South Central Region Board for the states of Texas, Oklahoma, and Louisana.
? about vac. diagrams
Old Dec 11, 2005 | 02:00 AM
dizmo's Avatar
Car: 88 camaro
Engine: 305 non ho
Transmission: not sure
first off im from the se side of houston and im new to the site so hi all . and i have a ?. my heater is not working . the fan blows. i replaced the temp control valve . and the hoses get hot just there is no hot air . im thinking a vacume hose is bad or has came off. the heater core should not be back cause there is fluid flowing throught it . so any help, i would be greatful because its getting really cold out there. o and also if any one has a pis or can send me a pic of the vacuum diagram for an 88 camaro. 305 tbi thank you very much
chris
Old Dec 11, 2005 | 08:55 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Welcome to the board!
If nobody can help, try one of the "tech boards" such as "Cooling" (since it has to do with water flow)-- "Body and Interior" --or the general engine tech board--OR do a search enter the word heater or some variation of that. I'm sure U will find the onfo U need!
One thing to make sure of is the bottom levr on the dash "temp control" when U move it from left to right (cold to hot) it is a cable that opens the trap door to let the heat actually in from the heater core. If U don't feel a little resistance while moving it the cable may be broken or something. Also, check the hoses past the heater control valve to make surethat it is actually opening--the hoses leading to it should be warm as (U said they were), but if they are not on the other side of the valve , something not letting th valve open.
U can always hook up a tempory vacuum hose to see if the valve is working right.
Old Dec 11, 2005 | 09:01 AM
dizmo's Avatar
Car: 88 camaro
Engine: 305 non ho
cool thanks zap ill do that tech forum . and thanks for the info
Old Dec 11, 2005 | 01:45 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Let us know how it turns out--we all learn from each other experiances!
Old Dec 12, 2005 | 01:56 PM
dizmo's Avatar
Car: 88 camaro
Engine: 305 non ho
hey not sure what it is yet but got some ideas so . i think im going to change the thermstat. and hope for the best lol thanks again for pointing me in the right direction
Old Dec 12, 2005 | 01:59 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Excuse my ignorance, but what would the thermostat have to do with the heater blowing hot?
Old Dec 13, 2005 | 12:03 PM
dizmo's Avatar
Car: 88 camaro
Engine: 305 non ho
i have no clue someone said that it may be stuck open. which would actually make a little since. consitering that the temp never gets over the first mark on the temp gauge. so for the price its whorth a try right lol.
Old Dec 13, 2005 | 12:34 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Even if it was stuck open, once the engine got up to operating temp, U would feel heat if the heating system was working correctly.
Old Dec 13, 2005 | 04:00 PM
dizmo's Avatar
Car: 88 camaro
Engine: 305 non ho
yea i know . but that sucks i just dont feel like relaceing a heater core right now im lazy . mainly cause i work nights and yea i work nights lol
Old Dec 13, 2005 | 04:17 PM
Zap Racing's Avatar
Car: 1989 IROC Z-28
I'm not so sure it's the heater core--they either work or not usually because they leak or don't leak. I guess they can clog up but I have never heard of one doing that.
What part of town do U live in?
OOps, I see U live in Alvin--was gonna say if U wanna swing by the house I'd be glad to look at it.
Does the hose in between the firewall and the heater control valve get hot when engine is warm and heater is turned on?
Have U posted this on the cooling board?
Old Dec 14, 2005 | 03:55 AM
dizmo's Avatar
Car: 88 camaro
Engine: 305 non ho
they all get hot . to tghe radiator and to the temp. control vavle. all hose doing with the heater core get hot . so im acually clueless. thats why i thought it was a vacuum hose. but someone said it couldnt be a vacuum hose so yea im im lost
Old Dec 14, 2005 | 09:17 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Have U checked to see if the trap door is opening when U slide the temp control **** all the way to the right? Do U hear it opening and closing?
Old Dec 14, 2005 | 03:20 PM
dizmo's Avatar
Car: 88 camaro
Engine: 305 non ho
yea i acctually opened the bottom of that area to see if there were any vacuum hoses . and the cable is conected and it does move. im also thinking the whole thing in the dash may be bad . i have no clue . sooling systems are not my thing. i just keep it running lol . im going to have to go to my dad . damnit . o well i give it 10 min. and he will tell me what it is lol . machnic for 30 someodd years . but well . i let you know what it turns out to be ok take it easy . later man
InfernalVortex
Apr 20, 2021 11:31 AM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
rjcme
Sep 5, 2015 01:23 PM
