Popping sound when taking off!
Old Jul 26, 2002 | 09:12 AM
mjjmike's Avatar
I have an 89 Pontiac Firebird. When I take off from a dead stand still and really give it gas, like just punching it...I hear a lound popping sound from what sounds like the right front wheel. Anyone have any idea what this might be? I have NO experience in the chasis, suspension area. So I was hoping someone could help me out on this. Thanks in adavance.
Old Jul 26, 2002 | 09:16 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
tranny mount
Old Jul 26, 2002 | 10:46 AM
mjjmike's Avatar
Thanks Man! Is this something that is very hard to repair? Is it something that is loose or is it something that could be broken? Or either?
Old Jul 26, 2002 | 03:04 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
yea my freinds camaro did the same thing and I think it was the trans mount. Its not that hard to replace. Just take off the bolts raise up the trans a bit (you could use a jack) then put in the new one.
Old Jul 26, 2002 | 03:20 PM
mine was broke in two pieces. easy to replace, i used an energy suspension poly one.
Old Jul 27, 2002 | 12:49 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
This is what you need:
http://store.summitracing.com/partdetail.asp?part=5117
Old Aug 7, 2002 | 11:37 AM
mjjmike's Avatar
Okay guys, I have the tranny mount from summit, now, I guess I am going to attempt to install this thing myself. What am I lokking for here? Is this above the Tranny, under it or what? I was hoping you guys could kinda point me to the spot! I would really appreciate it.
Old Aug 13, 2002 | 03:12 PM
WS6 Berlinetta's Avatar
Ok when you are under the car
You will (or Should =) ) see where the drive shaft connects to the tranny.
There is a cross bar called the tranny cross member it should be a relativley flat bar that the back end (tail shaft) of the tranny rests on.
The rubber chunk between the cross member and the tail shaft is the transmission mount.
If you jack the tail shaft up the rubber most likely will be split in 2 pieces. It's should be one solid piece.
R
Old Aug 13, 2002 | 08:26 PM
83 MidniteZ's Avatar
If the sound is coming from the right front tire it could be a loose sway bar. i was experiencing the same problem with mine and found my endlinks needed replacing. Wouldn't you hear the noise in the tunnel if it were the trans?
RazorN8
Jan 7, 2022 11:44 AM
db057
Sep 4, 2015 07:57 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
19irocz85
Aug 26, 2015 07:54 PM
aaron7
Aug 26, 2015 09:45 AM
