AM
Administrator
I knew we had it before!!
Old Oct 23, 2003 | 12:24 AM
JT's Avatar
JT
But it was never an individual option of default On or default Off, or option in the user CP, if i am not mistaken. That's why i mentioned the Admins would have to adjust that
That does make sense since it's default to ON normally, and your Private Message section currently still is set to default ON.
Old Oct 23, 2003 | 09:35 PM
AaronIROCZ's Avatar
R u talking to me???
Old Oct 23, 2003 | 09:48 PM
JT's Avatar
JT
i think the user was talking to IROCZTWENTYGR8, one of the Administrators who normally would be able to take care of things like this. But in this case, that isn't possible.
pwdbychevy
Apr 16, 2023 07:27 AM
formula_novice
Sep 5, 2015 03:58 AM
onebadazzsrt
Aug 15, 2015 07:00 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Roshambo
Sep 26, 2001 02:45 AM
