FRESH REBUILT 700 FLUID SUGGESTIONS
Old 07-16-2019, 03:28 PM
Dan Baker's Avatar
I just picked up tranny. And the rebuilder. Told me to just use type f transmission fluid.
he as rebuilt tyranny’s for 35 years. Super reputable tranny builder. Rebuilds for a lot of hot rods. Anyway I ask again. He said type f. I think he was losing is mind. I’m asking y’alls thoughts on this.
He did upgrade transmission considerably.
Old 07-16-2019, 03:55 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: FRESH REBUILT 700 FLUID SUGGESTIONS
I went with Mobil 1 ATF and flushed my 120,000 mile trans and got that in there. Works great. I prefer synthetic.
Old 07-16-2019, 04:31 PM
Dan Baker's Avatar
I reading that most recommend type f in th350. But not 700r4 with tcc lock up
Old 07-16-2019, 09:34 PM
Pro Built Automatics's Avatar
Type F oil was designed for when they were using Asbestos in the clutches. With paper type clutches (since 1978) you use Dexron type oil. If you want firmer shifts, you modify the circuitry, feed hole sizes, servos, accumulators, line pressure and line rise, etc., not using the wrong oil. Type F makes the shifts firmer by allowing the clutches to slip more then apply at the end of the shift to give the firmer shift feel. Dexron type oil has the clutches starting to apply earlier in the shift for a smoother apply. This will make the transmission last longer. According to Borg Warner, type F is a better "static clutch" (neutral to drive) holding apply oil, however type F has a lower "dynamic clutch" apply (shifting clutch) holding ability.
Dan Baker (07-17-2019)
Old 07-16-2019, 11:17 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
ford type F is the go to for the hot rod world. have used in in my 700R4s (nonstock) it works.
Old 07-17-2019, 01:56 AM
I did not say it would not work. There is a better oil that was designed for the type of paper clutches being used. Borg Warner, Raybestos, Alto and others that make these type of paper clutches have never recommended type F.
Old 07-17-2019, 04:31 AM
Dan Baker's Avatar
I called the old man back.the transmission rebuilder. He said. Dan. Why are you questioning me. I said cause your getting purity old. And I thought maybe you where losing it. He found that super amusing. Laughed and laughed. I have known this man for 35+ years. First time I have ever heard him laugh. He basically said shut the **** up and use type F. And hung up. After reading the difference. I understand now.
Old 07-17-2019, 11:41 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
I've always been told mercon 3 and no synthetic. If your builder says to use f use it. He built it and will ultimately stand behind it.
Old 07-17-2019, 04:00 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Use the fluid specified by the guy who built the transmission. Not sure why you'd even come here to ask random forum posters this question.
Old 07-18-2019, 02:02 PM
WOW... Random forum poster.... Hmmm.....
The following 2 users liked this post by Pro Built Automatics:
NoEmissions84TA (07-18-2019), T.L. (07-18-2019)
Old 07-18-2019, 03:06 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Lol. We are all just randoms...
Old 07-24-2019, 02:27 PM
Dan Baker's Avatar
The amount of craft experience on this particular forum. Is extremely high. And the reason I asked. Was in the original post. Transmission builder is getting some age on him. And I wanted some real world advise. From some of the smartest (random forum poster).
Old 07-24-2019, 02:43 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Nobody here but ProBuilt builds transmissions for a living. He would be the one to give you the best answer. That said. My builder specifies mercon 3. Nothing else. Most here will give you that same answer. Can you use what you are? Sure. But the simple fact of you coming here second guessing your builders advice says your not 100% confident in his answer. If you used mercon 3 I'm sure it would not be detrimental. Either way it's your choice.
Old 07-24-2019, 03:10 PM
Dan Baker's Avatar
I’m not 100% in anybody’s opinion. I just don’t like you. Your a smart ***.
