South West Region South West regional discussion board.
Need Help Fast!!!!
Old Jul 29, 2006 | 06:22 PM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Need Help Fast!!!!
I have a great need to borrow a Prom chip for a SD 350....I have ordered one but it will not be here for a week I have till the 2nd to pass emissions and the 305 Prom is not adjusting spark and fuel curve correctly to get it thru emissions.....Does any onw have one i can borrow to try to go thru emissions Monday?
Old Jul 29, 2006 | 09:53 PM
toms84ss's Avatar
PM sent Preston.
Old Jul 29, 2006 | 11:25 PM
Car: 85 87 87 91 92
Thanks for the offer bro and i might just have to take you up on it...But i think it is just a matter of a chip....So I am going to try that route first....
Old Jul 30, 2006 | 01:03 AM
1Bad3rdGen's Avatar
Car: 92 Firebird Convert & 91 Camaro RS
Engine: 305 L03 TBI
Transmission: 700r4 & T5
Axle/Gears: Stock
i have an ostrich i can let you borrow. all you need is load the files for a sd350. let me know
Martin
Old Jul 30, 2006 | 01:14 AM
Car: 85 87 87 91 92
Martin
dude i have know idea how to or what that is
Old Jul 30, 2006 | 01:36 AM
1Bad3rdGen's Avatar
Engine: 305 L03 TBI
Axle/Gears: Stock
its an emulator for burning proms. instead of burning chips you slap this to a computer and load the correct files. [URL="http://www.moates.net/ostrich-real-time-ecm-emulator-p-57.html"]
check it out
Old Jul 30, 2006 | 02:49 AM
Car: 85 87 87 91 92
check it out
The site seems to have alot of info but what mods are required to hook this thing up? Like i said I have already ordered the correct prom i just am out of time and it is not here......Also there are alot of files in the download section how do i know which to use?
Old Jul 30, 2006 | 01:35 PM
1Bad3rdGen's Avatar
Engine: 305 L03 TBI
Axle/Gears: Stock
it replaces your stock prom. and its as easy to hook up by removing your old prom and putting the ostrich emulator in place. i havent used it yet because the car i plan on using it is getting painted.and for files the onliny thing you need is the correct bin for the engine
Martin
Old Jul 30, 2006 | 02:16 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Preston, I have a 1991 L98 memcal you can borrow. I will need it back when you are done with it.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
