Let's talk about stroking it shall we.......
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
have about a half-dozen hours of research into my investigation into making a stroker motor for my 56 F-100 so I can then sell the tamer ZZ4 in there to Mike to get him up to speed and be somewhat competive
1) 5.7 or 6.0 inch rods
I know that 6.0 rods are better for power, stress, and longetivity (more desirable) but most kits are setup for the 5.7 rods, why? Is it because of clearance issues with the rods and cam/block? For the 6.0 rods do you need to run a special/smaller base circle cam?
2) rods: H or I beam?
The H-beams are stronger but seem to be heavier as well. The H-beam usually are bolted as opposed to the studded I-beam rods. Does the bolted H-beams provide anymore clearance than the I-beam?
3) 383, do they like to rev?
Does the stroker crank like to be spun or does the added weight and polar moments make it not so easily to rev? Will a 4130/4340 crank/rod help keep it together of is that overkill and a cast or 'ESP' crank be sufficient?
4) new 1-piece RMS cranks (like the eagle 4340)
do the internally balanced cranks still require a 400 balancer and special flywheel? It is a pretty silly question but maybe I'm not understanding soemthing completely. The cheaper cast or cast steel cranks are mostly still externally balanced and while, 1/2-1/3 the price, require the 400 balance and flexplate.
5) Eagle Cranks
good/decent quality or avoid at any cost? Any balance or other quality issues.
6) Camshaft
something in the 236-340 I / 240-250 E with .540-.550 lift sound about right along with a HSR or miniram. I'm looking for 440-480 crank-HP @5700-5800 RPM
7) anybody got a good rebuildable 1-piece RMS std bore 350 4-bolt roller block avalable? heck, I'll even take a good 1-piece RMS std bore 2-bolt bare roller block.
I still have to finish the EFI harness in the truck then come summer I get to work on its new engine. My goal is to take it to Fontana and Beat Vincent with a slice of Don....with my Ford
-James "doing my part for the economy..."
5) Eagle Cranks
6) Camshaft
Re: Let's talk about stroking it shall we.......
5) Eagle Cranks
6) Camshaft
James you worked me on this post
Jerry
Engine: 3.6L
Thanks Jerry. I appreciate your response as I have much respect for your experience.
As for the cranks Callies (dragon slayer line) has a reasonable priced crank. I haven't got much feedback on scat's line of cranks as the eagle line seems to be more widely available. I guess 'll talk to my machine shop and see what their experience has been.
6.0 rods:
I have seen where it looks like the oil ring lands appear to intersect the wrist pin hole. Is there any reason a 6.0 rods will create a longetivity isue with regard to oil control/consumption? Are the 6.0 rods geared more for a race engine that will be torn down more frequently and therfor long-term durability is less a concern?
Since the truck doesn't have to pass smog I can do almost anything to it and because it only sees a couple thousand miles a year, gas is less an issue. I will be installing a 21-gallon tank and most likely a 4-link in the rear if I can find the time.
But who's to say if I didn't install it in my camaro for a week or two to take care of some bidness
6.0 rods:
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Dang James,
85 Camaro, 56 F-100 and don't you also have a '60 something Mustang lurking around? Explain this starving student thing again?
Originally posted by BretD 88GTA
Dang James,
Dang James,
Engine: 3.6L
Originally posted by injdinjn
why bother, just drop a late 60's 428 in it. I did.
It's all about the EFI and interchangebilty with my F-body motor
6.0 rods:
Picture of the ones in my motor.
Jerry
Engine: 3.6L
OK, now I've done some more research on Scat. They are located in Redondo Beach but where are the forgings made and where are they finished at?
The crank I got is the on the top of this page.
http://www.scatcrankshafts.com/smblk...dcranks02.html
Balancing it was very easy even with the long stroke (3.800) and Carrillo rods and wiseco pistons that are on the heavy side.
Jerry
gixxer92
05-18-2017 11:20 AM
the_hamturdler
09-30-2015 12:50 PM