Old 07-24-2019, 03:18 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Well if facts hurt your feelings then that's tough **** for you isnt it? If you cant figure out such a simple thing as what transmission fluid to run ask a professional. You have asked. We told you. You still dont listen. Move on.
Old 07-24-2019, 03:35 PM
GeneralDisorder's Avatar
I have a 92 Ligenfelter built 700R4 designed for their stage three 383 build (car was built in 92 immediately after purchase), and has had type F it's entire life. I bought it from the original owner and put it in my 86 Trans Am with Amsoil Super Shift - which is basically synthetic Type F from what I understand. Works excellent. I've had the pan off multiple times and never any clutch material or anything on the magnet. It's really a very sweet transmission. Designed to handle 550 HP is what I'm told. It has excellent part throttle shifts and firm full throttle shifts.
GD
Old 07-24-2019, 03:47 PM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
I still don't follow. If you don't trust your trans builder's knowledge/experience/recommendations, I question why you'd ever have him build your transmission in the first place. He's the guy who has to stand behind his work, not anyone here telling you otherwise.
But that's just me; good luck with the longevity of your transmission in the future.
Old 07-24-2019, 04:09 PM
Dan Baker's Avatar
GD
Thank you. I really appreciate your answer. I was just trying to find someone else using type F. In a 700 with some time on the road with type f.
Old 07-24-2019, 04:12 PM
Dan Baker's Avatar
I tell you facts. Lol self proclaimed moderator.
Old 07-24-2019, 04:17 PM
Dan Baker's Avatar
I don’t trust anyone But god. Everyone must pay cash. Lol. I was just pickin at the self proclaimed moderator. This was a dead thread until. I read smart *** comments.
I used type F. It’s already installed. Runs good time will tell about the type F. Longevity I drive the car 300 miles a year max. So it may be a longtime on the longevity answer.
Old 07-24-2019, 04:54 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Someone who doesnt know a simple thing as what tranny fluid to use, I dont want facts from, you can keep them. The board thanks you for wasting it's time with moronic questions you already had answers too.Yours truly...
Old 07-24-2019, 05:15 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
"PRO Built" what is your opinion on "Lube Guard" transmission fluid supplement? I heard decades ago, it supplements for the Whale Oil that was removed from ATF, pursuit to the international whaling ban.
FWIW I have used it for decades, changing the Fluid and filter, on all my vehicles, every 30,000 miles. They have 200,000-300,000 mile without trans problems.
What about these new 8-10 speed At's?
Old 07-24-2019, 05:37 PM
OrangeBird's Avatar
Car: 1989 Firebird
[QUOTE=Dan Baker;6316244]I don’t trust anyone But god. Everyone must pay cash. Lol. I was just pickin at the self proclaimed moderator. This was a dead thread until. I read smart *** comments.
While discussing trust , Dana (Pro Built) is the board's go to source on 700R4 info , trustworthy as ol "Honest Abe" , so , pretty darned close to God himself . He stated that type F was used with Asbestos clutches and Mercon with paper .
This naturally begs the question ; if your builder specified type F does that mean he put Asbestos (or some type of Asbestos substitute) clutches in it ?
Since it appears to be the material the clutches are made of that determines which fluid is best for them , wouldn't some piece of mind come from knowing exactly what material the clutches are made from ?
Old 07-25-2019, 11:37 AM
"PRO Built" what is your opinion on "Lube Guard" transmission fluid supplement? I heard decades ago, it supplements for the Whale Oil that was removed from ATF, pursuit to the international whaling ban".
Yes, that is true, from what I have been able to find out over the years. It took a long time (decades) for the oil techs to come up with an oil that is just as good as the Sperm Whale Oil. The people that I know in this industry, use Lube Gard.
327_TPI_77_Maro
03-22-2007 03:34 PM
spearson
06-08-2001 09:39 PM
Quick Reply: FRESH REBUILT 700 FLUID SUGGESTIONS
