South West Region South West regional discussion board.
How Much Respect Does the L98 Deserve?
Old Jan 19, 2004 | 11:50 AM
OMINOUS_87's Avatar
Opinions needed?
My opinion is below:
Old Jan 19, 2004 | 11:54 AM
esams's Avatar
Man why you gotta be so mean to my ****? No love to give at all? That stuff served me well !
Old Jan 19, 2004 | 11:59 AM
OMINOUS_87's Avatar
Yeah ok!
Considering the condition of the bearings, deep grooves showing that some metal shavings passed through the oiling system, and the fact that one of the slugs fell out with a cracked top ring.
Hmmmmmmmmm?
Old Jan 19, 2004 | 12:06 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
hey.......
that crank coulda made a good door stop.
Old Jan 19, 2004 | 12:38 PM
OMINOUS_87's Avatar
Actually for a minute we were having delusions of grandeur and thinking of turning it into some nice wall art.
But the dumpster was just so damn close!!!
Old Jan 19, 2004 | 01:48 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
hehe, yea..
ever since i saw the engineblock/piston glass topped coffee table, ive been wanting to make one.... but it wouldnt be right to make one out of iron.. i need a busted alum block and some nice worn alum race rods/pistons...
Old Jan 21, 2004 | 07:57 AM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
It's all yours guys...
Old Jan 21, 2004 | 10:57 AM
OMINOUS_87's Avatar
Anyone care to venture a guess as to what may have gone through the motor or why?
You will be shocked when I tell you.
Old Jan 21, 2004 | 11:23 AM
camaro-mayhem's Avatar
Car: Camaro
Engine: 355c.i.
Transmission: th350
a bra
Old Jan 21, 2004 | 02:46 PM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
arghh the suspense is killing me!
Old Jan 21, 2004 | 03:55 PM
esams's Avatar
Knowing its history, I'd have to say.............
NO F-IN CLUE !
Stop teasing and tell us man!
Old Jan 21, 2004 | 04:22 PM
82Z28NAZ
Guest
Posts: n/a
I'd have to guess a connecting rod.
Old Jan 21, 2004 | 06:26 PM
90RS305's Avatar
That can of Bud-Light?
Old Jan 21, 2004 | 06:36 PM
OMINOUS_87's Avatar
No but I see we have the same taste in beverages!
Old Jan 21, 2004 | 06:44 PM
90RS305's Avatar
Old Jan 21, 2004 | 06:47 PM
OMINOUS_87's Avatar
Obviously it was metal shavings of some type.
But here comes some good old fashion tech content for yall.
The so called oil cooler in most of our applications is the devils spawn. The internals of the oil cooler are designed in such a manner that they trap engine debris before the debris hits the filter, not good huh? It gets worse. The oiling system is also setup with a bypass of the filter. The bypass is used on cold starts when the oil is to thick to pump through the filter or if by chance the filter gets clogged.
So the situation is as follows:
1. Oil cooler traps engine debris
2. Under certain circumstance this debris is pumped through the oiling system while bypassing the filter
3. This is most likely the reason that Eriks bearings had excessive wear and damage.
This buildup was witnessed in both Eriks cooler along with mine.
So if anyone ever does a buildup, do not reinstall the factory cooler, for the above mentioned obvious reasons.
Old Jan 21, 2004 | 07:21 PM
82Z28NAZ
Guest
Posts: n/a
I sold one of those on Ebay a while back. I noticed some crud that was built up inside of it also. After some research on the "oil cooler" (it looks as though it was actually designed to warm up the oil) I decided that it served no practical purpose and sold it.
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Linson
Sep 21, 2015 01:08 PM
