What specific year F-bodies came with the 34mm HOLLOW SWAY BAR?
Old Nov 4, 2002 | 08:19 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Will a 91 V-6 RS have a 34mm HOLLOW SWAYBAR? I need one for my ROAD RACE setup. I already have a 36mm 1-LE piece, but that is too stiff for this application. I use it for street driving. Thanks Gentlemen.
Old Nov 4, 2002 | 08:44 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i doubt an RS will have a 34mm.
the IROC's came with the 34mm hollow front sway bar.
Old Nov 4, 2002 | 08:47 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Thanks for the quick response.
Old Nov 4, 2002 | 08:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Myn 85 IROC had a solid 34 front (I've never actually seen a hollow 34, but from reading on this board, apparently they were available).
JamesC
Old Nov 4, 2002 | 10:24 AM
Dewey316's Avatar
Car: 1990 Camaro RS
your iroc should have had a hollow 34mm front and solid 23mm rear.
Old Nov 4, 2002 | 10:44 AM
JamesC's Avatar
Mine were solid, a 34 front and 24 rear.
JamesC
Old Nov 4, 2002 | 06:44 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
a 36 solid sway bar shouldnt be stiffer than a 34mm hollow, hollow ones are stiffer by design, always
Old Nov 4, 2002 | 07:06 PM
87IROC350's Avatar
Engine: 5.7
My 87 IROC has a 34mm hollow sway bar with a 24mm rear. I just removed it to install a 36mm (also hollow).
FYI
Old Nov 5, 2002 | 08:24 AM
88SS6SPEED's Avatar
Car: 88 Monte SS
Hey 87IROC350, do you want to sell that 34mm HOLLOW SWAY BAR? I also live in Florida. Let me know .
Old Nov 5, 2002 | 08:45 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
My Iroc also came with 34 mm hollow/24mm rear bars. My RS came with 34 mm hollow/21 mm rear bars. I replaced the 34 mm on my Iroc with a 36mm bar...
88SS6SPEED, if you want my 34 mm hollow bar, e-mail me:
ebmiller88@aol.com
Ed
Old Nov 10, 2002 | 01:36 PM
89firechicken's Avatar
how can you tell if your sway bars are hollow or not?
Old Nov 10, 2002 | 03:25 PM
ebmiller88's Avatar
They will have little drain holes on each end near the ring where the end links fit in to it.
Ed
Old Nov 10, 2002 | 07:40 PM
MdFormula350's Avatar
so you can get the 36 mm hollow sway bar from the 1le camaros, thats good to know if i need one.. just in case i find a wrecked one at a junk yard..
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
