Holley TBI questions
Old Aug 7, 2016 | 01:17 PM
JdubRS's Avatar
I'm wondering if anyone knows more about the Holley 670 cfm replacement TBIs.
-Are there any difference between the Holley main bodies of the 4.3 and the 350?
-On other posts I saw the injectors are kind of a problem and people use the GM injector pods and injectors. Is that a reasonable proposition?
Thanks!
Old Aug 7, 2016 | 05:06 PM
Schurkey's Avatar
Re: Holley TBI questions
Far as I know, the original (first design) Holley injectors--that had the rubber cap over the top of the injector--were the troublemakers.
The second design are OK.
Old Aug 7, 2016 | 05:21 PM
JdubRS's Avatar
I got one off eBay with bad injectors for $70 shipped. Impulse buy.
Old Aug 7, 2016 | 06:05 PM
Is the 670 cfm a higher rating than the OE Rochester piece?
Old Aug 7, 2016 | 06:20 PM
JdubRS's Avatar
Yeah, the Holley is a higher cfm. The stock is around 450 cfm. You can get a little more with the "ultimate" mods. The Holley has a 2" bore while the stock is I think 1-11/16" bore.
Old Aug 7, 2016 | 06:36 PM
Well, good deal for you then JdubRS!
Old Aug 7, 2016 | 06:57 PM
Schurkey's Avatar
Yup, those are the crappy plastic- or rubber-capped early-production style injectors.
These are the newer, better style.
Old Aug 7, 2016 | 07:02 PM
JdubRS's Avatar
Is it true you can use a GM injector pod?
Old Aug 17, 2016 | 04:08 AM
thecaminator's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 350 TBI
Transmission: NWC T5
Axle/Gears: 3.45 9 bolt posi
I've messed around with doing that. The GM injector pod has a locating dowel in the center of it. If it was ground down it would fit perfectly. You in the market for one of these Holley TBIs? I have one I'm trying to get rid of for 300 if you're interested.
Old Aug 17, 2016 | 08:00 AM
JdubRS's Avatar
Thanks for the info. I bought one off eBay with bad injectors and I've read the earlier Holley injector setup isn't great anyway.
Do the Holley TBIs use the same rebuild kits as the GM ones?
htrdbmr
DIY PROM
Jul 8, 2016 06:41 AM
DonW
Carburetors
24
Apr 8, 2016 10:53 PM
Calixbwsx
Apr 5, 2016 03:15 PM
Superblue87Formula
Aftermarket Product Review
Nov 21, 2000 09:56 AM
