another username change?
Re: another username change?
Done.
I should point out, and not to anyone specific, that we generally only change user names a few times per user. They aren't meant to be changed multiple times.
So anyone wanting a user name change should make sure you'll be happy and stick with it. This can be done, given that we have some (active) users with the same user name since the late 1990s.
Thanks.
Thanks.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
any chance i could get this done? hate to be a bother but the name was a common one i used for an email in high school....so its gotta go lol preferably BluFBdy if its not taken or bigblueqc if the first isnt available please and thank you
I think I wanna jump on this bandwagon. Mine was the name of a car that I no longer own, and, well, now its pointless. If I could I'd like to make it TPImoneypit, it's a little more fitting
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
If you have a minute I have been here for a few years and have got rid of my LS1 a long time ago.
If you can change me to (Fast 383) it would be cool, Thanks!
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Can I get my name changed to 58mark?
I use that name on many forums as a tribute to my Dad and our story linked in my siggy
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I've had Stephen 87 IROC for 10 years now. When you first join, you normally pick something easy or common. I've seen lots of new user names that won't work very well after a year.
Although so many people know me by this user name, I'd like to finally switch it to AlkyIROC. I feel the car has gone through enough changes that this will probably stick for a long time and I've used the user name on other forums.
Done, Stephen.
Done.
Once again, to point out that we generally only change user names once or twice per user. They aren't meant to be changed multiple times. Some of you changing your user name before even having a 1 year anniversary on this forum while others have used the same user name for over 10 years.
