maf car
Old 05-22-2019, 11:07 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
maf car
350 showing lean at idle.
ZZ4 cam 24 lb injectors
Not sure how to add fuel at low RPMs.
Any help appreciated.
Old 05-22-2019, 11:47 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: maf car
You need to add fuel in maf 1
Old 05-22-2019, 11:53 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Re: maf car
Yup maf table 1. Maybe 2 depending how much rpm and load. Kinda watch rpm and current logged maf flow value and go to that value in table 1 or 2, and increase the values at and around whatever your logged value was.
like 1200 rpm 16 grams/s... go to table 1 and find where 16 is and increase the cell above and below some
Old 05-23-2019, 10:05 AM
ULTM8Z's Avatar
Re: maf car
Don,
What kind of injectors? P/N?
Old 05-23-2019, 12:23 PM
Dyno Don's Avatar
Re: maf car
Bosch SVO 24's
The heated 02 just lays flat until I blip the throttle.
Old 05-23-2019, 02:15 PM
ULTM8Z's Avatar
Re: maf car
Are these the Bosch IIIs? Any way to snap a photo of them?
O2 stays flat at what voltage?
Anyway to get a tunerpro datalog?
Old 05-24-2019, 09:29 AM
Dyno Don's Avatar
Re: maf car
But the tops are blue instead of red and 02 at 100-200
Old 05-24-2019, 10:25 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: maf car
Quick try is move maf scalar 1 up two values and see what happens lol
Old 05-24-2019, 12:25 PM
ULTM8Z's Avatar
Re: maf car
I'm helping someone with those same injectors. Should probably make sure you have the right voltage offsets for them...
http://forum.efidynotuning.com/viewtopic.php?t=464
I think these are ones...
Old 05-25-2019, 01:53 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: maf car
I've added fuel in the MAF table 1 and 2. I've dropped the injector constant from 24lbs down to 16lbs. The O2 at idle is still in 100mv range or less, and BLM is at 160.
But as soon as you open the throttle, the heated O2 responds normally and does a good sine wave.
Old 05-25-2019, 02:14 PM
ULTM8Z's Avatar
Re: maf car
Kevin,
What is the voltage at the keyed ignition switch vs voltage at the battery when the engine is at idle?
It sounds like you may have some sort of voltage drop issue thats screwing around with the ECMs calculation of final base pulse width.
Old 05-25-2019, 02:23 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: maf car
That or a bad o2? It should be reading if heated
Old 05-25-2019, 02:36 PM
ULTM8Z's Avatar
Re: maf car
It's just strange that it comes to life just off idle. What comes to mind is system voltage that can often be low at idle speeds if the alternator is bad. Or if theres a large voltage drop across the ignition switch which can screw around with the ECM .
Old 05-25-2019, 02:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: maf car
Yeah that makes sense. Maybe get a reading at the plug at idle see what it is
Old 05-25-2019, 03:37 PM
ULTM8Z's Avatar
Re: maf car
o2 plug and the injector plugs...
Old 05-26-2019, 02:11 PM
tequilaboy's Avatar
Re: maf car
Assume car is still in open loop. Does car have still have an AIR pump (California)? Is Air Controlled = Not Diverted and Air Switched to Port = True? This can shift O2 and WB lean by about 1-1.5 points (if available). Get it into closed loop and give the fuel trims a chance to adjust before passing judgement.
Old 05-26-2019, 03:09 PM
Kevin91Z's Avatar
Re: maf car
Yes it has an air pump. I didnt change those settings so they should still be true. Yes its going into closed loop and still running lean, with BLM at 160 at idle.
liquidh8
DIY PROM
06-11-2010 09:39 AM
Grumpy
DIY PROM
24
06-07-2002 10:15 AM
Reno
09-01-2001 10:34 AM
Quick Reply: maf car
