Super Ram fit's Sdpc Base now.. Don is awesome
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I case you don't know.....the SR runnners hit the bolt head so it didn't fit.
I took a rotary file and lowered the surface and then used a countersink and a tapered head 5/16" allen head bolt. Now the bolt head is flush. (had to do this on two of them) Walla...problem solved
Look closely at picture again and you will see it.
Vortec heads?
So we definately don't have to worry about the smog laws here in CA for the Vortecs?
I know we've gone through this before prolly, but is the final word that they'd be ok?
Cuzz I want to start gathering parts....
It all depends on which test only station you go to. It requires hooking up the EGR like the corvette. To most of them a SB chevy is just that....a SB chevy
Originally posted by formula91
Vortec heads?
Vortec heads?
Can they not pass a visual for being a corvette egr regards to any kind of head?
Originally posted by 8T8IROC
FYI - if you look for a set of 1.6 rollers that will fit on Vortec heads the LT4 Rollers fit nicely
Car: Moving...
Engine: Running...
Transmission: Shifting...
I bought them to install on my IROC but the rollers do not clear the springs on the heads. They look just like the crane gold race rockers. They are aluminum in color with a Bow Tie stamped on them as well as a 1.6, I bought them from SDPC, I just looked over the site and found them
I hope that helps
I hope that helps
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Good job Don. That is using your noodle. Hehehe. Looks like Brandon is going to have a very nice car.
Allen
Allen Supreme Member
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Branden is still going to get his *** whipped even after he learns how to drive!
Just Kidding!!!
:rockon:
Just Kidding!!!
:rockon:
haha very funny Vincent.. You may be right..
Thanks Allen... It may not have all the top notch parts but hey I tried
It really was a combonation that came together over a long period..
Im going to check out those rockers right Now Randy
Vincent... Stay awake..
It's going to launch..
BrandenCali
It really was a combonation that came together over a long period..Im going to check out those rockers right Now Randy
It's going to launch..BrandenCali
Car: Moving...
Engine: Running...
I could have used them on the Trickflow heads, but like I said the body of the rocker itself rested on the valve spring retainer - not good
If you are interested in these rockers for your motor, shoot me a PM as I still have them and don't current have a project to use them on
Car: 1988 Camaro Convertible
Engine: 355
Of course branden if you would of listened to Gene you would have AFR's flowing more air, and wouldnt need a custom intake
Though getting the super ram with those vortecs is pretty cool looking.
9192camaro
16
Feb 3, 2019 12:21 AM
L98GTA87
Aug 11, 2015 06:55 PM
Don, congrats on getting farther along with your setup Branden
