Need dead engine accessories
Car: Sexy
Engine: Stock
Transmission: Slipping
I got the mockup motor set up for my turbo header project but I need some accessories to bolt up to check clearances.
I'll pay for a set of later model (A/C on the passenger's side, alternator on the driver's) serpentine brackets but if anyone has a dead alternator, PS pump, AIR pump, or water pump they wanna get rid of I'll take em off your hands.
Car: '85 Trans Am FAILBIRD
Axle/Gears: 4th gen torsen 3.42
I've got everything you need. just pulled all the serp stuff off my car. Was originally from a '89 IROC. Let me know exactly what you need.
Car: Sexy
Engine: Stock
I need everything I listed, except an A/C compressor (sorry Eric.
). I have two A/C compressors already.
Brackets
AIR pump
Alternator
Power steering pump
Water pump
). I have two A/C compressors already.Brackets
AIR pump
Alternator
Power steering pump
Water pump
ok well I have the brackets.
have a busted alternator, and a near-new alternator.
have the reverse-flow water pump, almost new.
AIR pump is long gone (I have the correct belt for bypassing this).
Power steering pump got re-used in my current setup, but I've got the Serp pulley for it.
Car: Sexy
Engine: Stock
Whoa. You're in MA, it'd cost a stupid amount to ship all that heavy stuff. How about just the brackets?
this might be worthwhile:
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
that's cheaper than I was thinking.
From: Tucson AZ where the 3k ft of elevation kills your time
Car: 89 camaro rs
Engine: 383 .06 over
Transmission: th350
Axle/Gears: 3.73 10 bolt
I have the ps pump and alt bracket with a alt that still works but has a busted housing at my work i also have a air pump somewhere and I think i got a water pump i know i have the stock water pump pulley( i gave my stock crank pulley to chris) and i have a ps pump for it, almost the hole kit
Give me a call and let me know what you need.
Give me a call and let me know what you need. Thread
