One brake grabs first
Old Oct 10, 2002 | 06:25 PM
Project Z's Avatar
Car: 1987 Iroc Z28
Axle/Gears: 9 Bolt, 3.23 Posi
Just bought an 87 Iroc, 305, 5spd, Carb. just to let you know what I'm starting from.
When depressing the brake pedal while in motion, the car will initially pull to the right and then track straight. I assume that the right caliper is grabbing first, but I don't know the cause/soultion. Any sugestions are welcome.
Thanks.
Old Oct 10, 2002 | 06:29 PM
f0rmula350's Avatar
damn, i thought i was the only one. except myne pulls to the left and then the steering wheel starts to shake violently. ive heard from a number of people that the brake lines go bad after a while, so i would start there. im about to replace everything that has to do with brakes in the front. good luck!
chris
Old Oct 10, 2002 | 10:10 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
It's either the hoses or the calipers. Mine did this and I replaced hoses and calipers at the same time. It was so bad that one caliper was getting stuck and when I would drive smoke would come from the pads from the heat.
Old Oct 10, 2002 | 10:26 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Change out your hoses and the calipers. It's all cheap, so change them all. Flush out and change the old fluid and you should be all set.
Ed
Old Oct 10, 2002 | 10:44 PM
87Formula4bbl's Avatar
Car: '87 Formula
I had the same problem on my 85 Trans Am. After a while, the flexible rubber hoses connecting the calipers to the main brake line hoses built up with junk. This also decreases stopping power. I think if you replaced these, it should make a difference. I think they are around ? $12 ? apeice.
Old Oct 11, 2002 | 09:41 AM
Project Z's Avatar
Car: 1987 Iroc Z28
Thanks for your suggestions. The car is less than a week in my possession and every day a new laundry list of repairs. Thank the Lord I found this resource. It really is invaluable.
Old Oct 11, 2002 | 01:09 PM
MdFormula350's Avatar
hey thats what thirdgen's are good for j/k
anyway start cheap and do the brakes hoses, and then see what happens..
Old Oct 12, 2002 | 01:28 AM
CheezX's Avatar
Mine likes to do this ...
Old Oct 12, 2002 | 03:10 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
mine does that too...... freaking driver's side front lockup.
Old Oct 12, 2002 | 11:40 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Mine likes to do that too, just in a little differant fashion...
Old Oct 13, 2002 | 12:31 AM
CheezX's Avatar
hey those marks look throttle related. lol
Old Oct 13, 2002 | 09:13 AM
Car: 1988 IROC-Z
yeah mine does that too when i push the other pedal to make the car go, to the floor
Old Oct 13, 2002 | 11:12 AM
AFast83z28's Avatar
reply
my back brakes did that. They are drums and I hate drums. One i think rear wheel cylinder or something of that nature started bleeding and it locked my rear right drum every time i touched the brakes...that basicaly means...i slid 10 feet every time i wen tot stop
Old Oct 13, 2002 | 03:19 PM
CheezX's Avatar
my friend's '68 Chevelle did that. drums front and rear. fronts didn't work, rears always locked up.
300+ HP, crap brakes, crap handling. soooo much fun to drive. scared the hell out of everyone.
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
