Boost Controllers... Opinions Wanted
Old 03-17-2019, 11:21 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
What are you Turbo guys using for boost controllers?
Or are you simply running offf wastegate spring pressure?
please chime in...
Old 03-17-2019, 11:34 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
Re: Boost Controllers... Opinions Wanted
i use a grimmspeed boost controller, works pretty good.
Old 03-18-2019, 06:26 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
I have an older ams-500. Its ok. My friends run boost leash and i like it better
Old 03-18-2019, 08:48 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I ran the SCG-1 (wideband and boost control) it worked great, only sold since i went with MS3pro and use it for boost control.
Jay
Old 03-18-2019, 12:50 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i had a greddy on my srt4 . worked great
Old 03-18-2019, 01:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I ran the turboXS manual one too on my first twin setup and my remote turbo 305. Works good for the first couple turns, usually 1 psi per turn. 3-4 turns is safe. After that sneak up on it. Half turn may start to get 1-2 psi
Old 03-19-2019, 12:22 PM
Street Lethal's Avatar
Yeah those are expensive, but well worth it.
- Rob
Old 03-19-2019, 01:26 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
- Rob
~ 560 retail for the boost leash. Its a pretty good deal. The AMS 500 V2 is 750 but is similar in that its graph based vs time
i have the V1 AMS 500 which is 450$ and it has adjustable ramp rate of boost psi per second and two stages, but only 1 stage uses the ramp rate
its simple and does seem to work but hard to tell how well the ramp works. I like setting it up for launch boost that you engage on a trans brake and on release of brake it will enter your second stage which will be your max target boost with ramp rate
on the street you can cruise around on gate spring boost and when you need big boost, put the second stage on a switch, so its always available if you need it
Old 03-19-2019, 08:31 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I going to be using a Holley Hp for my nitrous controller, yes I know its not the same.
But it also controls timing and datalogs.
And wasn't that much more expensive than buying all the components together
Old 03-19-2019, 09:07 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
This is great guys,
I’ve got reading to do
Old 03-19-2019, 11:20 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Anybody have experience with G-Force unit?
Looks like they are out of Australia...
But the price is right $335 AUD, which is like $315 CAN
https://www.gfb.com.au/products/boos...troller-detail
Old 03-20-2019, 01:03 AM
Kingtal0n's Avatar
Car: 240sx
Engine: whatever works
Transmission: 4l80e this year
Axle/Gears: 3.512
fifteen turbo cars and I always use greddy profec B spec-ii
Units are $150~200 used
it is very basic open loop controller, and also powerful (start boost)
however there are much more powerful high frequency drivers available with better control and even closed loop available. Honestly these days you want the ECU to do this job so it can both monitor and control boost.
Old 03-20-2019, 04:36 AM
3.4 grape's Avatar
Car: 94 Camaro
Engine: 3.5 turbo
Transmission: Performabuilt 4l60E
Axle/Gears: Strange rear, 3.42
I just installed one in my car. This is my first electronic boost controller, so I can't compare to other units. I did some research though before I purchased it, and for the price and options, I chose the GFB. So far, very happy with the controller. I bought mine off amazon for under $300.
Old 03-20-2019, 06:16 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Looks like it could work well enough. Single solenoid for increasing boost i guess, no secondary solenoid for decreasing supply so your control may not be as good or accurate as a two solenoid deal. But for the money it seems sufficient
Old 03-30-2019, 12:17 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
I use a midget. Wrap him up in some heat shielding, give him a pair of gloves, and pay him in free beer. IT's cheap, easy, and the little dude does a good job.
Old 04-05-2019, 09:06 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:42
For the price, I also went with the G-force 2. Its very simple to setup,save 6 presets and scramble.Im considering selling mine for the new version that has boostcut safety from wideband o2. For anyone looking for a affordable ebc with very easy display setup then I highly recommend these.Plus..the customer service is outstanding.
Old 04-08-2019, 12:21 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Ran a ball and spring style manual boost controller for a few years in two of my cars. Worked great. Much quicker spool than just running a stiffer WG spring. The advantage being the WG doesn't even start cracking open until right at your boost set point. Now both are running GM boost control solenoids controlled directly with a Megasquirt ECU. No experience with stand alone electronic controllers. Ha, I know I shouldn't have even chimed in!
Drew
06-10-2010 01:17 PM
ttypecamaro
Group Purchases
09-28-2006 11:52 PM
ttypecamaro
04-09-2006 01:31 PM
rx7speed
02-20-2003 11:53 AM
qazd
10-08-2001 10:41 PM
Quick Reply: Boost Controllers... Opinions Wanted
