Southern California Area Southern California Members.
header protection
Old Jul 1, 2009 | 04:00 PM
captain_camaro's Avatar
Car: 1989 camaro Rs or iroc clone??
Engine: 5.oh tpi
Transmission: borg warner t5 world class
Axle/Gears: 3.23-GU5
header protection
i have edelbrock shortys on my 89 and they keep burning my plugwires as well as starter wires and fanswitch wire basically EVERYTHING!
ive tried the wire boots 70bucks ate through them. high temperature tape($25) same thing.... ive had to replace my msd as well as accell wires 4 times....they dont just eat one or two wires...THEY EAT 6 ALL THE TIME!
when i replace the wires car is fast n responsive.....then when its sluggish i know what it is....it gets to my coil n fuuks it up kuz of the missfiring....please ANYONE WHAT CAN I USE!! ill go to home depo walmart kmart where ever! GIVE ME A SOLUTION!! summit, jeggs,autozone kragen n pepboys just wont cut it!
Old Jul 1, 2009 | 04:10 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: header protection
Ceramic coating inside and out.
Old Jul 1, 2009 | 04:23 PM
Engine: 5.oh tpi
more specific please
Old Jul 1, 2009 | 05:02 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
There is some heat shield stuff that you can wrap around the header tubes, I dont know the name but I have seen it, probably expensive.
Maybe you need to consider rerouting your wires.
Old Jul 1, 2009 | 05:39 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Like injdinjn said, they sell header heat wrap that is supposed to insulate the headers and keep heat from radiating outward. I don't think they're very expensive, however if you have any warranty on the headers then they become void when you use the header wrap, because the wrap is rumored to eventually cause the headers to rust out.
And Darkshot was referring to having your headers ceramic coated inside and out, the headers will last a very long time if you have them ceramic coated, and it should cure your problem with everything getting fried.
This is probably the best place to get your headers coated.
http://www.jet-hot.com/
You can also have your entire exhaust system coated by them.
Old Jul 2, 2009 | 09:12 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Coating them is a very good idea, however covering them is a definate no no.
First tho you need to figure out what is causing the heat, headers should never get that hot. Something has to be causing it, like late timing or lean condition.
Putting a band aid on doesn't help cure what is really wrong.
Old Jul 2, 2009 | 10:08 AM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Do you have stock heads? If you have angle-plug heads, it will push the plug boots against your headers and they will burn no matter what. I'm not sure I would recommend coating a set of Edelbrock headers, they are really a pretty marginal design if you plan to get any serious HP, and coating them will probably run a few hundred.
Accel just introduced plug wires with ceramic boots for this very problem. Here is the link, go have a look...
www.accel-ignition.com
TA
Old Jul 2, 2009 | 10:29 AM
Engine: 5.oh tpi
you are right the headers being wrapped causes them to rust away!
and also ave been having a timing problem with this freakin car ever since i built the motor...i bored over the block .030 flat head pistons mild can aluminum heads msd ignition bigger intake street legal headers roller rockers n other stuff i cant think of at the moment :/ and i pass smog
well Ever since i built that motor i could NEVER get the timing right...its TBI but the weird part about it is that when i bought the kit from summit.....they told me i should pull about 400 or close to hp...mmmmmm i kinda dont think so (-.-)...but i did, believe it or not keep up with a gto 6.0 i was on his door the whole time n that was because i got cut off on the fwy......
well any way when i took it to a dyno tune the guy told me "what the **** is Wrong with this shYt! i cant find the peak!"
well i went home n did what he recomended....to change the harmonic balancer... as i loosen the bolt in the center of the crank i notice the harmonic was REALLY lose!.....i pulled it off with my hands EASiLY i was like ....oh....no.... i looked over at the crank and my crank tip was broken i look at the harmonic n that piece was there with the CRACKED harmonic.....sad day that day so im guessing that was my problem....
now im converting the car to manual I bought a borg warner t5 world class fresh rebuild..with a stage 2 centerforce im also going to customize my computer (id rather not risk anything) and well i was SUPPOSE to start the car a month ago...but some one told me about a pilot bearing not installed....n well this is my first time dealing with manual parts...i was like SH!!!!!!!!!!T so now im laggin on it but im getting on it this friday...
so what do you guys suggest?
Old Jul 2, 2009 | 10:32 AM
Engine: 5.oh tpi
TA
aluminum edelbrock heads is what i got.........n oooooooooooooooooooooooooooooooooooooooooooooo (0.0) i like those wires Thanks for showin me...i think ima go with those...
Old Jul 2, 2009 | 03:05 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Yes, Accel makes their Extreme 9000 wires which are supposed to be very heat resistant. I run these on my car. Never had a problem.
As Don mentioned though, you might want to check your timing. If it's off it will cause excessive heat in the headers and bake everything like you've described.
Old Jul 2, 2009 | 03:11 PM
Engine: 5.oh tpi
yea hopefully i dont get that timing problem now that i have fixed the crank AS WELL AS the harmonic as you can read the chapter i left above lol!
Old Jul 6, 2009 | 02:32 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Also keep in mind there are two lines on the harmonic balancer. I think the TBI and carb cars use the straight up line as 0* but the TPI cars use 2 o'clock as 0*.
Old Jul 6, 2009 | 09:42 AM
Engine: 5.oh tpi
is that right?? i NEVER noticed that ...i mean ive bought the harmonic at autozone..(which is TRASH but i got no money for a better one) and i only see the one line....is there a lighter line? or how can you tell??
Old Jul 12, 2009 | 01:03 PM
Kevin91Z's Avatar
There should be two grooves or lines in the balancer, plain as day. If not then its probably a carb/tbi balancer, but I am not sure.
Old Jul 12, 2009 | 07:04 PM
Engine: 5.oh tpi
mines a tBi motor thats probably why
Old Jul 13, 2009 | 06:44 PM
Dyno Don's Avatar
What he mean't was....there are two different marks on the timing cover.
TBI is at 12:00 o'clock TPI is at 2:00 o'clock.
Old Jul 13, 2009 | 07:03 PM
injdinjn's Avatar
Thats only 30 degrees
Old Jul 14, 2009 | 10:20 AM
Engine: 5.oh tpi
ok ill look that up then....before my crank broke i had put a chrome cover with an aftermarket tab(biggest mistake)and timing was an impossible.... now that i swapped the crank and i put the old cover back im hoping the nightmare is over
Rousseau92maro
Feb 1, 2016 05:12 PM
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
