Won't start
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
I can almost guarantee it's one of two things...
1) You need to replace your ignition switch. I was having that SAME problem with mine, everything worked fine but it just wouldn't turn over (no click or nothin') Replaced the switch and it's worked great ever since...
2) The ignition chip (take a look at your key) reader is starting to go bad. I had a friend with a 1990 IROC that had to replace the chip reader and it too has worked just fine ever since...
HTH!!
Bruce (90RS305)
HTH!!
Bruce (90RS305)
Guest
Posts: n/a
I kinda thought that's what it might be next so I got a new switch. How the hell do you get to that back screw? That one's a booger.
HTH!!
Bruce (90RS305)
HTH!!
Bruce (90RS305)
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Originally posted by 82Z28NAZ
what am I looking for on the key? worn chip? it looks fine
Car: 1989 Iroc-Z
Engine: 5.7L TPI
If the VATs Control module does not get the proper response from the the resistor in the key, it will prevent the ECM from sending a signal to the starter enable relay and will not send a pulse to the fuel injectors. When this happens, the security light, which is located to the left of the service engine soon light, will come on and stay on until the correct resistance is seen by the VATS Module.
Well,
I had this happen to my 1979 Trans Am convertible a few years ago!
I had power to the lights, radio, but no ignition! I tracked it down to a battery cable going to the starter. It was not in the right place (as I wasn't the original owner, the one before me replaced it with a generic one, and didn't run it in the same way that GM did), and would hit the block, causing it to arc, and blow out my module in the distributor!
Of coarse, it took me about 3 tries to figure this out (by this, I mean 3 modules!!!!
) And yes, I replace the battery cable with the correct one, and ran it right!!
This might be your problem as well!
Good luck,
George
) And yes, I replace the battery cable with the correct one, and ran it right!!This might be your problem as well!
Good luck,
George
Bruce (90RS305)
Ohh and on the ignition switch I just had it professionally done ($150) and the funny thing is he over-rid the clutch switch so now I can start my car without the pedal depressed...
you have an automatic right? try the neutral safety switch. try turning the key while wiggling the gear shifter around....
the neutral safety switch is under the shifter console, on the side of the shifter. it has a big plug that goes into it..
gl...
gl...
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Try this simple little test, if you have a pellet in the key. Take a multimeter and set it to OHM's, touch the meter's probes to the contacts on the key and write down the resistance value. Next, look under the dash for two yellow wires in a black wrap or two white wires in a orange wrap (newer style) that connect to a two wire connector (wires are purple/yellow & black/white. Disconnect that harness and put the key in the lock cylinder in the "OFF" position. Put the meter probes in the connector coming down the steering column and measure the resistance value in the key. If the value is different, you have a problem with the lock cylinder. If the value is the same, your problem is elsewhere.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hey 82Z28NAZ,
If it does turn out to be the lock cylinder, you can fix it a lot cheaper by doing it yourself. Either way, good luck on it.
Guest
Posts: n/a
I know I can do the lock cylinder a lot cheaper. But the thing is you still have to go to GM and get a key cut with the stupid chip in it. It's not a matter of cost. It's a matter of time. And that my friend is running very shallow at the moment. I'll be lucky if I can make it before it becomes a huge problem.
BTW.. it cost me all of $25 to replace the ignition switch.
Car: A Camaro
Engine: Weak
Transmission: Weaker
I'm not sure if this has been touched or not, but check the wiring going to the starter, more than likely there's an inline fuse that melts when too much current is passed through it. Also, starter wiring on thirdgens has been known to be problematic. My ex-girlfriend's V6 RS set on fire in the driveway, the wiring for the starter caught on fire somehow. Put a multi-meter across the starter leads and have someone turn the key and see if you're getting power to it. There's only a few steps to the starter circuit and as I recall it's just:
Key
VATS
Clutch/Neutral safety switch
Starter
Those are going to be your prime suspects, but I'd be willing to bet that some of that 12 year old wiring that powers the most powerful electrical device in the car is somehow fried.
Good luck man
Tony
Key
VATS
Starter
Good luck man
Tony
Car: 1987 IROC-Z
Here is one that is hardly ever noted but causes so many problems it's ridiculouse.
"IF YOU HAVE TPI"
When you turn your key to the on position does the SES light come on OR do you hear the fuel pump prime? If not I am 99% sure it is the fuse that is right next to you battery.
There is a 20 amp fuse that powers you ECM AND your fuel pump, if it burns out then you will have power to everything & spark, but the car wont run due tot he ecm technically being dead & the pump not feeding fuel.
However W/O VATS the car should turn over, just not start up. but if you have VATS the car wont even turn over.
Give it a try, go check it out and see if it's burnt, replace it if it is and your problem will be gone.
"IF YOU HAVE TPI"
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
there is also a vats fuse on the right hand side of the stearing calum that is next to the stupid thing that makes all that noise when you have your keys in the ingnition and the car is not running in fact it is esay to find it just fallow the noise you here when you turn the key over it should be a ten amp fuse that is to your vats along with some other fuses i don't remember what they were for.
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
VATS will not prevent the car from turning over. Id check the ignition switch and go from there.
Car: 89 camaro rs
Transmission: th350
