What parts of the wiring harness can be removed.
Car: 1986 Firebird Formula all options
Engine: 305 tpi soon to be 383 stroker
Axle/Gears: 4/10
I am swapping my 305 tpi engine for a carbureted Chevy 355 in my 1987 Firebird Formula. I was wondering what wires I can remove because I am getting a little confused. I don't want to cut any wires but I want every wire that isn't needed out. Is there a plug on the inside of the passenger side fender that I can just unplug to get everything like the fuel injector wires out. What are all the wires on the drivers side, is that all the gauge cluster inside. I would like to get the wires cleanly out because my plan is to put that tpi in my 1941 Chevy truck. pictures will come shortly. Thanks for any information.
Axle/Gears: 4/10
Re: What parts of the wiring harness can be removed.
These are the wires on the drivers side.
You can remove the ECM harness entirely,...the one of the pass side. You'll need all the wiring on the drivers side.
Once you remove the TPI ECM your speedo will probably quit working. You can correct this problem by simply grounding the black wire on your VSS buffer or grounding the buffers ground at the C207 connector.
Help wire speedo after ECM removal
https://www.thirdgen.org/forums/elec...edo-after.html
Good luck !
Good luck !
Axle/Gears: 4/10
Okay thanks alot.
Axle/Gears: 4/10
This is the ecm wire in the wheel well how do I unplug it is there a screw or does it pull straight out.
Axle/Gears: 4/10
Is there a special tool I have to use because it will not come out the thing is giving me hell. Haha
No special tools needed to remove the clip.you might need to use a flat blade screw driver to pry it up .
Post 1 shows what the inside looks like.
https://www.thirdgen.org/forums/dfi-...connector.html
Car: 88 Trans am
Axle/Gears: C4 IRS 3.42
1986 Fbird ? Do you have a cable speedo ?
as for hacking the harness, Start here :
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Im in the middle of a similar swap and when I went to remove the maf relays on the drivers side, the wires were entangled with another harness that needed to remain in the vehicle preventing me from removing without cutting many wires. something to look out for.
Axle/Gears: 4/10
What do I do now because the headlights aren't working and nothing electric inside the is working. Was I not supposed to take the whole ECM plug off. what do I do now?
The headlights and interior gets power through c100. Not sure if this is the same as 86 but here’s a pinout of 87 c100.
http://www.austinthirdgen.org/mkport..._1987_C100.gif
Axle/Gears: 4/10
Where is that located?
Axle/Gears: 4/10
Is that c100 that picture I posted up top or can I take those out.
Axle/Gears: 4/10
What is post #2 can that be removed?
zaxanllc (05-03-2021)
Ops and fuel pump wiring schematic
https://www.thirdgen.org/forums/carb...fuel-pump.html
Tcc lockup information
https://www.thirdgen.org/forums/tran...up-switch.html
michael
17
06-25-2015 08:36 PM
Ronny
DIY PROM
08-10-2005 03:31 PM
