Fixed the problem!
Old Jan 11, 2003 | 04:27 PM
TransAm's Avatar
From: Somewhere in between Lynn, MA (home) and Lakeland, FL (school)
Fixed the problem!
Hey. I posted on here a while back about a funny handling problem, where you would turn the wheel and it felt like the chassis moved before the body. CrazyHawiian recommended i replace the suspension bushings. I'm a little short on cash, so i only replaced the anti-sway bar bushings. But wow. It made all the difference in the world. It handles like a completely different car now.
Old Jan 11, 2003 | 04:31 PM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Great! Next job is to replace to uppers. I noticed a difference when I changed mine too
TransAm's Avatar
Uppers?
Old Jan 13, 2003 | 12:16 PM
aklaim's Avatar
Upper what?
Old Jan 13, 2003 | 01:03 PM
Upper sway bar bushings. SOrry, TransAM said he replaced the sway bar end links only (I think). I was being lazy.
Old Jan 13, 2003 | 01:17 PM
aklaim's Avatar
There are no "upper" sway bar bushings. There are sway bar bushings and there are endlinks. He said he changed out his bushings....
Old Jan 13, 2003 | 02:46 PM
TransAm's Avatar
I did the bushings that connect the sway bar to the brackets in the middle of the car, as well as the bolts&bushings that attach it at either end.
Old Jan 13, 2003 | 02:49 PM
aklaim's Avatar
Cool, sounds like you got everything.....as far as sway bars go.
Old Jan 13, 2003 | 03:57 PM
aklaim
Man you are a stickler!
According to Haynes and CHilton, they are actually called "insulators" at both the bracket and end-link, but how technical do we want to get?
And in my hand, I'm holding a package entitled, "sway bar end link bushing set".
Anyway...for some reason I thought that TransAM had only replaced the bushing at the end-links and after he raved about his results, I merely suggested that he replace the "insulators" at the brackets (i.e upper bushings).
Wheeeeew! Now that thats explained.........
theshackle
Mar 5, 2017 06:37 PM
dyeager535
Aug 28, 2015 08:10 AM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
