susp setup ??'s opinions welcome
Old Nov 29, 2002 | 02:54 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
ok, i was looking at the eibach pro kit springs, and kyb struts for my rs. does anyone have this setup? do i need new control arms with this?
is there a better more cost-effective setup to go with?
my plan is to put the new stuff in the rs and then take the rs parts and put them in the z, since it needs new springs and struts.
also does my z have larger sway bars than the rs? b/c i will swap those out as well.
thank you, any help or suggestions will be helpful
:hail:
Old Nov 29, 2002 | 04:30 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The Pro-Kit with KYBs is a great setup, I've had mine in for about 5 months now. I strongly recommend it for a budget minded upgrade. No you don't need new control arms, just get it aligned after.
As far as the sway bars go, you'll just have to measure. Both my Iroc and my RS came stock with the exact same springs and 34 mm hollow bars up front. The Iroc came with a 24mm solid rear bar, the RS with a 21mm solid rear bar.
Ed
Old Nov 29, 2002 | 06:30 PM
brett_sc's Avatar
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
eb-
what kyb shocks are you running? Gr-2 or Gas adjust?
or, which ones are the better pair for our cars?
Old Nov 30, 2002 | 05:31 AM
ebmiller88's Avatar
GR2 struts and the Gas-A-Just rears. I was told this was a matched combo and other guys who are running the same pair were happy with them. Summit lists them as a set in their catalog also.
Ed
Old Dec 2, 2002 | 06:27 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
eb...what setting do you run the rears on?
Old Dec 2, 2002 | 06:35 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
what's the cost out of summit, if you remember?
tire rack wants $269 for the springs, and i can't remember what the shocks/struts kit was
thanks again
Old Dec 2, 2002 | 10:21 PM
MdFormula350's Avatar
yeah www.tirerack.com sells the springs, and the kyb shocks and struts.
Old Dec 3, 2002 | 08:37 AM
ebmiller88's Avatar
racereno,
No setting. These aren't the AGX adjustables. I dunno why they call 'em "Gas A Just".
Ed
Old Dec 4, 2002 | 01:29 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Thanks eb I didn't know that Gas a Justs weren't adjustable.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
customblackbird
Oct 1, 2015 04:30 PM
HikoriYami
Sep 21, 2015 07:11 PM
WhteRbt
Sep 21, 2015 09:48 AM
Jlanz55
Sep 8, 2015 11:28 PM
