Wonderbar in 3.1 V6
Old Oct 1, 2002 | 06:45 PM
planman's Avatar
Car: 92 RS
Engine: 3.1 V6
Wonderbar in 3.1 V6
I am looking for info to safety relocate the lower radiator hose and support bracket so that I can install a wonderbar in a 92 RS with a 3.1 V6.
Old Oct 1, 2002 | 07:23 PM
AFrikanGoodTime's Avatar
I just cut off aprox 3" of the bottom radiator hose (side to the radiator with the funny bend) and completely removed the plastic bracket. Been like that for a year or so and works great. We drive this car daily.
Old Oct 2, 2002 | 06:17 PM
planman's Avatar
Car: 92 RS
Engine: 3.1 V6
I'll give a try. Beats buying a V8 radiator that is suggested in some other posts
Old Oct 3, 2002 | 08:25 AM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I had to put the hose up alittle. It fits...
Old Oct 5, 2002 | 06:54 PM
kizz's Avatar
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
I just installed a wonderbar in my 2.8 V6 car last night. no hose cutting or re-routing necessary. The lower hose does touch the wonderbar a bit, but there's no hose deformation or bandwidth decrease.
Ironically, I haven't really noticed a *major* difference in handling yet. I took it down some hairpin curves but it handles about the same as before, which is to say damn well for a base bird, being an F41 with P245 15 inch tires. The wonderbar seems to have made no difference as far as I can tell. Will keep experimenting.
GT
Old Oct 5, 2002 | 07:02 PM
kizz's Avatar
Old Oct 5, 2002 | 07:21 PM
Originally posted by kizz
Mine WB is a Global West unit. It has a larger diameter than the iroc unit you are using so clearence is a bit tighter than your pictures.
I also did not notice any difference when I first installed it on my vehicle. However, the main reason I put it on is to just strengthen the frame area up front to prevent the prone for cracking area behind the steering box. I run larger rims and tires than the stock V6's and I truely believe that GM put the Wonderbars stock on the larger tire Irocs for this simple reason. $50 is cheap insurance not to have the frame flex and crack.
Old Oct 7, 2002 | 02:23 PM
drop-top IROC's Avatar
Engine: 305 TPI (LB9)
Transmission: WC T-5
You are probably not going to notice any major difference in handling, what you will notice are things like less tendency for the steering gear to start pulling out of the frame rail or causing stress cracks, your radiator not cracking after bottoming out your front end hard, potentially less cowl shaking, etc.
Elephantismo
Feb 13, 2019 12:51 AM
Scamo-2.8
Dec 5, 2015 09:16 PM
cking99
Sep 22, 2015 11:33 AM
snakeshooter
Sep 10, 2015 07:46 AM
