Big header swap problem, help!
Car: A Camaro
Engine: Weak
Transmission: Weaker
Hey guys
So I woke up this morning and decided to take off the ole' exhaust manifolds and put on the headers that I've had for about a year now. Everything is going great until I get to the last drivers side bolt. I go to feel for it and it's already loose. Confused, I take it out and sure enough, it's sheared in half. The threads are still in the block and there's no thread sticking out. I don't know what to do here, this f-ing sucks. Anyone good with a drill and an extractor? Are we going to have to helicoil it? Any help would be greatly appreciated or recommendations for a shop to take it to.
Tony
Tony
Car: Trans Am
Engine: chevy 350
You might be able to getaway without that bolt but sooner or later you'll get a leak
Is this drivers side towards the front or by the firwall? wich one is it exactly??? Looks like the only option is to pull the head and heli coil it. hell better than it being a stripped spark plug hole.
Car: Trans Am
Engine: chevy 350
of all the bolts the bolt from hell has to be the one that snaped. your gonna have to pull off the head dude unless you can pull a miracle.
Car: Trans Am
Engine: chevy 350
Originally posted by 90_WS6_Formula
yep... you're going to have to pull the head. Hard to drill where it's at.
Unless you can get a punch back there to tap it around. It may not be loose though.
Car: Sexy
Engine: Stock
Transmission: Slipping
You can be pretty sure that if the bolt broke, it's because it's in there tight. Good luck taking it out with a screwdriver.
Car: Trans Am
Engine: chevy 350
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
pull off the manifold since u broke the head off,and maybe you will see some threads then.
Car: `86 SS / `87 SS
Tony,
I would get a small punch and try & drive the bolt out with it.
And you might get it to rotate out.
I'm not far from ASU, so I might be able to lend a hand. Good luck with it.
Code:
_ /____ punch this way / \ \ | | \ _ /
Car: Trans Am
Engine: chevy 350
Transmission: t-5
yeah,gotta hope though right. if not,anyway to get mroe room at it by lowing the motor some, or rain it up some?
Car: A Camaro
Engine: Weak
Yeah, when I found it was broke, I was praying that when I took the manifold off there would at least be a little bit of thread or something left sticking out of the block...no dice. It's about a millimeter into the block
. I'm just gonna try to run the car without the bolt for now and if that falls through I have a shop in mind to take it to. F-ing A, why does this crap always happen to me?
. I'm just gonna try to run the car without the bolt for now and if that falls through I have a shop in mind to take it to. F-ing A, why does this crap always happen to me? Senior Member
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
I am not 100% sure on this but I think that you don't have to use that bolt hole for the headers. There are two bolt holes in that back of the head. If I am right the one that you brook is the hole farthest away from the front and the hole that you need to use is closer to the front. I will double check for you when I go out to my car.
Or you can just go outside to your car and look for yourself. IF it is stuck to the hole closer to the exhoust port then you are ****ed. I have been driving my car with out that bolt on it for a month now and it still doesn't leak
, But I think that sooner or later it will.
, But I think that sooner or later it will. Supreme Member
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
You can live without one bolt as long as the others are nice and tight and your header flange is thick and flat. Just be sure to use a GOOD quality gasket, like one of those copper ones, or the metal empregnated composite ones.
Car: Sexy
Engine: Stock
If his SLP headers are anything like mine, they tick if that bolt is even a little bit loose. I keep a 3/8" wrench in my glove box for this reason.
Car: Trans Am
Engine: chevy 350
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Thats what I had to do in my Bronco. Damn thing scared me too much with if off
