Coil over street kit
Old Jan 11, 2003 | 05:24 PM
Turbojunkie's Avatar
Does anyone make a good coil over suspension system for the street and about how much does it go for? Tubular A-arms and their price? Also what are some go suggestions for shocks & struts for a daily driven 90 Iroc when using coil overs?
Thanks all input.
BT
Old Jan 12, 2003 | 08:28 AM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Hey
I remember asking the same question a while back.
Take a look at http://www.paracing.net/
Old Jan 12, 2003 | 04:51 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
You can also check out
http://www.roadtechonline.com
I'm going to be ordering their kit pretty soon.
Old Jan 12, 2003 | 08:39 PM
Kandied91z's Avatar
i'd like to know as well.
i was told the pa unit worked very well, we just installed one here at the shop a little while back with the works and it looks awsome....damn winter weather for not being able to really road test her though.
fit and finish though i was very happy with it, plus i can use my existing bilstein struts so i can only benefit from the setup. less weight and adjustable ride height. i like....cost i don't.
let me know if you find any more info out.
Old Jan 13, 2003 | 03:15 AM
REVLIMIT's Avatar
Engine: Built L98
how much weight do you think it shaved? if you know
Old Jan 13, 2003 | 10:47 AM
Kandied91z's Avatar
unless you go with everything down to the rack & pinion steering as well you aren't going to notice it.
you loose more weight removing the air conditioning and less worries about road troubles.
searching all over the internet i've found quite a few stories from people using these on various cars that have had some major incidents through no fault of their own over time.
i think it looks great and is very useful....i just don't know about it.
Old Jan 13, 2003 | 12:47 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I am not sure about the front, but you can put coil overs on the back easy.
I got coil over with half inch lift studs on the back of mine. Any auto store sells coil over springs for shocks. I like them allot, the added pre load is nice. Also my car rides nice and level, even full of people.
In the front if you look, there is enough room to put a shock in the stock a-arm. and maybe even a coil over shock.
take a look down there, it could be done in a few hrs.
Old Jan 13, 2003 | 05:21 PM
german-motorsport's Avatar
Rear and front coil overs are no problem on a third gen!
Konis yellow!
If cash is not the problem: penske!
In 3 weeks our cargo con will be here and weŽll swap to
Baer / Alcon 14" Frontmonsters!
Old Jan 13, 2003 | 05:37 PM
SuperchargedRS's Avatar
Car: Camaro of course
What about QA1(or it might also be called HAL)??? I hear good thing's about these guys. I also like the fact that there shox are re-buildable.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
Americanmouse
Sep 7, 2015 12:10 PM
lt1z350
Aug 28, 2015 05:57 AM
TreDeClaw
Aug 14, 2015 06:58 PM
